#57 | |
![]() ![]() ![]() Drives: 2018 ZL-1 Join Date: Jan 2018
I live in a very dusty environment, so air filtration is very important to me for engines, etc. |
#58 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
#59 |
![]() Drives: 2018 ZL1 Garnet Red A10 Join Date: Mar 2015
Agree, I have a green filter already. Interested in an intake elbow that won't have a tendency to collapse under vacuum as I increase power levels. Elite carbon is pricey but it has a filter with a big surface area and it is isolated from engine compartment heat.
2018 ZL1 Red Hot A10 (SOLD 1/21)
2001 Corvette Z06 Quicksilver Heads/Cam/Longtubes 443rwhp (SOLD 5/23) 2018 ZL1 Garnet Red A10 (SOLD 4/25) 2003 Corvette Z06 Torch Red bone stock 60k mi |
#60 | ||
#61 | |
#62 | |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
#63 | |
#64 | |
Shadow Gray '19 ZLE M6
But the quoted post from Z OH 6 seems to hit on the crux of the debate. The stock paper filter may filter out more contaminants in a lab environment (and real world too), but the cotton filter is designed to flow more air. Does that mean it also allows in more contaminants? Well, likely yes! Is that ok? All signs point to yes. I've had cotton filters on all of my cars with no issues. All of my cars have been either drag raced, autoX'd or ran on a road course. Everything is a tradeoff, a compromise. Want more air for more HP? Probably need to accept a few more contaminants. Want less contaminants? Probably need to sacrifice a few ponies.
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
#65 |
My first clean line tee’s into the throttlebody with a non-destructive quick disconnect T fitting for non-wide-open vacuum, the second one tee’s into the intake tube (ZL1 basically has a catch can of sorts that has a vacuum line hooked up to the intake tube already so the elite already has it incorporated in their intake tube) with the non-destructive T fitting as a secondary vacuum for wide-open throttle. Thanks to Garage kings in Toronto I didn’t have to modify any vacuum lines on the car, He was able to supply me these quick connect fittings for my install. And with the LT4 the Pcv valve underneath the supercharger is replaced with a bypass to divert it into the can instead of straight into the supercharger
#66 | |
#67 | |
#68 |
![]() Drives: 6th Gen LT1 Join Date: Jun 2023
This is a typical case of survivor bias.
The fact that 1st of 2nd owners of a car don't see any issues with a bad air filter before selling it at 30k miles, doesn't mean the engine didn't get dust and sand that shortened it's life. Also, if you never change the oil, and sell the car with 20k miles, you most probably won't see any issues with it. |
#69 | |
#70 | |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 - Beast Build Join Date: Dec 2022
https://www.youtube.com/@GarageKing/about Just email him and he'll send you instructions on how to purchase tee fitting.
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
