#8093 |
![]() ![]() ![]() ![]() Drives: bug Join Date: May 2009
^ Or just momentary gearing advantage.
Honestly id like to see that race |
#8094 |
![]() Drives: Black SS Join Date: Apr 2010
whats the rear gearing on the L99 cars? 3.45:1? because on the 2011 GT's the autos have 3.15:1.
#8095 |
INTHECLOUDS
Drives: 2010 2SS/RS Join Date: Aug 2009
Great race...The L99 has a tremendos amount of Torque Management which probably explains the 1-2 pull. I would have to assume Ford did a better job of setting their shift profile up to make the car actually shift firmer. Having said that, stock for stock looks like and honest kill.
2010 IOM 2SS/RS A6, Tuned by Me, ARH/NoCats, Borla Touring, Vararam CAI, G-Force 9" with 4.10's, Circle D 4500K, (Skinnies/Slicks, and Bogarts all around 24MPG
11.39 @ 118 510 DA ![]() www.6l80tuning.com www.6l90tuning.com |
#8096 |
#8097 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2005 STi corn fed Join Date: Jul 2008
The whole gearing issue has been proven pretty much moot considering the fastest 5.0's have both been the tallest geared. An auto (3.15:1) running a 12.57 and a manual (3.31:1) running a 12.58.
#8098 |
![]() Drives: 2010 Vette Join Date: Jun 2010
What the rear gear is means nothing by itself. You have to look at each transmission gear and multiply that by the rear gear to get the effective actual gearing (and then consider tire diameter if you want to really get down to it).
The 5.0 vs the SS is a great example. With factory, non-optional gearing, the SS has the advantage in rear gears (3.23:1 vs 3.15:1 and 3.45:1 vs 3.31:1). But when transmission gearing is taken into account, the "advantage" completely reverses, and even becomes much more pronounced. |
#8099 |
That's not my point. My point is, the 3.73 equipped cars aren't (apparently) ETing quicker in the 1/4 than the taller geared cars, nor are they ETing quicker at any reference points, such as 1/8, 1000', etc. Any advantage the 3.73's hold is theoretical and unproven. I see a lot of people on this forum assuming that a shorter rear gear means a quicker car, which is not always the case. How power delivery meshes with the gearing is much more important than how short the gearing actually is.
#8100 | |
Camaro & Stang Enthusiast
Drives: 2011 Mustang 5.0 in Kona Blue Join Date: Mar 2008
Bought my Camaro from Eric Hall(817) 421-7266
#8101 |
INTHECLOUDS
I picked up maybe 2/10s from the gear swap, but actually feels like 1/2 second... We will see when the temps get cooler. My latest run was a 12.3 @ 112 85 degrees 90% humidity.
#8102 |
Ahh ok, so there is more to it than driver experience that makes for the faster times..
#8103 |
Drives: 2003 Cobra Convertible Join Date: Feb 2009
i believe there an auto that ALSO ran 12.53 aside from the 12.57 you listed.
#8104 |
#8105 |
INTHECLOUDS
That's what I've noticed. I actually trap about the same, only I do it at the top of 4th where before it was the top of 3rd. The car feels allot stronger off the line, but goes through the gears so quick you don't get the long pull anymore. The key is to get the shift points down low just as the HP curve starts to fall. Also shift completion on the backside/decreasing side of the torque curve negates slower ETs.
#8106 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 SS & 2008 C6 Join Date: Mar 2008
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s! Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list.. |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Camaro VS Mustang Mega Thread | Beau Tie | Chevy Camaro vs... | 3644 | 03-09-2012 07:45 PM |
| Gran Turismo 5... No Camaro? | 5thGenOwner | 5th Gen Camaro SS LS LT General Discussions | 111 | 12-06-2011 10:06 AM |
| Official 2011 Mustang GT info released | nester7929 | General Automotive + Other Cars Discussion | 81 | 12-28-2009 03:13 PM |
