View Poll Results: Do you plan to get this recall if you had a choice? | |||
Yes | 245 | 15.30% | |
No | 1,356 | 84.70% | |
Voters: 1601. You may not vote on this poll |
Thread Tools |
06-14-2014, 11:34 AM | #729 | |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
If you read my statement again, I very clearly describe the key and fob with nothing on it. Your physics example requires a lot more rotational force to be applied to the stationary object in the 'chain'- the key- than the model supports, as the fob is not directly moving the key in the manner the recall describes. As an example, if I place a rod through a chain link and then spin the rod, am I spinning the chain link too? Only if the chain link has enough friction, right? Well then how am I spinning the stationary rod by bumping the chain link then? The chain link will just swing. The only way the full force is applied to the key by the fob is when mechanically the fob cannot be rotated further- think about it- and it binds on the keyring. Prior to that point in my stated example, there is not enough friction to turn the key, becasue the fob isn't heavy enough. Your model requires a moment arm mine doesn't and can't have. The ignition is designed to need 3 or 4 lbs of pressure if I recall correctly. Thanks for trying to make me look ignorant just the same, but to refute my statement, you changed my model
06-14-2014, 11:35 AM | #730 |
Raining Blood
Drives: 2014 SS Performance Sedan Join Date: Oct 2009
I'm still waiting for Skidpuppy to explain how the ignition gets cut off by reaching for the radio....
Ordered 1/9/12 - Born 2/3/12 - Delivered 2/21/12 - '12 1SS/RS Summit White - TRADED.
2014 SS Performance Sedan #2974 - Red Hot 2 - S/R. & Spare. Built 01/09/14 #238 of 291 as configured |
06-14-2014, 12:02 PM | #731 |
Drives: 2011 2SS/RS Victory Red Join Date: Dec 2011
I will be curious to see how many people actually get this done once the dust settles. From what I have see on here so far most people including myself won't be getting this done. It's really a non-issue in my mind.
06-14-2014, 12:04 PM | #732 |
Drives: 2011 2SS 6.2L W/RS package Join Date: Jan 2011
So went out and tried this, my knee hits the steering wheel not even close to the key, I would have to move the seat way up close to get my knee to hit it, and even then I tried to knee it like 15 times, and I couldn't get it to shut off.
Again who is going to jerk there foot off the gas to hit the key??
KooKs LT Headers, Borla S-Type cat back, RotoFab CAI, Bo White PTB, RMCR tune... |
06-14-2014, 12:19 PM | #733 |
Drives: 2012 ZL 1 #370 Join Date: Dec 2010
For my understanding. They will make it also in the export camaros like mine.
For all other problems it will ne no possible to make some guarantee works, but for the key gm says its ok? I prefere some change of my supercharger, which make some noises. |
06-14-2014, 12:26 PM | #734 |
Drives: 2014 2LT/RS Ashen Gray Metallic Join Date: Nov 2011
How about this issue, separate from the key fob thing:
I was just ready to pull the trigger on a 2014 2LT as an upgrade to my 2012 1LT. GM is running $2500 in consumer rebates, as well as my dealer running a $2000 discount from MSRP...a real killer deal coupled with the upside trade in value I have with my 2012. However, the rebates end June 30th. Have no idea how long the sales hold will be, so the rebates could expire before the hold is removed. The least GM can do is extend the rebates for the length of the sales hold....but who knows how they will address this and I don't hear anyone else commenting on this issue which is far more important to me than the key fob stupidity. While I understand why the sales hold was done, how about the option of me signing either a waver form that I hold GM harmless if I have a key fob malfunction, or I sign an agreement that I promise to bring the car in for the replacement key/fob recall? This makes much more sense to me, but then again, this is GM we are talking about. Oh, and about the key fob issue....in the almost 3 years I have had my 2012, I have NEVER touched the key fob with my knee, and never thought that there was any problem with the possibility of hitting the fob and shutting off the engine.... |
06-14-2014, 01:24 PM | #735 |
ACE5
Drives: 2010 2SS/RS LS3 Join Date: Sep 2009
Right where it's supposed to be.
SIM 2SS/RS LS3, Vararam, RX Catch Can, SOLO HF Cats, Flowmaster AT Catback, Skip-Shift Eliminator. 404HP/414TQ
06-14-2014, 01:30 PM | #736 |
ACE5
I'm not sure how I did it but I did. All I know is, I reached for the radio, probably had my hand on the bottom of the wheel, went underneath it and brushed my keys. All thats on my key fob is my house key and a few of those small plastic barcode store things.
06-14-2014, 01:31 PM | #737 |
Drives: 2011 Camaro 2LT, 68 Camaro RS Join Date: May 2010
So I just took my car out and at both 35 and 55 mph...turned it off. No loss of steering, no loss of braking power. In fact, I wasn't even sure the car was off. I had to check the gauges. Maybe this is why people are having issues? Otherwise, I can't see any way this is causing crashes.
2011 Black/Inferno 2LT. Inferno Brembos, MRT 2.0, Vararam, BBK LTs, RX Catch Can, VMAX ICE-olator, VMAX P/P Throttle Body, Monster clutch, MGW Shifter, OverKill Tuned.
06-14-2014, 01:40 PM | #738 | |
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be |
06-14-2014, 01:48 PM | #739 |
Drives: 2014 2SS 1LE Join Date: Mar 2014
Dammit, I checked the law and 49 USC Section 30120 means that they can't deliever until the defect has been corrected. I don't see any loopholes to this.
06-14-2014, 02:03 PM | #740 |
Drives: 2011 Dodge Charger Join Date: Apr 2009
Most of them were merged/moved to another section. I imagine this one will be too.
2011 Dodge Charger
06-14-2014, 02:11 PM | #741 |
Drives: 2021 2SS 1le Shock Join Date: Feb 2011
Read a brief article mentioned possiblly replacing the ingintion switch spring with a stronger spring. The separate key FOB is also possible.
Dealer has a hold on my new 1le, even though bought, and paid for, until the recall is fixed and my auto insurance will cover and damages while it sits there waiting for the fix. Frustraion.....
A10, Navigation, Sunroof, Illuminated bow tie, 30% tint, GM Splash guards, GM Strut brace, GM CAI, Illuminated foot wells, Wicker bill, BLK GM Camaro fender badge, GM Fuel door w/ Carbon fiber inserts.
06-14-2014, 02:14 PM | #742 |
Drives: Honda. Camaro in the future. Join Date: Apr 2014
Blame the media and lawyers for a poorly designed ignition switch... Not a word on chevy or the engineers? Wow.
Tags |
2014, camaro, new camaro, question, recall |
