#785 |
![]() Drives: '18 Hyper Blue 2SS1LE '20 Crush RSR Join Date: Aug 2018
I have the cradle bushings too, just not installed yet. I have the SPL rear toe arms and with the hex profile on the center bar it will make at track adjustments easy. My next alignment I will set a bit more static toe in and then check what adjustment a flat(1/6th turn) does either way.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track |
#786 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
I think the main choices are the GMPP ZLE bushings, which are aluminum, or the BME Delrin bushings.
I got the ZLE bushings, there are a few threads here on the install, which is a PITA but not that bad if you have the right tools to remove and install the bushings. The install is permanent and it says it will invalidate warranty, but I figure if I paint them black before I bring the car in nobody will notice. Price was about $425, I think it was worth it but I'm not sure it's doing the same thing as the ediff tune, ime the tune and bushings solve completely different issues. Both are more subtle improvements overall, the car is still great stock. To me, bushings improved the overall feel of the rear end of the car, plus more info gets to your butt. You can feel the surface texture of the road better, lol... In some circumstances you can feel the rear subframe bushing flex, this totally eliminates it.
#787 | |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
#788 |
![]() Drives: 370z, Srt-6 Join Date: Aug 2017
Dropping the car off tomorrow to get the apex wheels put on, 315/335. Zle. Can anyone share a autocross alignment? I’m at -2.7 and -2 front and rear. Going to see if they can get -3 at least front. What are some toe specs, I do think I will toe out the front a touch, but how much do you guys recommend. Car only will get 4000ish miles a year so front wear isn’t a big deal to me. This is the first autocross car I’ve had with any real adjustment. What’s everybody running on rear toe?
Thank you |
#789 |
![]() Drives: 2019 ZL1 1LE Join Date: Sep 2010
Autocross alignment for a ZL1 1LE? Absolute max camber in front, should be around -3.7. Somewhere around -1.8 to -2.0 rear.
I run zero toe in front, only 1/16" total toe-in rear. That's mostly preference. |
#790 |
Who Needs to KNOW?
Running some toe out right now [vs print out shown], but I will freely admit I dont know what I am doing
![]() Toe out does seem to turn in better than track alignment guide which has toe in. Should schedule some rack time to see where its settled after a year of events.
#791 |
That’s what I thought was max, my local shop can only get -2.7, the top hat has been adjusted but they’re saying that’s all it’s got, I’ll have to do some more research and find a printout for them to get some more. Thanks for the info
#792 |
Who Needs to KNOW?
odd.. max without rotating top hat was -2 +/-.. when you rotate top ( remove brass pin), you can go way into deep -3 on ZLE.
#793 | |
Did get my apex wheels in, 315/30/18 335/30/18 stock sizes |
#794 |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
An SS 1LE or regular ZL1 without the flippable camber plates can get -2.7. Mine did. As others have said, a ZLE should be able to go way past that. Maybe they don't know about the adjustment at the union between the strut and knuckle?
Matt Miller
2020 SS 1LE |
#795 | |
#796 |
Everything disabled. I run in track mode but over ride options in the infotainment screen. Steering is always on Tour, Exhaust in Track, Suspension in either Sport or Track depending on surface conditions and temperature(ambient and surface). But if it's wet I run suspension in Tour.
#797 | |
Might help with the corner exit oversteer by being not so quick as sport is. I guess not as you still get the oversteer, even with the EDiff tune. I would leave the rest as you do. Our low grip worn out lot needs sport on suspension. |
#798 | |
![]() ![]() ![]() ![]() Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
Video of my left and right sides at this years Toledo pro. Only ever done three pros in my life as pros aren't my focus but it is fun. Need to work on my launches. Car wasn't 100%. I could tell my first few runs the handling was way way off, understeer into massive over steer. something was up. got the car back to paddock lacked it up, and bingo, BMR bushing blow out. Bushing would not stay in place, no place locally had the right size I could make do and mend but to I had to deal with the clunking and inconstancy feeling. The car was sooo wayward and inconsistent but I was able to calm it down and come home in second.
#53 F Street
2025 FS National Champion 2025 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 |
