#57 |
![]() Drives: Camaro Join Date: Apr 2021
How about the stock cats on the ZLE? Are they melting like this also under heavy track use?
#58 |
I scraped-out my Kooks green cats last week after a little more than two years. They were a mangled whistling mess. Not burnt. Kooks has referred me to their high output cats, but I know nothing about their specs.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 10-04-2022 at 01:09 PM. |
#59 |
![]() Drives: Camaro gen 6 zl1 1le Join Date: Jun 2022
anybody has tested 200 cpsi HJS cats they fall out too ??
I hear nothing good about arh cats kooks cats green cats gesi gen 1 cats |
#60 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
Kooks has a new set of high output green cats available now under part number 22603400.
#61 |
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
Why not go full tune with E50/ 91 or 93 mix? That should avoid or at least considerably slow down cats melting like that even under track usage.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% lower, Griptec 2.5 upper, NGK HR7 Ruthenium plugs, Nostrum 22+ injectors, XDI Goliath HPFP, Katech dual in tank low side pump, Katech oil pump, LME tensioner, DOD delete, LT1 big fuel cam, Jokerz ported blower, MPI lid, GMS hood extractor bracket, Soler ported 87mm (91mm eff) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, 186* LS3 T-stat, Black Widow Angry Housewife/ Corsa NPP mufflers, Borla X pipe, BMR engine mounts, Banks iDash, Lithium Battery, AEM X- Series, HP Tuners, E85, 16.5 psi
723 HP/ 765 TQ |
#62 |
The green cats aren't melting for most people, they are just folding in and clogging. If they're melting then the tune is probably off.
#63 |
Drives: 21 ZL1 Join Date: Feb 2022
Just hammer those "green cats" out and make them offroad. The look is there for inspection and you will appreciate the power and sound.
#64 |
Exactly what we did. Hammered/scraped them out. It sounds like John Force now. Not for those with sensitive ears.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#65 |
Just bore out the cats and you will still retain a visual state inspection. You will be on full e85 after your port injection so your exhaust will not smell that bad.
#66 |
The biggest issue is that these cars sound like hot garbage without the cats. They develop a raspy sound that is hard to fix. You can change the exhaust, different muffler combinations, etc, but the they still have a distinct rough sound to the exhaust. With cats, they just sound a LOT smoother and less raspy. Also, adding port injection just to run E85 is very expensive for a lot of people so that may not be an option either.
#67 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
My buddy has no cats on his and similar exhaust as me and it’s simply just loud noise. When you take that rasp away it’s a game changer. You can hear the engine how it should sound reminds me of the old 454 days running on 12:1 compression ![]() If you take a c6 z06, put same exhaust as a new c7 or zl1 side by side, there’s simply no comparison. These new gen 2 cats have been great, I am Just not sure if they are going to hold up on my new motor that’s goin in. As far as port injection, yeah not cheap. I believe my kit was like 6k for the Holley and that doesn’t include install.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#68 |
To clarify: My green cats were a mangled whistling mess, but not burnt, as I previously stated. Kooks has referred me to their high output cats, but I know nothing about their specs.
2020 ZL1LE A10.
#69 | |
When I pulled my OG green cats because I was concerned about them failing, I went with offroad pipes and immediately disliked the additional volume and tone, so I added the Magnaflow muffler in the center as many have done which helped with the volume but the tone still wasn't as good as it was with the green cats, but then I got concerned about the flow of the double Y design so I pulled it out and installed a Jones X pipe muffler and the sound got worse, much sloppier and raspy. I had it on the car about a month and now I'm back to my original green cats again and it sounds great again. I bought a set of the Kooks HO green cats which I will swap out with the original green cats when they arrive. |
#70 |
They are custom made for Kooks by GESI, I believe they are rated to 500-850hp per bank instead of the the previous green cats 350-500hp per bank. Based on the specs 3" inlet and 4.5" body, 300 cell count, it looks very similar the Gen 1 UHO cats from GESI, PN 85032.
