Old 09-18-2019, 02:02 PM   #701
NeverDie
Drives: 2017 Camaro SS 1LE
Originally Posted by samurai View Post
Sorry but you are talking absolutely bs. The Camaro SS runs stock 290 km/h which is 180 mp/h. I tested it myself on german Autobahn. But you feel that this is still an electronic limit and the car would be capable of even higher speeds.
I'm quoting the manufacturer. The people who design, engineer, and build these products. What you see *indicated* on the dash isn't necessarily the speed you are going (but now I'm sure you totally had GPS or whatever lol). And yes, the limiters do have some slack. The 1LE has a 175 MPH top speed as well.
Nothing I've said to either of you is BS, all of it is easily verifiable using your own due diligence to do even just a cursory amount of research before you go speaking out of turn on something where you're so under educated.
NeverDie is offline   Reply With Quote
Old 09-18-2019, 02:27 PM   #702
Wyzz Kydd
Drives: 2018 Camaro SS1 1LE
Originally Posted by 3.8TransAM View Post
Here is what I know and it makes me laugh. If I put my 89 TTA back to stock I would embarrass all current Camaros minus the ZL1 if we are talking top speed only.
I don't think so.
Car and Driver:
1989 Turbo Trans Am 0-60 4.6 seconds, 1/4 mile 13.4 seconds @ 101 mph, top speed 153 mph.
http://www.gtasourcepage.com/8920thTACDReview.html
Car and Driver
2019 Camaro SS 1LE 0-60 4.1 seconds, 1/4 mile 12.4 seconds @116 mph, top speed 165 mph
https://www.caranddriver.com/reviews...d-test-review/
Wyzz Kydd is offline   Reply With Quote
Old 09-18-2019, 02:36 PM   #703
6spdhyperblue
Drives: 2SS 1LE
the 89 tta while impressive for its time and still is a good collector got one-upped a long time ago by the ls1 4th gen.
The auto 6gen is running 12.0-11.9s stock. no comparison
Old 09-18-2019, 02:39 PM   #704
3.8TransAM
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula
Originally Posted by NeverDie View Post
The drag coefficient of the 6th generation camaro is .35 for the SS.
The drag coefficient for the 3.8 TTA is .32.
So this isn't a huge gap, and .35 is hardly a barn door. Car and Driver tested the TTA at 162MPH, which is below the speed limiter of the 6th gen SS and well below the 175mph top speed of the SS 1LE.
So no, not a single lie... not on my end. It's best to know what you're actually talking about before calling someone a liar, lest you become one yourself!
Still a barn door nose considering it's 30 years later. TTA does far higher than 162 or the other quoted 153. It will do 170s. GN would do nearly 160 with true barn door aero and considerably less power. I was verified by a second car in the upper 160s in my own when it was stock, still had pedal left.
I said I had to eat crow as I found the road tests for the new Camaro. No need to still be butt hurt over it.
3.8TransAM is offline   Reply With Quote
Old 09-18-2019, 02:39 PM   #705
s346k
s346k's Avatar
Drives: like an old lady
i’m surprised the 3rd gen didn’t run out of gas or overheat before achieving 130 mph
Old 09-18-2019, 02:45 PM   #706
3.8TransAM
The cars get a bad rap for no real reason. Maybe some of the early to mid 80s deserved it but the late late 80's thru 92 actually did very well. I have prolly 200k on a few and I totaled one set of injectors, one fuel pump and one alternator as actual failures on mine when still stock. The only low mileage issue was on my 91 GTA I bought from Provo with 19k on it. Had been stored a long time and I think the injector cleaner killed them off.
All have been buried more than once. All have been to the strip multiple times and a couple even road coursed a little way back when.
For shits and giggles, a TTAs boost gauge will start quivering at a 100mph, 135mph is about 6 psi burying the speedo which is marked to 150 is about 8-9 psi. You have a lot of pedal left still.
Old 01-31-2020, 11:28 AM   #707
Darth Vader
Drives: chevrolet camaro 2ss
when and where is Camaro Fest this year like to see 2020 SS there?
Darth Vader is offline   Reply With Quote
Old 01-31-2020, 11:32 AM   #708
Martinjlm
Retired fr GM + SP Global
Martinjlm's Avatar
Welcome to Camaro6. Hope to see you in Bowling Green KY in July.
Everything you need to know about CamaroFest is in the link below.
https://www.camaro6.com/forums/forumdisplay.php?f=315
Old 01-31-2020, 11:41 AM   #709
Darth Vader
thank for the info on Camaro Fest I just recently bought a used 2016 2SS Cajun Red I had a 2010 SS but I never made Camaro Fest going to try to make it this year.
