#57 | ||
![]() ![]() Drives: 2021 2SS 1LE Join Date: Aug 2020
Indeed, the Vette driver made a bad decision to rejoin the racing line with so little speed. But on the on the other hand, from a "defensive driver" point of view, you could have done better to minimize your risk. You dragged your foot on the brake with ~ half normal pressure for several seconds while you presumably were watching the scenario with the Vette unfold, leaving a large chunk of braking for the very end. I understand you probably did not want to brake hard prior to normal brake zone as that would be an unexpected, dangerous move for the cars following close behind you. An alternative that would have worked would be to initially brake lightly to let the followers see your brake lights, then progress to heavy braking and scrub enough speed to enter the chicane below track normal speed and easily allow for you to take a "far left" line in case the Vette driver wound up doing what he ultimately did. |
#58 |
![]() Drives: 1977 Pontiac Trans Am Join Date: Oct 2019
I agree I should have done better, just got a bit of red mist I guess after he had stuck it to my bumper on a warm up lap and then passed without a point by.
#59 | |
![]() ![]() ![]() Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
However to play devil's advocate, you should have pointed by the white Vette on your bumper as soon as you saw the green light after entering the banking if you were following track etiquette. Also technically the Vette didn't leave the track surface but I agree that the driver should have taken the cut through or used their mirrors and waited for a gap before getting back onto the racing line considering how slow they were going. I always ask if the out lap is yellow or green at Track Night drivers meetings if it isn't mentioned because it is almost always green (usually implied = no actual green flag displayed) and this is different from how many other track event organizers run their events. The track night flag video they email out before each event does not even mention the green flag which is not good. Whatever flag (or light color) is displayed during the out lap should override what was said about the out lap in the drivers meeting. |
#60 | |
You are correct he never left the surface but never even looked back to see if anyone was going to be there, that is the skinniest point of the course and even had I been able to avoid him, I am pretty sure i would have ended up in the grass on the outside of 9 and with the rain would have been a free ride into the inside wall. All of it could have been avoided had I backed it down earlier going into 8 as others have suggested, it has been bothering me all weekend, mad that he was able to get me off my game in the first place. |
#61 |
I know that lousy and inconsiderate drivers at HPDE events can easily get under your skin. But take a deep breath and remind yourself that the cars (with the OEM safety systems) we are driving were not designed for collisions with solid objects at speeds over ~ 50 mph. At HPDEs we are well exceeding those speeds, so safety is #1 because we want to be able to go home with our cars and our bodies in one piece.
If you run across a fellow driver who is not behaving in a safe and predictable manner, I suggest you: 1) Distance yourself from that driver on track 2) Inform the track stewards of that driver's unsafe behavior and ask that corrective action be taken. |
#62 | |
![]() ![]() Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
One more to add, first thing in the video.
#63 |
![]() Drives: 2018 NFG 2SS 1LE! Join Date: Jul 2018
At TNIA events 1st session 1st lap is yellow. 2nd and 3rd sessions are green first lap.
#64 |
![]() Drives: Cadillac ATS-V Join Date: Feb 2023
First time to Mid-Ohio, first session, third lap...not enough brake into Madness, then not enough steering input, then no throttle to rotate, then forgetting the grass was wet ...
Stopped with the right rear about 3' from the concrete wall. https://www.instagram.com/reel/Cwfso48rreU/
2018 Cadillac ATS-V Sedan
NCM*Putnam Park*Mid-Ohio*Gingerman*Road Atlanta*Barber*Pitt Race*VIR |
#65 | ||
![]() Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
I have one from mid Ohio today. How not to enter Turn 1. 3 mistakes: 1) Downshifting after turn-in 2) I typically heal and toe, but was being lazy this time and did not, thinking auto blib would do it for me 3) accidently switched off auto blip earlier in the session Last edited by 5.M0NSTER; 04-14-2024 at 09:34 AM. |
#66 | ||
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
#67 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
#68 | |
Thanks, I had that split moment when I considered going shiffle hands to add more, but then I though "no, just hold full lock, it will be catch". Glad I stayed the course.
#69 | |
![]() Drives: 2021 SS 1LE Join Date: Mar 2023
Alright.. I'll throw one out there from the past -
My wife forgot to put the hood pins back in. Somehow the car made it through the warm up lap and the first few corners. It was a qualifying race - I finished second. There was a LOT of interest in how much the car weighed in impound.. |
#70 | ||
