View Poll Results: Who has experienced an oil pump failure?
2016 or earlier 25 14.97%
2017 57 34.13%
2018 77 46.11%
2019 3 1.80%
2020 4 2.40%
2021 1 0.60%
Voters: 167. You may not vote on this poll
Old 04-06-2021, 06:35 AM   #701
Tricksta
Tricksta's Avatar
Drives: 2018 ZL1 A10
They replaced the oil pump again, then had to replace a sensor. They say it is making pressure and ready for pickup this morning some time.
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust
Tricksta is offline   Reply With Quote
Old 04-07-2021, 06:40 AM   #702
Tricksta
Tricksta's Avatar
Got the car back yesterday. OVERALL it is looking good, but I am now hearing a noise sounding like rattling(Hoping it is just a pulley making noise), and the dealership put a gouge in my driver side skirt from their hoist.. Will be going back Monday to address both issues.
Modifications
Old 04-07-2021, 07:57 AM   #703
L78toLT1
L78toLT1's Avatar
[QUOTE=Revalot;10983582]
Originally Posted by Tricksta View Post
They said the replacement pump was faulty, waiting on parts again, should all be in by tomorrow.
This statement here above is very disheartening , when there is a part failure on the engine, and the replacement part is bad also, it makes you wonder what GM is thinking by bidding on a part from a supplier that has low quality in workmanship.
A 30k-70k car should have a parts good enough for the automobile to be paid for before needing repairs.
I retired from the state of Texas, most states like automotive companies bid on parts/contracts, needless to say the lower price bidders get the job !
Me and my family drive mostly toyota's for every day routines, they cost more, but you can get 3 times the life out of one.
I don't know that the oil pump failures are a result of a quality issue. I suspect the design of the pump is the problem. All seem to fail when the outer race cracks at the pivot point. This point is obviously a stress riser. The area of the cross section in this region does not appear to be adequate.
I'm a mechanical engineer with nearly forty year's experience in aerospace. I have seen quality take the hit for countless design issues over the years.
A good automotive analogy is the Vega, by nearly all accounts a total p.o.s. People squealed about the poor quality. While quality may have played a role, a Vega assembled from parts that were all dead nuts to their respective engineering nominal configuration i.e. 'perfect' quality, would still be a piece of crap.
If quality were to blame for pump failures, gm would beat up on the supplier. Since they're continually rolling the part number, they are apparently tweaking the part design.
Baby Blue
Old 04-14-2021, 01:17 PM   #704
GunMetalGrey
GunMetalGrey's Avatar
Drives: 2018 ZL1 (SOLD) 992 GT3 (current)
Add me to the list of failed oil pumps!
I'm trying to get the dealership to convince me that all of the broken fragmented metal pieces from the oil pump are accounted for.
Ordered a new pump from Katech so it doesn’t fail while on the track.
https://shop.katechengines.com/produ...sump-oil-pump/
Name:  Broken Oil Pump.jpg
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 04-14-2021, 01:59 PM   #705
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Haha
You're asking dumb people to play God. It doesn't work.
ZX-10R is offline   Reply With Quote
Old 04-14-2021, 02:17 PM   #706
GunMetalGrey
Originally Posted by ZX-10R View Post
Haha
So in order words I should be demanding a new engine.
Old 04-14-2021, 03:41 PM   #707
SSallday
SSallday's Avatar
Drives: ‘18 ZL1 / ‘22 ZLE
Damn it never ends. If you call up GM and complain they might give you an accessory voucher. I received a $500 voucher after complaining about my supercharger. It’s the least they could do.
SSallday is offline   Reply With Quote
Old 04-14-2021, 03:51 PM   #708
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Attachment 1064864
What’s your production date?
pauly1119 is offline   Reply With Quote
Old 04-14-2021, 04:39 PM   #709
GunMetalGrey
Not sure exactly, it's in the shop right now so can't find VIN, received the car May/June 2018
Old 04-14-2021, 06:16 PM   #710
Akura
Akura's Avatar
Drives: ´18 ZL1 A10 Red Hot 😍
Symptons before the fail?
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
Akura is offline   Reply With Quote
Old 04-14-2021, 08:16 PM   #711
collinms
Drives: 2017 ZL1 A10 Summit White
Your oil pressure will drop to around 19 at hot idle. Mine was doing that for about a month before it happened. Some people say that they saw their oil pressure go full max on the guage at full throttle as well.
collinms is offline   Reply With Quote
Old 04-15-2021, 01:25 PM   #712
GunMetalGrey
Haha
The dealership told me that as soon as the pump fails there is no sucking or pushing and therefore no metal fragments should have left the pump... they also say there is a screen after the pump that prevents any significant sized metal pieces from making it by. They checked the oil pan for any signs of metal and found nothing.
Old 04-15-2021, 01:26 PM   #713
GunMetalGrey
Check engine light went off and it said "reduced power mode" then about 30 seconds later it said "low oil pressure shut off engine"
I did not check the oil pressure when the check engine light went off and it said "reduced power mode".
Old 04-15-2021, 02:11 PM   #714
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
The oil goes from the pump through the crank, and straight into your main and rod bearings. I hate to say it but I don't see how fragments like this don't do some damage, and other mfrs would have recalled all ZL1s from the defective pump period (there aren't that many) and replaced the pumps.
They owe all "non-failed pump" affected owners a preventative pump replacement, and all owners who had a failure a 1) new motor or at least 2) full top-to-bottom engine inspection, oil system flush, new oil cooler, lines, etc. and bearings replacement including cam bearings and, new crank or cam if needed.
Probably stuff I'm missing, I'm not an expert that's my .02
SFV1LE is offline   Reply With Quote
