Old 12-03-2020, 08:46 PM   #57
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
The pinch welds are stronger and stiffer than the sheet metal on either side. That's why all car manufacturers designate them as the best lift points on unibody cars.
The lift blocks that straddle pinch welds and load the horizontal sheet metal next to them were designed by people who don't know structural design, sorry to say.
Old 12-04-2020, 07:04 AM   #58
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
I agree.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 12-04-2020, 07:35 AM   #59
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Originally Posted by craigss50 View Post
Does anyone know what the difference is between the convertible and the sedan as far as pinch welds? You can get bolt on for the sedan for under $50 but if you have a convertible it looks like ZL1 Add Ons is the only company that makes them for the verts and costs $94.
There's a difference in the "depth" of the pinch weld on one side (height of floorpan vs height of rocker). The unique door frames for the vert come with extra steel on the outboard side to support the x-brace and add stiffness. The ZL1 Addons Vert pads are cut down on one side so they properly fit this beefier panel at the pinch weld. If you don't cut down the outboard side, the set screw will not engage.
(edit - added a crappy photo but you get the idea)
Old 12-04-2020, 08:43 AM   #60
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
Originally Posted by Racerman27410 View Post
The fender damage that i've seen doesn't come from the pinch weld lift pads . The dealerships use a two post lift that has arms that swing under the car. When the lifting pads on those arms are not adjusted correctly then the arms of the two post lift will make contact with bottom of the front fender
and bend them before the lifting pad makes contact with the subframe/ chassis of the car.
Has nothing to do with the strength of the pinch welds and everything to do with techs not paying attention to details before lifting the car.
Thank you for this excellent description of how the damage can happen.
Emoto is offline   Reply With Quote
Old 12-04-2020, 10:59 AM   #61
MatthewAMEL
MatthewAMEL's Avatar
You mean other than the ZL1Addons product? They DO NOT make the area around the pinch welds load-bearing. They simply make the area of the pinch weld easier to access and get a lifting device on.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 12-04-2020, 12:43 PM   #62
az4783054
Drives: SWXXZL1
The provided 1/8" allen set screws are a PITA to tighten since they're so recessed within the pucks. Longer set screws may be available (?).
I replaced them with hex head grade 8 bolts. I believe the thread size is 1/4-28" to allow a better grip and torque without stripping out the recessed set screws. I also inserted 1/8" aluminum shims behind the fasteners to prevent the fasteners from digging into the pinch welds.
"Joe" does a hilarious impression of a slinky toy on stairs.
az4783054 is offline   Reply With Quote
Old 12-04-2020, 12:54 PM   #63
zaimer
zaimer's Avatar
Drives: 23 ZL1 6speed
Originally Posted by az4783054 View Post
The provided 1/8" allen set screws are a PITA to tighten since they're so recessed within the pucks. The unibody floor boards are not flat which prevents using just about anything but an allen wrench. Longer set screws may be available (?).
I addressed that by replacing them with hex head grade 8 bolts. I believe the thread size is 1/4-28". With those, one can get a better grip and torque without fear of stripping out the recessed set screws. I also inserted 1/8" aluminum shims behind the fasteners to prevent the fasteners from digging into the pinch welds.
The ZL1 ADDONS pucks may be more to prevent the pinch welds from being deformed laterally when lifted.
Thank you, I'm glad I'm not the only one who had struggled. They weren't terribly difficult but it was enough to say "c'mon on now".
zaimer is offline   Reply With Quote
Old 12-04-2020, 07:47 PM   #64
Gunkk
Gunkk's Avatar
You can get 3/4" stainless set screws on amazon.
