Old 07-13-2020, 05:28 PM   #701
MackSteelPrivateEye
Originally Posted by Pro-2A View Post
Yup. Get that Catch-Can NOW! Your 8k mile engine in ingesting that garbage and whatever octane fuel you're burning is being reduced substantially because oil doesn't burn! Not to mention it's coating the stems of your valves.
Get a good one and mount it as far from the engine as possible; no, not near the exhaust manifolds either.
Not sure why some blow oil and some don't. Mine was totally dry when I changed mine. No CC needed on mine.
Old 07-17-2020, 12:57 PM   #702
LeadFootDoc
Average Joe
LeadFootDoc's Avatar
Drives: 2018 Camaro 1SS
So mine got shipped yesterday. Should he here in a few days.
Question about the re-learning process. Can Mike or someone explain to me the necessity of the limp mode test? Thanks
LeadFootDoc is offline   Reply With Quote
Old 07-17-2020, 02:02 PM   #703
Mike@SolerPerformanceLLC
Mike@SolerPerformanceLLC's Avatar
Drives: 2015 Corvette Stingray
Thank you very much! Not strictly necessary, but it is good to know that the TB will perform all its functions. Most modified TB's, if not all, come w/o instructions or testing, we wanted to have a complete set of instructions for those who want to do a complete test. It is really up to you.
Tiffany,
Soler Performance LLC,
support@solerengineering.com
www.solerengineering.com
(251) 468-9786
Mike@SolerPerformanceLLC is offline   Reply With Quote
Old 07-18-2020, 07:04 PM   #704
LeadFootDoc
Average Joe
Got it this afternoon and installed it.came with detailed instructions. So far, I did the idle (it’s stable at around 600rpm for my manual) and the gradual/progressive acceleration to 4k rpm. No kinks so far. Will start doing the normal driving process of gradual/progressive acceleration and deceleration process in different gears. 5-10 driving cycles for a total of around ~100miles or so.
Please let me know if I’m doing this right and not missing any crucial steps. Oh by the way, no check engine light as of now.....
Cheers
Old 07-18-2020, 07:37 PM   #705
HCI2000SS
HCI2000SS's Avatar
Drives: 2018 Camaro V6/RS
Cheers
This is exactly how I did it with mine. About 500 miles later all is still well
HCI2000SS is offline   Reply With Quote
Old 08-01-2020, 11:28 PM   #706
Kirewark
Drives: 2016 Camaro SS A8
Received my Soler on Friday, installing it tomorrow morning. I ordered with the option of no etching/branding on the blade or the outside of the TB. That is an awesome option - Helps keep things stealth and lowers the chance that I screw myself out of any future warranty work. Comparing the TB to the stock one the machining looks really nice. I'm excited to see how it goes.
FYI for those who change their TB: I removed the four bolts and flipped the TB upside down to get at that gray clip. It pops out if you push the gray clip toward the connector end with a flat blade screwdriver. After that the connector pulls right out. I have seen posts and videos from people saying they had to break the gray clip to unplug the TB.
Kirewark is offline   Reply With Quote
Old 08-24-2020, 01:38 PM   #707
JerseySS1le
Drives: 2018 SS 1LE
Installed mine a week ago. The difference in the car is amazing. I rarely drove my SS 1LE on the road, saving it for the track, because it was so difficult to drive smoothly. The Soler has transformed the car. I am enjoying driving it with RM off. I am looking forward to seeing the difference on track. The surging is gone. I can't believe such a simple upgrade has made such a big difference. Well done Soler.
JerseySS1le is offline   Reply With Quote
Old 08-28-2021, 04:03 PM   #708
18SS1LE
Drives: Black 2021 ZLE 10AT
about to order one, just want to make sure this (https://www.solerengineering.com/gen...ors/se8223-080) is the correct one for zl1 1le A10?
18SS1LE is offline   Reply With Quote
Old 08-28-2021, 04:18 PM   #709
Yes, this is the one for all stock LT4 applications.
Old 08-28-2021, 07:55 PM   #710
18SS1LE
appreciate your help man!
Old 10-31-2021, 10:43 AM   #711
donniedarko
Drives: 2021 LT1 A10 RS
Just ordered new TB to compliment my controller. I elected to buy non engraved, non refurb unit. Excited. Thk you : )
donniedarko is offline   Reply With Quote
Old 11-16-2021, 02:47 PM   #712
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
any 112mm work?
Old 12-18-2021, 01:15 PM   #713
any 112mm work?
Not yet, but really tempted to go for it.
Tiffany,
(251) 468-9786
Old 03-06-2022, 05:26 PM   #714
SSlow6
SSlow6's Avatar
Drives: '11 BMW 328i, '22 2SS 1LE
Any reason not to install while still breaking in the engine? Does the relearn procedure require high revs?
2022 2SS 1LE M6 Wild Cherry
01/22/2022 - 1100
04/16/2022 - 6000
SSlow6 is offline   Reply With Quote
