#57 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
Thank you capricio. I could splice into the crankcase to intake tube line and install a occ. Or Tracy Lewis sells a occ package that goes from crankcase to occ to intake manifold. You have to tap into the intake manifold. The cam cover fittings are drilled out , I guess they have a valve in them, and the lines go to the intake tube like factory. The package ads a oil fill cap that has a tube that goes to the intake tube where the factory crankcase tube went. Seems like Tacy Lewis wants the lgx to have more pressure relief. I have had oil seep out of the oil fill cap when oil was put to full on dip stick.
#58 |
Flying around Thailand
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
I think it depends on the engine. Mine was bone stock and brand new and after only 4000 miles the entire intake system was drenched. Got a MM can and after another 7000 miles pulled it apart (while currently doing Jannetty's 125 package with an interchiller) and barely a drop in the entire intake system. but have emptied the can twice.
#59 | |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
