05-20-2020, 08:42 AM | #7421 | |
Drives: 2018 ZL1 coupe Join Date: Nov 2018
I agree on the 'track alignment', but tests should be run on the OEM tires. Comparison tests should be about what you get off the showroom floor, not the car's ultimate potential... |
05-20-2020, 08:46 AM | #7422 | |
Drives: 2013 C6Z06 Join Date: Nov 2016
Edit: But a same tire same day test after the OEM configuration test should happen |
05-20-2020, 09:40 AM | #7423 |
Drives: 1999 Camaro SS M6 - SBE LS1 Join Date: Jun 2018
Ford had Michelin spec Cup 2's specifically for the CFTP, all while claiming not to be chasing lap times...
"He uses a program that fairly accurately predicts lap times at Virginia International Raceway as the team programs in a vehicle's hard points and tunes for factors such as differential torque bias, tire characteristics, aerodynamics, etc. Early computer twiddling resulted in the team assigning Michelin a fresh set of tire-performance targets (the front tires are especially critical at VIR)" https://www.motortrend.com/news/2020...rmance-wisdom/
1999 Camaro SS 6M - SBE LS1
1963 Corvette GrandSport - ZZ502 4M 2017 Denali 1500 6.2 2017 Yukon Denali 6.2 |
05-20-2020, 10:43 AM | #7424 |
Drives: 2019 CLA 450 Mercedes Join Date: May 2016
I just had a random thought. Why not run the cars with track alignment. Most people will get the suggested track alignment before taking their car to the track. Run the cars with the OEM tires. Likely there has been engineering around that configuration. Run a 20 minute session with 1 warm up lap. You can get lap by lap times, so you can see who runs a faster Hero lap and how the cars hold up over a full session. -- Later thought -- you might need to change brake fluids. No one wants to face a corner, after a straight when your brake fluid has boiled (4 wheelin' times).
I get it that smaller budgets (Throttle House) may not be able to accomplish all of this testing. I think some manufacturers may balk. That should be clearly called out. I also understand that this will require a longer possession time for the car by the testing group. They can then move on to the measurement testing of 0-60 / quarter mile / cornering, etc. This would almost certainly call for a tire change and a reset to street specifications. I would do the road course first as that puts the most strain on components.
2019 Lunar Blue Metallic Mercedes CLS 450
2021 C43 AMG Mercedes Coupe Metallic Cardinal Red 2014 Lincoln MKT EcoBoost (The Bus) |
05-20-2020, 10:44 AM | #7425 | |||
Retired from GM
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
I'm not sure how this was done in the '60s, but I am aware that for the past few decades performance car manufacturers have been working with tire manufacturers to spec a tire for "optimal performance". The first one I can remember is the C4 Corvette in 1984. First time I had ever seen tires with specific corner placement. GM made a huge deal out of working with Goodyear to specifically design the tires to work with the new chassis. Could be that others were doing that before the C4 tires and I just wasn't paying attention. As for GT500 vs GT3RS laps... my opinion is that it's a bit of both car and tire. The stresses on the tires are distributed differently between the two cars. The GT500 front tires have to bear the stresses of directional and momentum changes as the car barrels through the curves. They have to do that with much of the vehicle's weight bearing down on them. The rear tires have an easier job because they are focused on propulsion and traction. On the Porsche, the duty is split differently amongst the four tires. The front tires will of course have to manage all the stress input from steering through corners that the GT500 front tires have to manage, but without the additional stress of supporting a heavy engine. The rear tires have to manage the same propulsion and traction duties that the GT500 rear tires have to manage, but also have to manage additional weight. The additional weight aids the traction for the car but probably also induces more wear on the rears than we would likely see on the GT500. Personally, I like that tradeoff.
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8” LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | |
05-20-2020, 11:40 AM | #7426 | |
Drives: The DSSV Twins: ZR2 and ZLE A10 Join Date: Oct 2019
05-20-2020, 11:41 AM | #7427 | |
05-20-2020, 11:45 AM | #7428 | ||
05-20-2020, 11:46 AM | #7429 | |
05-20-2020, 11:55 AM | #7430 |
Since this is the thread for everything:
https://www.corvetteforum.com/articl...-track-weapon/ Speedphenom, has been to a few racing schools. I thought that kid could drive.. |
05-20-2020, 12:03 PM | #7431 | |||
I fully agree with this type of test. Quote:
Case in point - GTR N attack time (you can't even buy these parts on a North American Nissan dealer, you have to spend $80K + at Stillen, then get the tune and correct fuel). Porsche has also been caught with higher octane fuel than factory spec'd... This is where they start seeing less value in attacking lap records.
05-20-2020, 01:42 PM | #7432 |
Drives: SS 6 speed of course Join Date: Jan 2016
I see few guys on the autoX with "OEM designed tires". I have my doubt on how much collaboration / cooperation are done between the tire guys and the OEM car mfg. Sure there is some, for example the Nexen on the Challenger 1320 has a specific compound on that specific size 275/40R20. Maybe the average GT500 owner will stick to the already sticky spec Cup2s, I highly doubt the Vette, Hellcat and for sure guys like me with a SS stick with the OEM tire. So that is ONE car, maybe 2 if you toss in the GT PP2 setup...
05-21-2020, 09:32 AM | #7433 | |
Ex. Put MPSC2s on the ZLE and watch its 2nd and 3rd laptimes fall off a little bit -Put G3Rs on the CFTP and see how many sessions before they cord and don't mention it got faster, because we don't want that. -Put MPSC2s on the C8 and watch it close the gap on the CFTP even at VIR Full -Put DRs on any car that spins on launch |
05-21-2020, 09:41 AM | #7434 | ||
I have no problem with the CFTP going faster on a different tire, and expect most who track them will likely use a road course tire over the Cup2s or the G3Rs, no different than I have for my GS. Edit: Speaking of same tire, same day comparisons on "equally" equipped cars - Throttle House did this with the SS 1LE and GT PP2 both on Cup2s...
1963 Corvette GrandSport - ZZ502 4M 2017 Denali 1500 6.2 2017 Yukon Denali 6.2 Last edited by NW-99SS; 05-21-2020 at 09:58 AM. |
