#7351 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Really Slow Join Date: Apr 2010
#7352 |
the pictures I posted are of a boost gauge, but they do make afr
#7353 |
Emerald Coast Camaros
Drives: 2010 Camaro 2LT/RS M6 Join Date: Nov 2009
#7354 |
$275 for that.
#7355 |
#7356 | |
it comes with a plate, to cover the wiring ![]() not sure how you route the wiring though. i'm assuming down the steering column, under the dash, and then into the engine bay area.
#7357 |
I believe they are a vendor, so maybe you can get a discount, if you pm them.
#7358 |
#7359 |
so, I guess tracy will be at fest. lol keep us posted on what's going on!!!
#7360 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Mustang 5.0 Join Date: Dec 2012
Ive learned that our cars make more HP and tq then seen on the dyno. I know this has been said but our knock sensors pull back alot of time and with headers, a axelback, etc all create more vibrations that our hypersensitve sensors pick up. I have done a couple different dynos... one says 250, one 255, one even 281, and another even higher at a cold start after leaving off for over 24 hours to say about 291. Now I look at my 1/4 mile times and i see that how can a 250 hp car, if dyno was so correct, can run a 13.8. its timing thats pulled and of course heat soak may effect it significantly too.
now if im wrong at anything correct me. Also the vararam sucks on the dyno. Not sure why but they do, on the track is a different story. On the same day i gained .4 on the 1/4 mile with just a vararam added. It works.
Performance Mods: Vararam Intake, MRTv2.0 exhaust, Elite Engineering CC, Vmax Black Iceolator, Vmax Ported TB, OBX LT Headers w/ no CATS, LMR Tune
Visual mods: Eagle Eyes w/5k hids, Custom Hood Spears, Heritage Grille, Stage 2 LED Dome lights,Transformer Emblems, PD Bezels, 19in Chevy rims with pirellis, Blue painted calipers, GM GFX Front Splitter, 35/20 % Tint, TailLight Tint(charcoal) 1/4 Mile: 13.65 sec @ 102.53 mph R.I.P. |
#7361 |
yes, 1/4 time is the true measure of your car. I wouldn't worry about dyno numbers so much.
#7362 |
Looks like they only make the bracket for two gauges while I only need one though. I will keep them in mind as I get closer to doing that. And I wonder if Tracy is actually gonna go the fest
#7363 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
#7364 |
I would contact ADM, because i'm fairly sure they come with those brackets for the single gauge. I think they offer the dual gauge bracket separate because how will they know to send you a bracket with 2 holes cut out...
