#687 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Hopefully Alpha 2 allows a tad bit more cabin space, without adding lots of weight.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
#688 | ||
Drives: Looking Join Date: Jul 2017
#689 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 GT350 Join Date: Jan 2011
We will find out how much of a difference tire/wheel package makes when the next H2H between the 1LE and PP2 takes place. If the GT suddenly pulls even then so much for the superior chassis on the 1LE, the advantage was tires over the PP1. If the GT only gains a little then we will have to say the 1LE chassis is indeed superior regardless of tire.
2019 GT350 RR
2013 Boss Mustang 2012 SRT Challenger 392 auto 12:40s 112 stock 2012 Ford Mustang 5.0. Brembo, 3:73s 2010 SS, LS3, Cammed, LTs, 12:20s 2004 Redfire Cobra, Pullied & Tuned 1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot |
#690 | ||
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
#691 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 21 Bronco Join Date: Jun 2012
Even if the PP2 pulls the GT even with the 1LE, I would stillsay the alpha chassis is superior to the S550
#692 | |
I'm curious on your reasoning. |
#693 |
https://blog.caranddriver.com/ford-m...ressed-we-are/
Don't forget, even the GT350TP weighs less than a GT PP1. PP2 is going to add more weight. So yes there are a lot of things done to save weight and change the setup of the GT350 vs the GT. Unlike the SS 1LE, which is tires, some aero bits, brakes, different MRC tune, and eLSD.
#694 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Current Camaro-less Join Date: Jul 2014
#695 |
1. It is lighter than the S550
2. Despite being down on power the 1LE appears it would be right on the heels of the 350 3. Even with the super Pilot Cup 2 tires, I still don't expect the GTPP2 to edge out the 1LE. Maybe be even with it or at least competitive That to me has to be combo of chassis and suspension tuning. So either GM's people are that much better than Fords or the Alpha chassis is just better |
#696 |
Really? That sounds like a dealership visit is in order. You made me curious to see how it was done differently. Is the trunk opening any better too? If so, man...that would have really made the car perfect.
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor |
#697 |
![]() Drives: 2017 Camaro Join Date: Nov 2016
A 4.10 rear end option would make the manual SS Camaro even better.
#698 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Yes, I bought my 1SS specifically for a daily driver and need to use the back seat often for my two kids (short trips in town only). The ATS seems to have a few more inches of legroom, which makes a huge difference!
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
#699 | |||
As for the weight difference, that wasn’t done with chassis…but rather lighter weight suspension components as well as a carbon fiber front bumper support. Fundamentally, the chassis (in both cases) are pretty much the same. Quote:
You don’t realize just how good the stock SS1le tires are, do you? They may not be up to sport cup2 level…but by all accounts they are quite a fantastic offering. So to sum it up, even if the PP2 paces or edges out the 1LE…the 1LE chassis is better because the 1LE is on the heels of the GT350? What? And you are saying the chassis is better not based off of data, but because you don’t think the PP2 will edge out the 1LE? Suspension tuning is where it’s all about. Both chassis are extremely rigid, but the 1LE has the best overall suspension for the track (VS the GT). That is why they are offering the PP2. Stiffer springs, heavier sway bars, wider, more track oriented tires, stiffer bushings, unique stability tuning, more aero bits etc. |
#700 | |
Also when you cut weight on a chassis, it will definitely make it seem much better (i.e. Z/28 and the comments made earlier about R to non-R). A GT PP2 is not a GT350TP without the 5.2L. Because I don't recall Ford making a claim that they changed 90% of the suspension components on the PP2 like they did with the GT350. I don't look at it so much as the S550 is so inferior to the Alpha, but Ford can't make the S550 do what the Alpha can do at the same price point. Where is it mentioned that the 1LE had chassis improvements?
