#701 |
I used to be Dragoneye...
If I understand correctly, the hood vents are a dealer-installed LPO option...not model/package specific...so I imagine you would be able to get one of whatever color vents they offer.
#702 |
![]() Drives: C3 Join Date: Feb 2016
Im also not a huge fan of the totally black wrapped hood. I may remove, and color match it to the body color if needed along with the vents. Then lay out my own center stripe on the hood only, in a color similar to carbon flash like my C7 had.
Im either getting a white car or a blue one, have not decided yet. Cheers Dale |
#703 |
![]() Drives: 98 SS Join Date: May 2015
Will the 1LE come with the new 6 speed from the ZL1? You don't need double overdrives for a track car. I don't currently own a Camaro, but I did own a 93SS & 98SS. Both 6 speeds, never saw a use for double overdrive. Looking to buy another Camaro this year and I really want the 1LE
#704 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
1-3 are underdrive, 4th is 1:1 and 5-6 are overdrive.
#705 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
#706 |
They alluded to this, and haven't advertised anything from a differing transmission to even different ratios (which you'd think would be substantial information for a car designed for track duty)
#707 |
Maybe there is room for a Z/28?
Base 1LE/ with High winding Naturally aspirated LT? ZL1 front clip,brakes and the new 6 speed 305 on all four corners Rear seat delete Get the weight to around 3400 |
#708 |
So far, I haven't seen anything to indicate the 6th gen 1LE has a different trans than the SS.
#709 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Wife's 14' IS 250 Join Date: Mar 2014
It wouldn't be considered a "SS", I think too many wish for a diff type of Camaro.. But at the end of the day it remains as an "option" on a Camaro SS. Sent from my iPhone using Tapatalk
-11% tint all around Ordered • 2/06/16 Built on • 3/22/16 Adopted • 4/07/16 Sold on 2/05/16: 2014 Camaro SW L99, 2SS, RS, NAV, Inferno Orange Interior: -Borla ATAK catback -Range AFM delete -15% tint all around -Red LED interior bulbs -55k white Cree LED fogs -License plate LED bulb swap -12" Sub Kit, BA amp swap -Oracle ghosted LED sidemarkers |
#710 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
what ratios are better than these? 4 genfbody/C6Z/5th gen 1LE. seems like the combo to have?
the LT1 torque curve, weight difference, and shorter tire should make up for the 3.90 rear aswell, imo |
#711 | |
The 5th gen 1LE has a different trans than the standard SS. Most people know the 1LE is an option package. Instead of typing SS 1LE every time, I just shorten it to 1LE and most people seem to know what I mean.
#712 | |
Dodges all the cones
Drives: Soon Join Date: Sep 2015
Also, what do you mean by "The 5th gen 1LE has a different trans than the standard 1LE"? Did you mean "than the standard SS"? --kC |
#713 | |
Yes, I meant standard SS.
#714 |
Technically 5th gen SS and SS 1LE have the same transmission, the difference is the gear ratios and rear 3.91.
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. |
| Tags |
| 2016 camaro, 2016 camaro 1le, 2017 camaro, 2017 camaro 1le, 6th gen camaro 1le, camaro 1le, camaro 1le 6th gen, camaro forum, camaro forums |
