Old 07-29-2022, 01:32 PM   #57
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
Originally Posted by Camaro1973 View Post
29 degrees of timing is quite a bit. What rpm is that? Also What’s the timing at e40 compared to e50? If it’s only a degree less we’re talking 10-15hp.
Your INJ pw is perfectly fine but pressure is indeed dropping .
If your IPW is that low I wouldn't be too concerned about the rail pressure dropping some jmo.... I am surprised you are running out of high side pump before injector unless the cam doesn't have a large enough fuel lobe. I agree with above that the timing Seems excessive, many NA LT1 H/C E85 setups don't run that much.
Cool. I was waiting for you guys to chime in. I will recheck the log, but I think I was at 7K (a couple hundred rpms above my target) for that advance. I don't think there was any knock. But, I am not sure (much of the log makes little sense to me). I'm running e43 right now. I will water it down a little and log a run tonight to see the difference. The cam has a 32% lobe. Ted saw the log but didn't elaborate (other than to drop the e to 40).
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper
FIC+30%
DSX Flex fuel/Low side
NW 103mm TB/Roto-Fab CAI
Monster S Series
Elite E2-X
2" TSP LT's
BMR:BK063, BK060,TCA061, UTCA060, UTCA063
Weld Beadlocks/17" NT5R2
MartinLe is offline   Reply With Quote
Old 07-29-2022, 02:03 PM   #58
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
Originally Posted by MartinLe View Post
When I spoke with Ted before I installed his Terminator Cam/2650 blower package, I want to believe he cautioned me that the cam or blower by itself would not perform well. Not saying gains wouldn't be seen, just nothing crazy.
I just finished tuning my car with Ted. You might find some of the data helpful. With E50, the car ran 29.5 degrees of timing. Low side fueling held at 70# but the high side dropped to 2400# with IPW of 5.34. The E40 pull saw my high side 2900#, low side 70+# and IPW under 5.
Ted suggested that I keep the E at 40 to be safe. The car is going on the dyno next week. I am going to have them do a pull at E40 and another at E50. I am curious to see the difference.
Your low side is still only the voltage booster?
How much boost are you seeing with that pulley combination?
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
Old 07-29-2022, 02:13 PM   #59
MartinLe
MartinLe's Avatar
Yup. Just the voltage booster. I will know the boost after tonight. I have been running JRE's channel list - and it does not show boost.
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 07-29-2022, 02:26 PM   #60
swisstyphoon
Awesome! Can't wait to try mine on E!
30% Injectors and pump is already in the car, will finish the tuning after my vacation.
If you have map and atmosphere you can just subtract the atmosphere number for boost.
2018 Camaro ZL1 A10
MPI Compound Turbo
40% over Injectors
Old 07-29-2022, 02:27 PM   #61
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Heheh. Take the map in kpa and subtract your barometric pressure from it. Then use a converter to convert kpa to psi.
EX: 200 MAP - 101 barometric pressure = 99kpa
99 kpa = 14.35 psi
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 07-29-2022, 02:45 PM   #62
MartinLe
MartinLe's Avatar
99 kpa = 14.35 psi
Thanks for the help. I'm thinking that HP Tuners is not a weather station. So, I need to do this calc at the time of the pull. And, if this is another DA question/statement, please, only one "he". I got feelings, ya know
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 07-29-2022, 02:57 PM   #63
swisstyphoon
There is a channel for that in HP tuners.
I think it is already added in Ted's channel list, but can't remember for sure.
2018 Camaro ZL1 A10
MPI Compound Turbo
40% over Injectors
Old 07-29-2022, 03:12 PM   #64
MartinLe
MartinLe's Avatar
Thanks. I just Googled it and found the answer. I will take a look when I get home and let you know.
Sorry, Camaro1973. You can't clown me, I beat you to the punch HaHa.
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 07-29-2022, 03:17 PM   #65
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Ha! Ya barometric pressure is def there and I’m Sure Ted logs map .
Baro changes yes, but you do the calc from the log taken.
Btw you can add boost to your graph, just use the math pids. You’ll see it.
Old 07-29-2022, 03:41 PM   #66
MartinLe
MartinLe's Avatar
Cool.
FIC+30%
Monster S Series
Elite E2-X
2" TSP LT's
Old 07-29-2022, 03:47 PM   #67
Trochoidal
Drives: 2017 Camaro 2SS A8
Boost it!
https://m.youtube.com/watch?v=8CWwTwgsLoI
Old 08-01-2022, 05:41 PM   #68
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Originally Posted by Smokin19 View Post
I can only give an uneducated opinion, others know better but, should you be looking at more of a 38% fuel cam. Further down the road you might need more high side fuel and that would include low side also. The cam should be the right one from the git go because of the cost of pulling the engine. Again, others know better.
I checked with TED and he said the 32% fuel lobe is easier on the pump... Parts are on their way!
Old 08-01-2022, 05:44 PM   #69
SOCAL.M6.ZLE
Project Update.... PARTS have been ordered.
The following are on their way...
- JRE Cam Package with valve-train upgrades
- ATI Balancer with 15% OD Pulley
- Synergy 2 gallon fender tank
- Might Mouse WILD Catch Can
- Katech Oil Pump
- Katech Cast Covers and Coil Relocation Kit
- Katech VVT Delete Front cover
- Katech C5R Chain
- Banks iDash Gauge
- Velossa Tech Ram Air Mouth
So here is my current debate.
Because I am trying to maximize the fueling from the cam and JMS only... I am wondering if I even need to port the blower and add the 103mm TB.
Perhaps I install the above, test, tune, dyno... and see where fueling it at?
I think I can expect 725rwhp with the above?
Then later... Add a low side AUX pump and the ported blower and turn up the E content? Thoughts?
Essentially... are the ported blower and 103mmTB a waste without a low side AUX pump to support them? or do you think the JMS will support up to 750-780rwhp?
Old 08-01-2022, 06:42 PM   #70
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
I would just do it now if your even thinking about it. Your going to end up doing it anyway and going to spend more.
