Old 06-04-2024, 01:34 PM   #57
Cotton31
Cotton31's Avatar
Drives: 2010 camaro ss
I pull the starter relay out all the time
Cotton31 is offline   Reply With Quote
Old 06-04-2024, 03:09 PM   #58
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - Beast Build
Reading all of this is enough to have me add some extra protection against my ZL1 being stolen from my garage. Thus, I am installing two of the below parking bollards in my garage. I'm installing one at the driver’s door and one in the middle rear bumper. (I park my car against the right-side garage wall so close you can’t really open the door and get in the car from that side)
Also, since getting my ZL1 a year and a half ago. I've installed two Z-Wave devices in my garage. One is an outlet and the other is a light switch. This helps against easily opening my garage door to back the car out. The outlet is where my garage door opener is plugged into. The outlet only has power (can't be opened or closed) when I use my Samsung SmartThings app to open/close the garage door. I also don't have a wall mounted manual push button opener. The light switch is for a large electric magnetic door lock. This is hooked to a light switch for on/off to activate or de-activate the electric magnetic lock. It can be done either manually or via the Samsung SmartThings app. When the lock is activated, it's impossible to even budge the door up, let a-lone actually open the door. All this uses scripts in the Samsung SmartThings apps. So really, it's as simple as pushing the app icon to open or close the garage door and all other things process in the script accordingly.
I've always had a full AT&T security system for my detached garage that links to the house security system since getting my car. Adding to that, I have a Ring camera in my garage with motion detection. I'm purposely leaving out a lot of other details since this is on a public forum! But enough I feel is in the way of a thief not know all this to be able to get my car out of my garage before my local police have time to show up. My city is only 2 square miles in size, but we have a full police department and they are literally two blocks from my house. Also, I have a work truck my son uses that's always parked behind my ZL1 unless he's doing a pressure washing job.
I hope that would be enough for whom ever tried to just move on!
LOCKING TOP LOCK HIGH SECURITY SERIES [TL1004HS] $1,007/each and $154 shipping
"Top Lock Bollard – High Security version, with internal dead bolt, locked in place with padlock (US Patents # 7,472,891 & 7,722,285 Canadian Patent 2,623,426). 36" tall 4.5” OD .237 wall 36” tall. Hot dipped 12” tall “Heavy Traffic” galvanized ground sleeve with welded in place stop pins, and hot dipped galvanized ground sleeve plug. Post weight 40 lbs. Color: Safety Yellow." I bought (w) at $1,007/each and $154 shipping. I might be over kill, but my ZL1 at this point would be near impossible to replace!
https://www.trafficguard.net/securit...eries-tl1004hs
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 06-04-2024, 08:31 PM   #59
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
Originally Posted by dfxrte View Post
can't start until the code is put in. installer may have botched the install or it wasn't a manual
source: i have one
Thanks DFXRTE. I do know that his is a manual transmission. The installer tried two different IGLA units and even updated the firmware to try and get it to work. But, the Z would start like normal, but would stall out if you tried to drive away then hit the brake. They spent two full days trying to figure out how to change the programming to “not start” until the code was entered. They basically succumbed to the fact that they couldn’t do it and the decision was made to just remove it. The whole idea was to not let the engine start until the code was entered, but that didn’t work out. It’s a HUGE bummer as this system looks bulletproof, even for advanced thieves. And yes, I know anything is steal able, no sense in rehashing that again. Thanks again
SHE'Z 18 is offline   Reply With Quote
Old 06-05-2024, 10:12 AM   #60
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
Pricey to be sure, but an interesting option to add to the list! Now if they'd only let me drill a hole for that in front of my favorite parking spot at the office...
Old 06-13-2024, 12:31 PM   #61
LORDOBERON
Drives: chevrolet camaro
will the IGLA work with the Compustar T13 Drone or would they conflict with each other
LORDOBERON is offline   Reply With Quote
Old 06-15-2024, 01:42 AM   #62
roostere4
Drives: 1987 IROC, 2020 ZL1
You can definitely get IGLA and Compustar installed together.
Have had an IGLA installed for awhile and been debating on getting a Compustar installed too
Keep going back and forth on the Compustar install. Would love to have an alarm and notification. Especially when out and about, or on a trip, but not really so much ar home.
Not a daily driver, so between not sure if it really adds value at home, the security of IGLA, the possible battery issues for leaving the car sitting for days or even a week or two, and the duplication of factory options I'm torn on whether to pull the trigger on an install.
Do you have Compustar installed already? What's your experience like with it?
roostere4 is offline   Reply With Quote
Old 06-15-2024, 11:40 PM   #63
dfxrte
Drives: 22 ZL1 M6
jeez that is unfortunate cus the system is certainly great. IGLA installers are far and few, it definitely takes a lot of know how.
22 m6 zl1. cammed, headers, etc
https://ibb.co/qpWHXZM][img]https://i.ibb.co/NKm0Q46/zl1.jpg
dfxrte is offline   Reply With Quote
Old 06-16-2024, 12:44 AM   #64
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Multi-layer, multi-layer, multi-layer... IGLA is not some magical answer... Most thieves are extremely lazy and dumb... Throw them just a few things they were NOT expecting (layered approach (several visible mechanical layers (steering wheel club as well as a steering wheel/brake lock)) as well as several electrical layers of immobility) and they will very likely move on down the road to the next, much easier target (which will very likely not be protected at all)...
Old 06-16-2024, 06:18 PM   #65
Kubo
Drives: 2020 ZL1 1LE
Some good news this weekend, police found my car and in not too bad of shape all things considered. Now on to the next step of dealing with insurance
Kubo is offline   Reply With Quote
Old 06-16-2024, 08:11 PM   #66
discgolf01
Drives: 2018 ZL1 Convertible M6
Something else to consider: sometimes thieves "tag" a car by placing an Apple air tag on or in it, that way they can track it back to where it resides and try to steal it at their convenience. Even though it's made by Apple, there is an Android app that can scan for them and make them beep if it finds one. If you have an iPhone, I think it automatically will notify you if one is in the area (not sure, I'm an Android guy)
discgolf01 is offline   Reply With Quote
Old 06-16-2024, 08:17 PM   #67
dfxrte
Drives: 22 ZL1 M6
whatever helps people feel better more power to them. IGLA/ghost is far and wide the best immobilizer there is and provides the least inconvenience for the driver. Other than a tow truck you're not moving the car
Old 06-17-2024, 05:35 AM   #68
Broooster
Drives: Sharkskin Metallic ZL1
I'm not sure if that's a good thing or not. I guess it would depend on how attached you was to the car. Hopefully they didn't beat on it to bad.
Broooster is offline   Reply With Quote
Old 06-17-2024, 07:20 PM   #69
2SS Capt
2SS Capt's Avatar
Glad they found your car, did you have any theft deterrents in place when it was stolen? If so, do you mind sharing?
Old 06-18-2024, 07:28 AM   #70
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I got my Progressive renewal and my comp/collision went up about $140/6months, unexplained other than I think ZL1s are highly stolen these days.
