Old 10-08-2022, 07:33 PM   #57
ZO6Ted
Old badass
ZO6Ted's Avatar
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2
Nice run, King!
No kidding and how about that 60' on the street! Impressive.
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror
ZO6Ted is offline   Reply With Quote
Old 10-08-2022, 07:54 PM   #58
grampa_ss
grampa_ss's Avatar
Originally Posted by JimGnitecki View Post
If I go with the Nitto 555R2 tires on my OEM 8.5" wide rims, should I run the OEM 35 psi tire pressure for street (No dragracing and no track days), or a different psi?
Jim G
24-26 psi cold is what I'd run if you're just out screwing around, even lower if I knew I was going to see some action. Now if you were going a long drive with the family, then I'd bump it up 30-32.
Old 10-08-2022, 09:16 PM   #59
JimGnitecki
Drives: Chevrolet Camaro LT1
Thank-you, Grampa ss.
Jim G
JimGnitecki is offline   Reply With Quote
Old 10-09-2022, 08:51 AM   #60
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Nice run, King!
Thanks sir! I found some low hanging fruit in the torque request rate tables that I believe helped my 60ft. It makes the throttle more responsive in the first 40% instead of laggy then hits like a light switch.
Hey KinglT1: That 10.58 second quarter mile time is almost as quick as my 2008 Kawasaki ZX-6R MOTORCYCLE whose rev limit is 16,500 and whose weight I got down to about 395 lb before fuel !! For a CAR, 10.5 is really moving!
Jim G
Thank you! I don't have a dyno so Dragy and HPt tells me if I am going in the right direction.
Jim G
I drive normally with the 555r2's around 28-29psi and 23psi hot for dig racing.
Thanks. I am still learning some tricks to help launching on the street.
Old 10-09-2022, 09:04 AM   #61
shinysun
Drives: 2016 Camaro SS
New best today. Still a tenth off on my best 0-60 but it's making more up top. Almost trapped 137. I should be able to get a 10.4. Not easy on no prep.
Very impressive. I am having a hard time to hook on no prep. Not uner 3.6sec for 0-60. 2nd launch, 17inch nitto rii
What mode do u use? Sports or track Any difference btw them? Tcs still turned on?
shinysun is offline   Reply With Quote
Old 10-09-2022, 09:24 AM   #62
laynlo15
Drives: 2022 Lt1 A10
I run about the same pressure as King, just above where the TPMS light will kick on for low tire pressure. Usually it will kick on about 27 psi.
All kinds of trick or treat
Old 10-09-2022, 09:47 AM   #63
KingLT1
KingLT1's Avatar
Sport, competitive mode. good burn out, brake stall as high as you can get it if still on the stock stall(2600rpm), let off brake, let it roll out for a second and put it to the floor. I am 37-50% tps for the first 1.5 seconds of the run.
I found that multiplying the Torque request table X2 in gears 1-6 makes it a bit easier to manage the throttle. Also throttle response is greatly improved overall. I tried just maxing it out and it's too aggressive. You might have to play with that table to get a balance of what works best for your combo.
Old 10-09-2022, 10:43 AM   #64
JimGnitecki
T
Did you have to somehow turn off the tire psi nanny in the dash to do that?
Jim G
Old 10-09-2022, 11:06 AM   #65
JimGnitecki
KingLT1: Is "torque request" = "torque management"? No one has ever explained to me how and why this works.
Back in the "old (bad) days" in the early 2000s, GM's ECU Programming deliberately limited torque and thus power on the Corvette and SSR automatic-equipped vehicles VERY significantly in 1st and 2nd gear, as the 4L60E transmission was only rate for 350 ft lb of engine output (that spec was not publicized in the GM specs on the tranny but was there if you looked in the GM parts catalog), and the Corvette engine used in both the Corvettes and the SSR was rated at 400 ft lb then. When I supercharged my SSR, it quickly burnt up the 4L60E, and I had to get a built tranny from Phoenix Transmissions.
So how does the more modern version of torque management work?
Jim G
Old 10-09-2022, 04:09 PM   #66
grampa_ss
grampa_ss's Avatar
Jim G
Don't believe there is a tire psi nanny. just hit dismiss twice.
Old 10-09-2022, 04:14 PM   #67
grampa_ss
grampa_ss's Avatar
Which exact table is that? 9513, 9515 or ?
thanks
Old 10-09-2022, 06:04 PM   #68
KingLT1
KingLT1's Avatar
thanks
I did both Increasing tables.
Jim G
No it's not the same. The ECU system is torque based and there is torque management in several areas, but this does not that. Torque request rate effects how fast the throttle opens and closes. Driver demand requests the amount of torque, then torque request rate is how fast it's delivered vs throttle percentage.
Old 10-09-2022, 06:21 PM   #69
JimGnitecki
Ah, thank-you.
Jim G
Old 10-09-2022, 07:56 PM   #70
grampa_ss
grampa_ss's Avatar
The tables for 9513 were already maxed out....same as my stock file. 9515 is definitely not maxed out.
