Old 02-17-2024, 05:06 PM   #57
dfxrte
Drives: 22 ZL1 M6
Originally Posted by roostere4 View Post
Keetec looks like an decent option. However I believe if you can get IGLA installed it is the better choice. Key Fobs are optional in IGLA vs required in Keetec, the convenience is nice but it is less secure. Plus IGLA can be configured for additional security depending what kind of threats you expect you might encounter.
For sure. inputting the code for each start up with IGLA will get old quick.
You can se the proximity to like 1 foot for the FOB, and just keep it in your pocket.
If I go with IGLA over the keetec rider I already know 100% i'd use a fob. My friend has it on his lexus and he lasted about 2 days using the buttons to deactivate igla.
22 m6 zl1. cammed, headers, etc
https://ibb.co/qpWHXZM][img]https://i.ibb.co/NKm0Q46/zl1.jpg
dfxrte is offline   Reply With Quote
Old 02-27-2024, 12:35 AM   #58
DFVZL1 22
Drives: 22 Chey Cam ZL1 6spd
Originally Posted by Drnick View Post
All great ideas!, but, there are other alternatives, such
As sleeping in your car with a loaded gun,that’ll “kill”two birds
With one stone,remove the perp from the gene pool
And solve the stolen car situation!
Man, I Love your approach!
DFVZL1 22 is offline   Reply With Quote
Old 02-27-2024, 10:40 AM   #59
NW-99SS
Drives: 1999 Camaro SS M6 - SBE LS1
In addition to immobilizers, you should also scan for tracking devices:
https://www.androidpolice.com/find-a...android-phone/
https://www.iphonelife.com/content/w...airtags-iphone
1999 Camaro SS 6M - SBE LS1
1994 Camaro Z28 6M - Golen 383 HT
1963 Corvette GrandSport - ZZ502 4M
2017 Denali 1500 6.2
2017 Yukon Denali 6.2
NW-99SS is offline   Reply With Quote
Old 02-27-2024, 11:08 AM   #60
LORDOBERON
Drives: chevrolet camaro
has anyone actually installed this one. it says you have to splice into the fuel control module
https://www.jordandistributors.com/c...lock-universal
LORDOBERON is offline   Reply With Quote
Old 04-04-2024, 10:59 PM   #61
JAITG
JAITG's Avatar
Drives: Camaro 2SS 1LE 6MT
Having it work properly now on mine its pretty easy. Press in clutch, hit start, let out clutch, immediately type in code when dash lights backup, watch for the indication then start.
That being said check out the Ampire Can Bus Immobilizer as a DIY solution, I wish I knew about it before I shelled out the $1300 USD for the IGLA install :(
I have the IGLA installed now though so not worth getting removed but I since now I know about Ampire for the future I will recommend and use that. It has a wide range of support too not as extensive as IGLA but pretty close.
Last edited by JAITG; 04-04-2024 at 11:00 PM. Reason: Clarification in the last sentence
JAITG is offline   Reply With Quote
Old 04-06-2024, 09:13 AM   #62
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
Hey Jaitg,
Can you elaborate on why/how the Ampire system is better than the IGLA? Thanks
SHE'Z 18 is offline   Reply With Quote
Old 04-06-2024, 10:02 PM   #63
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
I have the Keetec coming in the mail, going to use a Faraday Pouch hidden if I don’t want to carry around the the fob for some reason or another. That’s if the pouch will actually work blocking the signal.
Old 04-06-2024, 10:15 PM   #64
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
From a quick glance, it looks like the KEETEC is the same/offset to the IGLA. Are you planning to install this yourself? How much is it? Thx Calvary
Old 04-06-2024, 10:43 PM   #65
bcasurvey1
Drives: 2019 ZLE sold now 2021 ZLE
does anyone know which fuse to pull to slow anyone down from stealing our cars?
bcasurvey1 is offline   Reply With Quote
Old 04-06-2024, 11:20 PM   #66
CalgaryZL1
CalgaryZL1's Avatar
https://lockdownsecuritycanada.ca/pr...on-immobilizer
Yes, I plan on installing it myself. Disassembly will be the same procedure as changing out the start button.
Old 04-07-2024, 07:12 AM   #67
Vivid24
Vivid24's Avatar
Drives: 2024 Camaro ZL1
I pull the starter relay out of mine. It is pretty easy to access, takes less than a minute. Not super convenient but it's better than filing a stolen vehicle report.
Vivid24 is offline   Reply With Quote
Old 04-07-2024, 09:03 PM   #68
discgolf01
Drives: 2018 ZL1 Convertible M6
For what it's worth, I bought this OBD2 port off of Amazon to be a dummy and zip tied the actual port up and under the dash. It snaps in perfectly:
https://www.amazon.com/dp/B0B213F7N1...roduct_details
Fool proof? Nah. Enough for one of these thieves to get frustrated and walk away? Maybe. Mine is garaged, so figure they would have to do this in a parking lot which may mean time is of the essence to them.
discgolf01 is offline   Reply With Quote
Old 04-14-2024, 12:12 PM   #69
LORDOBERON
i'm going to have it installed this friday april 19th
Old 04-14-2024, 02:14 PM   #70
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
If someone wants it bad enough they will get it. Mine sits in my garage with a locked garage door, alarm system, 2 cameras watching the garage and on a lift with a truck parked under it. You would have to break in, avoid the cameras, remove the truck which had a 550hp 383 with Flowmaster which is as loud as my alarm first, lower the car and take it. It’s been parked like this for 5 years for no reason then I’m over protective. With all this I’m sure someone could come and take it at anytime.
pauly1119 is offline   Reply With Quote
