Old 05-09-2022, 05:41 PM   #57
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Originally Posted by CamOnlyJabroni View Post
You can’t even alter the dyno it was on. The operator forgot to let off the button. Eat crow elsewhere. I will gladly take the car back and lay 700 down on a new mustang dyno. I already contacted the shop again.
I just talked to the owner. I specifically said I had a prick on the forums bashing things when all I’m trying to do is post information to help folks. He isn’t going to charge me and we are going to make pulls with just this car. Thanks for the motivation cupcake.
I think your numbers are good but the squgglies started at like 5900rpm so it wasn’t the button
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 05-10-2022, 08:40 AM   #58
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Originally Posted by wnta1ss View Post
Wait, you made shit up by 'adjusting' the numbers, without including that information along with your fantasyland numbers, then you falsely accuse me of a shit post?
Yes the dyno graph is messed up on the horsepower reading. The car shifted on the dyno...not sure if that caused it. Either way the fact that it made 700wtq should tell you the car is making good power for the mods...especially for being on a MD. I figured it would make 650-660whp on a MD. Again I am not really concerned about the Dyno numbers. The data logs tell me all I need know.
There is no false accusation...your initial post was shit plain and simple. Meaning being a disrespectful prick from post numero uno. You clearly missed the intentions of my post...Again it had a lot of sarcasm factored in. Hence the green emoji smoking...I posted that because I assumed another member who is the king of correction factor might read this.
Old 05-10-2022, 03:13 PM   #59
Idaho2018GTPremium
Idaho2018GTPremium's Avatar
Drives: 2021 Camaro ZL1 A10
I agree with the others on this post that the real peak hp value is about 660 whp, give or take. Don't be so easily offended when someone points out an error. It is obviously not a "real" 725 whp, that value came from the "squiggly" peak at the end of the curve, which isn't real. If this was my curve, I'd take the image and put it in Bluebeam and measure based on the hp scale on the end. You could get pretty close that way. Given the deviations are 150 hp, it's hard to be precise without measuring it out. You could probably get +/- 5 hp if you measured it.
Dyno numbers don't really mean much to me. Trap speed means a lot more in context with the DA, and next in line 60-130 mph times in context w/ DA.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2018 Mustang GT Premium w/ PP1, MR, and A10
2007 MazdaSpeed3
1995 Pontiac Trans Am
1987 Camaro Z28
Idaho2018GTPremium is offline   Reply With Quote
Old 12-11-2022, 04:05 PM   #60
CamOnlyJabroni
CamOnlyJabroni's Avatar
Drives: 19’ ZL1 A10 / 16’ C7Z M7
Here’s your 60-130 time. It’s making plenty of steam. Forgot about this thread after it got dumped on. It’s 700+ on a DJ all day and the 60-130 shows in plain as day. Full weight, full of fuel with a 270 pound driver on 20’s. I ran one 6.00 but it was invalid. 5’s all day with a drag pack.
CamOnlyJabroni is offline   Reply With Quote
Old 12-11-2022, 04:42 PM   #61
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
My results backed up your results 100%. Almost the same build exactly except I’m on totally stock pulleys. I dyno’d on a briskly cool morning with probably negative DA at 300ft and made 740whp uncorrected on e50. You are clearly making over 700whp. No question whatsoever.
CW3SF is offline   Reply With Quote
Old 12-11-2022, 05:11 PM   #62
CamOnlyJabroni
For sure. Couple simple builds with great results. No touching of the motor or meth needed to get well into the 700whp range.
