Old 03-08-2020, 05:48 AM   #7953
Soleil
Soleil's Avatar
Originally Posted by JonDaddy82 View Post
Did the seat recline mod for the misses, also swapped out the wireless charger for the base model cubby.
Do you have the DIY for the recline mod? I really like you highly professional lifting tools (kitchen paper)
Soleil
Old 03-08-2020, 10:48 AM   #7954
carrmro
carrmro's Avatar
Drives: 2018 Chevy Camaro RS
Thumbs up
Originally Posted by blueg1 View Post
Love the Red Accents.
AWESOME!!!
How did you add the Red trim to the front splitter? Is that just red trim tape? I was thinking about doing that to my Front Splitter and Side Skirts.
carrmro is offline   Reply With Quote
Old 03-08-2020, 10:50 PM   #7955
beworthy3
beworthy3's Avatar
Drives: 2018 Camaro SS 1LE
Installed borla atak axle back!
Installed a borla atak axleback with the help from my uncles friend who let us use his lift (helped a ton)! This system is awesome
beworthy3 is offline   Reply With Quote
Old 03-09-2020, 02:48 AM   #7956
MakCamaro
Makis
MakCamaro's Avatar
Drives: 2020 Red Hot ZL1 A10
This is the exhaust that I want to install. Can you post any videos?
Old 03-09-2020, 04:53 PM   #7957
beworthy3
beworthy3's Avatar
Originally Posted by MakCamaro View Post
This is the exhaust the exhaust that I want to install. Can you post any videos?
I dont have anywhere to upload them, but they sound just like the ones on youtube, phenomenal!
Old 03-09-2020, 07:28 PM   #7958
wookwook
wookwook's Avatar
Drives: 18 Camaro LS M6
EZ Gauge Dash Gauge Pod install
Just thought I would share a trick I used to get a hole in the window vent duct. Get a piece of 3/4 copper and your handy dremel. Don't have one yet? now you have a reason. Use a metal wheel and a hammer and shape the pipe like such. It will clear. I appreciate my dentist now...lol. seeing the edge of the duct end. Back up... If you push the oem vent back a bit there is a slight opening in the seam to use your PLASTIC Body tool Only! Wedge or pull the eom vent out and wire your gauges like so. You Dont Have to remove the side panel to do this, but it helps. Wedge the side panel hard and it will pop. You want to go into the duct about an inch and a half. Heat this baby HOT and position accordingly. Press the Die down and voila, you have your wiring channel through the window vent duct. Good Luck! Sorry the uploader decided to place the picture sideways.
NFG M6 2T
Mishimoto Hot side pie | ZZP Catted DP | KN Drop in | Borla - Sport Tour | Apex Arc 8 - square | Wookster Tuning+ | Flex Fuel
Last PB
4.8, 13.2@106
wookwook is offline   Reply With Quote
Old 03-10-2020, 06:22 PM   #7959
CamaroSS18
Camaro2SS18
Drives: 2018 Chevrolet Camaro 2SS
I have received my GM CAI, Mishimoto Oil Catch Can, Seat Belt Covers, GM Convertible Windscreen and Lloyd Mats Trunk Mat that I had ordered. Now as soon as spring finally arrives for good and the roads are cleaned up from all the salt and sand, I will be getting it out of storage and I will be installing everything with pictures to follow. Then I will be off to the ACS Composites Factory to have the ZL1 Aeropack to include the side skirts, front splitter with undertray installed. Can't wait, come on spring/summer!
CamaroSS18 is offline   Reply With Quote
Old 03-11-2020, 11:36 AM   #7960
Originally Posted by CHV2SS View Post
nothing but pita coz my 2ss got scratched (kind of deep) by a garage door
where can i buy a good paint satin steel?
Them nasty garage doors jump out from nowhere. I still remember when I sheared the pass side mirror clear off my old Grand Am on a sleepy winter morning, haha.
Search for "acdelco satin steel touch-up paint" on ebay or amazon, make sure the paint code matches yours, I've found G9K (or WA464C), but you can check on the service parts identification label in the trunk, under the floor cover.
If the gouge is deep and long or the panel is dented, however, you want to get this fixed professionally.
Old 03-13-2020, 08:41 AM   #7961
CHV2SS
Drives: '19 camaro 2ss
Originally Posted by Hyper16 View Post
Mishimoto Catch Can
Attachment 817614
Don't mind the silver washer. One of the black ones was missing. Trip to the store tomorrow will fix that.
planing on getting a catch can but first i want to know how hard to install it?
CHV2SS is offline   Reply With Quote
Old 03-13-2020, 10:24 AM   #7962
It's a trivial install, you just unplug the short stubby PCV hose, mount the catch can as on the picture above, and attach the hoses. A 10-minute job even for a stinky amateur like me. Double check if you attached the in/out hoses correctly to the can.
Old 03-13-2020, 01:56 PM   #7963
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Add some painted knee pads and door inserts.
https://www.camaro6.com/forums/showthread.php?t=571841
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 03-13-2020, 02:19 PM   #7964
Soleil
Soleil's Avatar
Looks like OEM.
Soleil
Old 03-13-2020, 04:39 PM   #7965
GroundhogSS
GroundhogSS's Avatar
It is easy but be careful when removing the hoses from the intake manifold. The fitting the hose goes on is plastic, as is the manifold, and can break easily.
Richard
Delivered: 08/15/2016
#TeamBeckyD
Old 03-13-2020, 07:02 PM   #7966
ItsChristianInHD
ItsChristianInHD's Avatar
Drives: 2017 Camaro 2LT RS 3.6L
Do you ever just look out and look at your car?
ItsChristianInHD is offline   Reply With Quote
