#57 |
![]() Drives: 2017 2SS Convertible Join Date: Mar 2021
Glad to hear that this solution helped, Nine9gtr
Camaro SS 2017 Convertible, 2SS trim, V8 6.2L 455HP 618Nm, A8, Silver
Mods so far: K&N oil air filter, rear lamps EU conversion with sequential turn signal, exhaust mod to 4 tips (non-NPP), LED rear fog light (EU requirement), Diode Dynamics LED markers. Mods planned: Morimoto LED lamps set (front) |
#58 |
![]() Drives: Camaro ZL1 1LE Join Date: May 2025
I know its marked as solved, but I'm still running into the issue after i brought the car to the dealer and had them do the update, it didn't fix the issue, i didn't watch them to ensure they did the right function. I'm concerned though that it might be something else, did anyone else continue to have the issue after the update was done? I have the exact same issues, triple unlock, heat/vent seats not working and memory seat not working. I did have codes for something about rear antenna and a couple high & low voltage codes but none of those relate anything to BCM or Airbag sensor, so I'm lost on what to do next. Fuses are good and battery is good.
#59 | |
IF BCM was updated in the way I mentioned in previous posts then I cannot provide more insight. What I would suggest is to double-check if the Update procedure was executed correctly - not sure if you were present the last time and can confirm that they did it exactly the same way (maybe they sipped some steps or executed Update not on BCM level but on general level - I have no idea). Maybe visit another dealer? Or better someone proficient with GM electronics like I did (my guy works in the GM factory in Poland - and gets his knowledge from there). I hope you will get that figured out. BR, Jarek
#60 |
![]() Drives: Chevrolet Camaro Join Date: Apr 2026
Hi, I have the same problem with my Camaro, no heating, ventilation, and seat memory, I'm also from Warsaw, could you send me the contact information for the mechanic who updated your BCM?
Cześć, mam ten sa problem z camaro, brak grzania, wentylacji i pamieci foteli, tez jestem z warszawy, podeslesz mi jakies namiary na tego mechanika ktory ci zaktualizowal ten bcm ? |
#61 | |
No problem - I have provided it via PM.
