Old 08-15-2023, 04:28 PM   #57
MT-SS1LE
Drives: 2023 SS 1LE Sharkskin
Originally Posted by Laidoffsick View Post
Its not a rattle. It's a ticking sound from the fluctuating fuel pressure caused by a crimp in the fuel line during assembly. GM has know about it for several years and it's due to them having 2 different part numbers for the same fuel line. One of them is a tad too long, so when it's connected during assembly it gets bent just enough to be a problem. Not major but the sound is very irritating and you will notice a bit of hesitation when you get on the gas real hard.
I noticed my car had it from the day I took delivery of it with 2 miles on it. The dealer put it on the rack and first told me it was normal due to the high pressure fuel pump. A friend has a ZL1 one year older than mine and he never had that noise. Then I was told it was just a rattle, the fuel line rubbing against the frame. Then I was told it was an exhaust leak and it did sound like one.
Finally after getting all the managers involved at the dealership, the suddenly discovered the service advisory that GM had put out a year or two prior.
1st they sent the fuel line for an SS so we had another delay. Finally got the right part and problem solved. Total... 2 months and this is how they returned my car after the first 6 weeks of having it.
Wow, that picture is disgraceful. Any dealer that returns a $75K car back to a customer in that condition should never get repeat business. Haven't had to use my GM dealer yet, but the few times I've taken in my 10 year old Tundra for service I have to tell them NOT to wash it, because it's usually clean but they would still do it as part of their routine.
MT-SS1LE is offline   Reply With Quote
Old 08-16-2023, 06:45 AM   #58
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Is this user replaceable, i.e., you have to drain the fuel line and so forth is it an easy remove/replace because I'd spend $100 and DIY.
Old 08-16-2023, 07:08 AM   #59
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
I'm glad the issue is solved! I would make the dealer pay for a detail for your car!
! O-H !
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 08-17-2023, 09:38 AM   #60
SnakeEyeSS
SnakeEyeSS's Avatar
Drives: Camaro 2SS & ZL1
What do you all think? Add me to this list?
107 miles right now
https://youtu.be/MgegmEczEKA
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red
SnakeEyeSS is offline   Reply With Quote
Old 08-17-2023, 09:52 AM   #61
triggerjerk
Drives: 2023 Camaro ZL1
107 miles right now
Bingo. Join the club.
I noticed mine at 74 miles.
triggerjerk is offline   Reply With Quote
Old 08-17-2023, 05:43 PM   #62
SnakeEyeSS
SnakeEyeSS's Avatar
Yeah, I played yours and mine back to back and there is about 5 seconds that might as well be the same video.
Some conjecture, probably wrong because I haven't really looked into this:
Two PN's because one was for the Z06, and they started using it again on the Blackwing engines?
Old 08-17-2023, 06:20 PM   #63
SnakeEyeSS
SnakeEyeSS's Avatar
Guess what I JUST got.....
The Vehicle Quality Survey from Chevy.
Oh yes, I responded
Old 08-17-2023, 06:36 PM   #64
triggerjerk
Oh yes, I responded
Nice. But if this has been an issue since 2017 per the tsb, they probably don't care. Now if some people dropping $150k on Escalades start complaining maybe we'll get somewhere.
Old 08-17-2023, 07:31 PM   #65
SnakeEyeSS
SnakeEyeSS's Avatar
I agree, they obviously don't care if you know why but it still happens 6 years later. I don't think they would care about the Escalade either, to be honest, especially if it's only a percentage of of engines and an easy cheap fix.
I have gotten a return call from GM before, after they showed off the first 5th gen concept car and I emailed them the day it was on the news. I promised to buy a new Camaro if they built it, he said the response was so strong they made a team to go through the emails and call some of the people that actually reached out to them to gauge how serious people were.
Old 08-18-2023, 02:51 AM   #66
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
I’m glad they solved the noise, do you happen to know what the part number is for the part They actually ended up changing?
Old 08-18-2023, 08:00 AM   #67
DangerZL1
Drives: 2023 Black ZL1 Auto
You'd think after 6 years they'd have corrected the problem with the fuel lines.
Old 08-18-2023, 08:15 AM   #68
WhiteMale
Has anyone found the remove/replace maintenance procedure, step-by-step...cause I'd do this DIY, the fuel line is affordable for me.
Old 08-18-2023, 02:50 PM   #69
SoMaR
Add me to the list for this issue. The tech at the dealership let me listen to the fuel line with his stethascope...really loud ticking. I gave them the TSB and theyre gonna order the part. Just a waiting game now. Car was built 6/2023.
SoMaR is offline   Reply With Quote
Old 08-18-2023, 02:53 PM   #70
triggerjerk
Welcome to the club :(
