Old 11-29-2019, 04:47 PM   #7673
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Cleaned her up and put away for the winter (with a new cover)
Old 11-29-2019, 05:11 PM   #7674
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Nighty night.... Think it's going to be a looong "busy" winter for us too
driven2exceSS is offline   Reply With Quote
Old 11-29-2019, 09:42 PM   #7675
I almost posted a pic very similar to Chutzpah's, but decided not to, who wants to see all these covers and battery tenders, heh. I cleaned her up nicely and detailed the interior, too. Hoping for a short winter
Old 11-30-2019, 10:44 AM   #7676
inlinejohn
Drives: 2019 Camaro 1SS_1LE
I can relate. Mine is soon to sleep too. Similar cover. Consider FlatStoppers by RaceRamps. I picked up a set and is gonna be very helpful for those tires
inlinejohn is offline   Reply With Quote
Old 11-30-2019, 11:41 AM   #7677
Chevyfan4life
The Green Hornet
Chevyfan4life's Avatar
Drives: 2020 Rally Green 2SS 1LE
I like the 1LE badge on the hood.I was thinking of doing that myself.looks really good..
XCMKZ4- 2020 Rally Green 2SS 1LE
1100-07/02/19
3100-07/04/19 | TPW 8/5
3400-7/29/19
3800-8/2/19 Built!
4300-8/5/19
4300-8/9/19 delivered to rail yard
4200-8/13/19 Shipped!
5000-8/19/19
6000-8/24/19 She's Home!
Chevyfan4life is offline   Reply With Quote
Old 11-30-2019, 01:20 PM   #7678
I already have nice plastic tiles on the garage floor, so I cheaped out and simply aired the tires up to 40 psi. We'll see in March whether this was sufficient to prevent flatspotting
Old 11-30-2019, 03:01 PM   #7679
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I can vouch for the Flatstoppers too, they work perfectly.
Old 11-30-2019, 10:41 PM   #7680
KLG
KLG's Avatar
Drives: 2016 2SS Convertible
Changed out the stock lugnuts with McGard black lugnuts:
Size:  43.4 KB Name:  IMG_1996cc.jpg
Size:  40.1 KB Name:  IMG_1997cc.jpg
Also changed to black TPMS valve stem nuts:
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
KLG is offline   Reply With Quote
Old 12-02-2019, 11:06 AM   #7681
madscotsman
Drives: 2018 SS 1LE
Attachment 1012293 Attachment 1012294 Attachment 1012295
Hopefully you put some form of anti-seeze in those valve stem caps... There's a reason the OEM ones are always plastic. They look nice, but those metal ones will eventually fuse to the valve stems after being subjected to the elements and will have to be cut off....
madscotsman is offline   Reply With Quote
Old 12-02-2019, 05:57 PM   #7682
Sheriff37
Do it for Dale
Sheriff37's Avatar
Drives: '16 NFGray V6 M6
Do those stem covers cover all of the exposed metal? The dealership lost two of my four covers so I'm trying to find some replacements. I've ordered 3 different stem covers and none of the sets were long enough to cover them!
Do those lugs require a key to fit over them when you want to take them off? I've been wanting some black ones but I'm also worried about the black scratching off of them.
Sheriff37 is offline   Reply With Quote
Old 12-02-2019, 07:23 PM   #7683
Zaqwert6
Zaqwert6's Avatar
Drives: 2SS
Maybe try not to park in the ocean, lol.
I've got metal/alu caps on every vehicle I own, never had a single problem. Hell, one of my motorcycles has had the same ones for literally 21 years now.
Zaqwert6 is offline   Reply With Quote
Old 12-02-2019, 09:19 PM   #7684
KLG
KLG's Avatar
So far so good without anti-seeze. I've used those black valve stem caps for several years, no issues. I check tire pressures once a month even when the car is parked for extensive periods, so the caps are removed routinely, never a sign of corrosion.
As you can see in the first photo, which I took after I installed the black valve stem nut, but before I re-installed the valve stem cap, the valve stem threads look new.
It helps living out here I suppose, my Camaro has never seen snow and it is not driven in the rain.
Old 12-02-2019, 09:59 PM   #7685
KLG
KLG's Avatar
The valve stem cap snugs up just short of touching the valve stem nut, you can almost see that in the bottom photo.
If you are looking for something like OEM valve stem caps, Amazon may have what you want, expensive however. These do cover all of the valve stem right up to the valve stem nut, in fact, these are almost too long. I use these on my Corvette:
https://www.amazon.com/ACDelco-25858...347829&sr=8-12
For the McGard lug nuts, no key necessary, just a 19mm or 3/4" lug nut socket. I think McGard guarantees their lug nuts not to rust or chip. To be on the safe side, I will not use an impact gun to remove or install.
Old 12-03-2019, 09:19 AM   #7686
DannyC
Drives: 17 Camaro SS
Put these on yesterday. Should be good for 10 HP. What do you guys think. Too much??
DannyC is offline   Reply With Quote
