Old 03-19-2021, 07:58 AM   #57
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by CS10SS View Post
Gotta save some upgrades for the future.
Agree 100%, which is why I added 200 crank last year via a custom valve train and headers in my 1st group of mods, but no SC or TB changes, other than 10% lower pulley.
My 2nd group could have included anything but will incl.:
Ported SC
103
DSX LP
GripTec snout 2.4
FII blower spacer plates & thermal reduction blanket
MM CC
My 3rd group might incl. a 2650, DSX HP, etc., or not.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 03-24-2021, 03:14 PM   #58
ZLAV1N
Previously CS10SS
ZLAV1N's Avatar
Drives: 2017 ZL1 A10
Pictures
Progress is being made & the build is coming along nicely. Katech found out that some of the guides are beyond spec and a few are right at the limit of the GM spec. Apparently this happens on LT4's. Mine only had 7,700 miles when the build started. So we added bronze guides with Katech Ti/Mo Valves just to be safe & prevent any issues down the road.
'02 Trans AM - sold
'05 SRT4 - sold
'05 STI - sold
'96 300ZX - sold
'10 2SS/RS M6 455rwhp - sold
'13 ZL1 M6 720rwhp - sold
'17 ZL1 A10 930rwhp - Katech Built
ZLAV1N is offline   Reply With Quote
Old 03-24-2021, 04:12 PM   #59
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
It all looks great, love the blueprinting sheet! Is the pic on the bottom a head after CNC but before final steps that result in that polished look? Both look clean as new, but the head at the top is so shiny, and has hand markings.
EDIT: I zoomed in close to the one on the bottom and looks like there is no CNC yet on that, it still has the casting look finish around the valves.
SFV1LE is offline   Reply With Quote
Old 03-25-2021, 07:39 AM   #60
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Question...
The weak link of the factory rotating asm is the thrust bearing I believe. Is this addressed while the engine is out? If so can they do a little spill on how they go about the upgrade?
I'd be interested to see why and what it looks like? I've heard complete street do a spill and maybe weapon X but never any photos and why the thrust bearing is the problem or how its corrected.
I believe they see failure just past a the 900 mark which is why I haven't turned up my setup much past 1000.
a lot shops do cams in the car, but your motor is out and seems like a good idea to look at it.
Old 03-25-2021, 10:51 AM   #61
Katech_Mike
Drives: 2015 Camaro ZL1
Question...
This engine is 100% stock bottom end. If we were doing a full engine build we would install a complete thrust bearing.
We have yet to fail a thrust bearing on a stock bottom end LT4 even on 1,000RWHP set ups.
Anything much past 1,000RWHP we would recommend building the bottom.
Katech_Mike is offline   Reply With Quote
Old 03-25-2021, 11:09 AM   #62
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
I understand but those of us on budget builds that want to use stock internals and correct this problem would be interested or I would.
Old 03-25-2021, 11:32 AM   #63
JSH
JSH's Avatar
Drives: '20 ZLE
Mike,
I see you only have 7 posts here, and just want to say that a lot of Camaro guys at this site, myself included, would surely benefit from having your/KaTech's input on many if not most topics. I've said to you in email that I will send my next car and perhaps my current car to KaTech.
2020 ZL1LE A10.
Old 03-25-2021, 11:54 AM   #64
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
Here is an explanation
https://www.enginebuildermag.com/202...february-2020/
The Gen V thrust bearing looks more like a half a washer.
My engine shop converted mine to the King LS style bearings while the engine was apart.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
Old 03-25-2021, 11:55 AM   #65
Katech_Mike
To replace the thrust bearing the crankshaft has to come out. So at a minimum your replacing all of the torque to yield fasteners in the bottom end (Rod bolts, main bolts, ect).
It honestly doesn't make sense to go that far without doing rods, pistons, main studs, main & rod bearings, ect.
In my opinion I wouldn't touch the bottom end until you're ready to build the engine.
Old 03-25-2021, 11:57 AM   #66
Katech_Mike
Mike,
Thanks for considering Katech for your next build. We're looking into becoming a supporting vendor which will mean much more activity from Zach or myself.
Old 03-26-2021, 03:56 PM   #67
ZLAV1N
Previously CS10SS
ZLAV1N's Avatar
One step closer.
'02 Trans AM - sold
'05 SRT4 - sold
'05 STI - sold
'96 300ZX - sold
Old 03-26-2021, 04:30 PM   #68
SFV1LE
I hope those head-gaskets hanging from a peg are the ones they took off your motor prior to throwing them out, and not something they plan to install on someone's car :-)
Old 03-26-2021, 04:59 PM   #69
JSH
JSH's Avatar
Drives: '20 ZLE
I would think those are otherwise good gaskets off of customer's engines that took a beating during removal. Hopefully not blown gaskets from customers lifting the heads with too much... N2O
2020 ZL1LE A10.
Old 03-26-2021, 05:34 PM   #70
SFV1LE
Any N2O is too much N2O :-)
