Old 11-14-2025, 07:45 PM   #687
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
The way you’re building this car, you gonna go from mid-10’s directly to the 8’s…!
Old 11-15-2025, 08:04 AM   #688
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - All Bolt On's
Well you pointed out the problem with 8's ! If with me driving it, and I can get quick like that! I might just have to figure out how to run no quicker than a 9.0000
2023 ZL1 A10-Stainless Works 2" Long Tubes & Legend NPP Axle Back•GESI UHO 4.5" CATs•RF BigGulp•Kong 103mm & X-Ported Blower•Griptech 2.30" Upper•ATI Super Damper w/9.45" Lower•THPSI Port Injection w/875cc Injectors•FI Interchillers Stage 2•Brisk RR14S Plugs•Granatelli Malevolent Coils•Katech Low Profile Billet Valve Covers•Katech Duel Fuel Pump•MM Wild 1000HP•DSX Flex Fuel Kit•DSX Billet Lid•DMS 2gal Fender Tank•BMR Cradle Lockout•Weld Solana 18x8 Fronts/17x10 Beadlocks MT ET ST R's•Unlocked TCM•E85=785rwhp/691rwtq +21psi | 1/4=10.5005 @134.21 60ft=1.6182, 1/8=6.8373 @106.11
Old 11-15-2025, 08:15 AM   #689
Joshinator99
Moderator
Too funny, I have the same issue… I need a driver mod haha! I don’t race often enough to get good at it. Plus I make changes every winter so it takes me a number of times out to get the car squared away.
Hopefully your track is friendly and will give you some leeway. Start with some 1/8 mile runs until you get comfortable with the cars new setup for sure. I highly recommend Smoothboost so you can dial the cars power down for some shakedown runs (or street use).
Old 11-17-2025, 11:40 AM   #690
2023_ZL1-AUTO
Update: A few new photos from Mike ! It's looking sweet!
Old 11-17-2025, 12:20 PM   #691
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
So Damn Sexy.... you should have put a NSFW warning on those pics
Old 11-17-2025, 01:21 PM   #692
Old 11-19-2025, 07:36 AM   #693
2023_ZL1-AUTO
Update: The build is moving a long great! Looks like the engine and trans is going back in very soon! One thing that stands out, is those beautiful red BMR Motor Mounts! Gabe, thanks for making that suggestion! Alex, Katech's media guy let me know he has tons of pics of the build and he's putting together a time lapse video! That's great! A big thanks to Mike and Alex and everyone for making that happen!
Old 11-19-2025, 09:32 AM   #694
2023_ZL1-AUTO
Update: A few more photos of the progress! The LT5 Tensioner and 10-Rib Pulley upgrade kit we got from Gabe at Griffin Motorsports looks totally BAD AZZ !
Old 11-20-2025, 09:49 AM   #695
2023_ZL1-AUTO
Update: Fuel tank tapped with the Fragola Fuel tank fitting for the DSX Aux Pump!
Old 11-20-2025, 11:39 AM   #696
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
If you have to tap a tank, that's how you should do it. Keep that baby 1/4 full or above just to be safe, though!
Looking good, Scott!!
Mods being installed-
Old 11-20-2025, 11:50 AM   #697
ZL1_1LE
Drives: Camaro ZL1
Why tap a tank? Isn't there other solutions fueling wise where you don't need to so you don't have to worry about things like that?
ZL1_1LE is offline   Reply With Quote
Old 11-20-2025, 12:04 PM   #698
2023_ZL1-AUTO
I could have replaced all the other fuel system upgrades I've done. Installed a Fore Innovations Triple Pump. But that's way labor intensive and the cost would probably be 3x the cost of tapping the tank and using the DSX Aux Fuel Pump ?
Old 11-20-2025, 12:05 PM   #699
ZL1_1LE
Drives: Camaro ZL1
Fair enough, didn't know if you were going full revision of what you already had accomplished with your previous build or if you were going to "build" off of what you already had. Good idea!
Old 11-20-2025, 06:57 PM   #700
2023_ZL1-AUTO
Update: Drag wing showed up and it's very nice. Very well packed, very well make and seems pretty straight forward. It even came with the drill bits needed! Way to go Accelerated Racing Solutions! Thanks Tiana !!
