#57 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
The contingency races they chose seem to indicate they are going for best ax tire, but it doesn't seem like the CRS V2 is faster than Yoks or REs, so I remain skeptical on the Vitour tires, will definitely be using the REs already ordered. It would be nice to have a 315 if they can match the REs though, we'll see. It's also nice the current best tire is also the least expensive option, might be nice to keep it that way.
#58 |
![]() ![]() ![]() ![]() Drives: '94 Z28+ '15 Z/28 Join Date: Jun 2009
There's a video in the link that I posted where they tested it against the Nankang CR-S. It was faster in a few areas. I don't believe that the Nankang is as fast as the A052 or the RE-71RS though. Maybe it is on certain surfaces. I don't have any direct feedback on the Nankangs, just going by what people tell me.
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C 1980 Z28- resto-mod project 1979 Y84 Trans Am 1986 IROC-Z |
#59 | |
![]() Drives: 2019 ZL1 1LE Join Date: Sep 2010
#60 |
Some do, I've heard they're not as fast as REs or A052s.
#61 |
![]() Drives: Cadillac ATS-V Join Date: Feb 2023
2018 Cadillac ATS-V Sedan
NCM*Putnam Park*Mid-Ohio*Gingerman*Road Atlanta*Barber*Pitt Race*VIR |
#62 |
Oh? I haven't seen anyone actually test them against REs or Yoks in Lincoln. I only know of one person who has run them on the surface, didn't compare it to any other tire, but decided he didn't like it so he's selling them.
#63 |
Yeah, I'm sure data is quite limited. I trust the source but not sure there's really enough data to have much certainty. Only a couple locals have them and we only have asphalt venues, so while their results aren't fantastic it's a very different surface. We'll have a lot more data very soon though. Personally, I hope the 295/35/18 REs stay at the top of the heap for a while, they cost a lot less than CRS and A052 in larger sizes, seem to perform more consistently vs other choices, and also seem to do well on 12" rims.
#64 |
They've proven to be fast on Asphalt in >80deg temps. (2 out of the top 3 on index, against several national champions) I think they will be trash if it's cold/wet, regardless of surface.
I ran them this weekend on Asphalt and they were great, although they had some very curious characteristics. From a dead stop they don't seem to hook at all, and thrust is poor while they are spinning. Once the spinning stopped, I was able to apply full throttle in 1st gear which is unusual for my car. The Yoks and Stones both hook much better, but I can't use full throttle in 1st gear on them. Lateral grip felt similar to Yoks, but they are more direct/responsive, with a better defined limit. Nowhere near as sharp as 295/35-18 stones stretched on 12's. Far and away their most impressive asset is their ability to multitask. On Yoks if I aggressively trail brake with 3900 lbs the tires just turn to mush and give up. With these you can REALLY attack entries and exits. I'm a reasonably consistent driver, nearly always top 5 on index and my first event on the Nankang was my first overall pax win this year. I went even faster in fun runs once I figured out that they wanted a little lower pressure than Yoks. They seem like a fantastic track tire. Whether they are any good at autox for locals is going to depend on your climate. We'll find out in about a week if they're any good for "serious business" autox. I'll be running them back-to-back against Stones at the Pro Finale. |
#65 |
CR-S V2 look pretty competitive against the 71RS and A052...
https://grassrootsmotorsports.com/ar...-sportnex-crs/
#66 | |
I managed to get 18x12s on, just barely. Now we'll see if the local discount tire will mount the 295/35/18 REs for me... If I can get them mounted in time I'll be able to try them out this Saturday.
#67 |
I ran the CRS V2 at the Pro Finale against Bridgestones, went fastest on the CRS.
I did a bunch of TNT runs with both tires and it was basically a wash. In the mid-70's it took 2 runs on the 25-sec TNT course before the CRS started working. At Nationals I was running 2nd heat and the forecast was cool with rain in the morning on Friday, so I decided to use the Bridgestones for Nationals itself. In retrospect, I kinda wish I ran the CRS since I was more confident in how they felt. They feel like a slightly sharper Yokohama, which I am very familiar with. In the end, it wouldn't have made much difference. Driving errors relegated me to 3rd place, where I realistically should have had the pace for 2nd on either tire. SD card issues lost my video and data from Thursday, but here is my fastest run on Friday- (which unfortunately was my first run) https://youtu.be/hKsUVGogpg0 You can see how uneasy I am with all the little corrections. |
#68 | ||
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
I don't understand what's going on with them, but it's making me dangerously close to trying the Nankangs. I would have to hold my nose to buy tires made in China for $60 more (each) than Bridgestones, but that may be where I'm headed. It was disappointing to trophy at both tours I entered and not at Nats.
Matt Miller
2020 SS 1LE |
#69 | |
Congrats on the 3rd! Unbelievable Dave won by 1.4s. And a T4 in 2nd... I almost got a T4. It's cool Randy Pobst bought one, but I don't regret going SS 1LE. Good to hear the CRS is a viable alternative to REs, they have larger sizes but they're expensive. I'm happy with that outcome and happy to spend less on tires. Given the Tire Rack test results on tire and rim widths, could be 295s stretched on 12s is as good or better than wider tires, and you'd need to go up to 13s to make the most of 315+. I got the new REs mounted and took her for a spin, felt very direct, softer than Falken's compound for sure. There's very little clearance up front, but I think it'll work out. It's within a few mm in either direction. A local Camaro autox'er has a set of JRZ 2-way coilovers for sale I'll likely buy, I think that'll be it for a while on car setup. I'll probably come to solo nats next year, the car will be pretty competitive at that point. The driver? Maybe, I've been improving but only having 3 runs in an unfamiliar setting is tough!
#70 | |
