#57 | |
![]() ![]() Drives: 2017 2SS Arctic blue fully loaded Join Date: Mar 2021
#58 |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
Michell Gyro and SME arm! Nice. I have a Michell Mycro with Moerch arm and Shelter cartridge.
Matt Miller
2020 SS 1LE |
#59 |
![]() ![]() ![]() Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
I think the BOSE stereo in my ‘21 ZL1 sounds really good. Enough bass for me. If I had a complaint it would be that the high frequencies can get a little harsh if they are turned too high in the EQ. This is due to no dedicated tweeters. That said, if you keep the highs turned down to no higher than +2, it sounds really good and can play pretty loud. I like that BOSE automatically increases the bass at low volumes. It’s the only car I’ve had that does that.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
#60 |
It's due to a basement-budget 2.5" driver being asked to do a really hard job: cover the frequency range of ~500hz-20khz. It's not up to the task, so we get seriously curtailed high frequencies and lots of distortion when driven even slightly hard. A good 2.5" driver can do it, and also reaches a little lower in frequency for a better blend with the woofers in the door.
Matt Miller
2020 SS 1LE |
#61 |
Electrical Engineer
I put a HUGE emphasis on amplifier quality. I never cheap out on the amp, usually a grand or more. I'll run budget raw drivers and play with tuning on the DSP. I've ran DSP since 1999 as well since time alignment is a must. I prefer active crossovers and dedicated 1/3 octave EQ, unique per driver.
I've been enjoying the sound of the exhaust (NPP in Track mode full-time, usually drive in Touring mode) and I am in no hurry of changing the stock stereo since I never really turn it up. Of course, I don't turn it up because it sounds awful. But if it was bugging me I would have gutted the car already. And the car has a wonderful soundtrack built-in. I don't mind the wide-band drivers in the dash corners, as that is great for imaging. I'll likely do a JL VX800/8i and VX1000/1 for amps, and Hybrid Audio or Audiofrog for speakers this time around since Hertz doesn't make a small-enough wide-band mid in their Mille series. I'd like to pull the windshield for headliner removal and at the same time modify the dash corners to accommodate a mid/tweet combo with a stock appearance. I suspect the soundstage will be a bit narrow but should have good depth and a solid center. Car will compete in IASCA SQ, possibly MECA.
1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 45k mi. @ Mar 2025 New Engine @ 22,600 mi. due to dealer confusing bad gas with a bad engine. Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
#62 |
![]() ![]() Drives: 2023 ZL1 Convertible, 1998 Z28 Join Date: Jan 2013
I went from a 2016 2ss to a 2023 ZL1, and I have to agree. The Bose setup is better in the 23 than it was in the 16.
2023 Rapid Blue ZL1 Convertible
#63 |
![]() Drives: 2002 Z28, 2023 1LT RS Redline Join Date: Sep 2022
I might be getting a Camaro with a standard stereo since the one I ordered with the Bose has no allocation for the last month and a half. Don’t know much about upgrading stereos. What would be the most effective way to increase accuracy and bass on a standard stereo using the head init that came with the car? Replace the six existing speakers, more powerful amp, and trunk mounted subwoofer?
#64 | |
Drives: Camaro SS 1LE Join Date: Aug 2018
#65 | |
Electrical Engineer
You could build this in phases also, and you will see gains immediately if you just went with a DSP 5 channel amp and sub and just reuse the factory speakers. I'd want to run the front 2.5" full active, so a bit of wiring would be needed to them. The factory speakers aren't great, but with DSP they can be as good if not better than a BOSE setup.
#66 |
![]() Drives: 2SS 1LE M6, Palisade Calligraphy Join Date: Nov 2021
Bose upgrade is probably not worth it in the Camaro. Couple of things to point out, it does not come with a slim separate subwoofer in the trunk. Front speakers take the duty as woofers and causes door panels to rattle. EQ setting is very basic and speaker quality is bottom of the barrel Bose. Best Bose system I owned was in the Audi A6 and then Cadillac CTS. Even in the Cadillac the Bose was subpar compared to the version in the Audi. The one in the Camaro is so far the worst Bose sound system that I ever owned. If you don't need the extras in the 2SS model, my advise is do not upgrade to the 2ss just for the Bose because its definitely not worth it. I also had a chance to listen to the Bose system in the C7 and C8 corvettes, they are couple of step above the version of the Camaro. Camaro definitely needs a separate woofer for the bass and better overall speakers.
#67 | |
One thing you could do differently than I did and get even more bass response: instead of the GS690s in the doors you could try the GS8ND2 in each door. That would extend the bass even more. The AF honcho, Andy Wehmeyer, has recommended that when using the GS25 as a twiddler. It wasn't available yet when I did my installation, or I might have tried it. Only downside is that they cost more than the GS690s. keep_hope_alive, I hope you start a thread on your build if you do one! If you're going to do separate mids and tweeters in the dash, then in the AF line I would think you'd want the GB25 and GB10 instead of the GS series. But I'm sure you already know that.
Matt Miller
2020 SS 1LE |
#68 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
#69 |
Going from 2016 2SS to 2023 ZL1 also mean going from a car with a sound tube and runflat tires to one without both of those noisemakers.
#70 |
