Old 04-09-2022, 10:23 AM   #57
joekd
Drives: 2018 Camaro SS vert
Originally Posted by TheDocKlopek View Post
Just got it in the other day and super pumped to put this in. I hope the removing the seat isn't too much of a pita.
It really is simple, just pull the top of the seat, hit the pins, done
Hardest part for me was getting the OEM plug disconnected, that thing was in there tight!
joekd is offline   Reply With Quote
Old 04-09-2022, 10:22 PM   #58
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Removing the seat back is easy… I struggled with the connector with the seat back in place. I ended up removing it to disconnect the plug. Although, your plug may not be as tight….
Old 04-11-2022, 10:22 AM   #59
tommcd24
tommcd24's Avatar
Drives: 2SS M6 NPP Convertible
Same experience for me. Two "sideways V" type spring clips about 3-4" down from the peak of each seating position. The top will lean out about 4", just enough to get my forearms down into. Took a little wiggling and effort to get the connector apart, but otherwise the install took about 10 minutes total.
Ember has a YouTube video he made when he installed his that I found helpful.
2SS Convertible M6 NPP Riverside Blue w/ Silver Rally Stripes
Dec. 18: took her home
Dec. 9: arrival at dealer
Nov. 16-29: Toledo, OH (railyard)
Nov. 9: 3800 -> 4300 (for stripes)
Oct. 8: 3400 status TPW 10/25
Oct. 6: 3100 status TPW 10/25
Sept. 9: 3000 status TPW 10/4/2021
Sept. 3: 2000 status (after 5 1/2 months)
Sept. 2: Change Order: 2SS (V6 constraint)
April 12: Reordered as ‘22 3LT RS V6 (March 16:Initial Order ‘21 3LT RS V6)
tommcd24 is offline   Reply With Quote
Old 01-31-2023, 01:54 PM   #60
Plasar
Drives: 2017 ZL1 Vert M6
Lightbulb
  • Hi, I wanted to give a quick update on my One Touch Top unit.
  • Recently, all the top functions stopped - the button on the headliner, key fob, the triple click of the unlock on door handle, etc.
  • I wanted to make sure it wasn’t recent work done on my top when it was replaced due to someone knifing it.
  • The folks who replaced my top plugged into the OBD Port to try to read codes - no codes.
  • As a last resort, their OBD tool had a command to lower the top ignoring all warnings or blocks - the top worked perfectly.
  • Then I concluded it must be the One Touch module - I opened up the back seat, unplugged and replugged the module in, and voila, now the top worked perfectly again.
  • I am so relieved and am stoked my top works again!!!
Plasar is offline   Reply With Quote
Old 02-15-2023, 09:05 AM   #61
TheDocKlopek
Drives: 2018 Camaro ZL1
I ordered this device back in March of 2022 and FINALLY installed it last week. I worked with their support and have to say they are extremely helpful and quick to respond. Everything works perfect, this is worth every dollar all day. Highly recommended if you are considering it.
2016 2SS Vert 6M Black/Adrenaline Red (Lost in Hurricane Harvey)
2018 ZL1 Vert 6M Garnet Red Tintcoat
TheDocKlopek is offline   Reply With Quote
Old 05-25-2024, 10:53 PM   #62
cengell
Drives: 2017 2LT Garnet Red
This sounds like a cool mod. I saw they had a $169 UK deal on Facebook? IS there any deals in May/2024.
Hoping for a deal/special as it's been a few years on the market..
Thanks
Christopher
cengell is offline   Reply With Quote
Old 05-29-2024, 08:25 AM   #63
OBD3
Drives: 2023 Chevrolet Camaro 2LT RS trim
I have this mod and its fantastic, it does exactly what i want it to do, notwithstanding the windows not going up. If you are looking for this, you might get it at a good price but with the Camaro out of production and years starting to go by, you might want to get it sooner than later. Happy Hunting
OBD3 is offline   Reply With Quote
Old 05-30-2024, 10:14 PM   #64
cengell
Thanks, I do wished that the 4 windows would go back up but think it's GM issue and not this product?
I read it's a safety issue, the reason we can't remotely get the windows back up/closed.
Maybe someone will find a discount code?
Thanks
Christopher
Old 05-31-2024, 06:52 AM   #65
ember1205
Hot Camaro
ember1205's Avatar
Thanks
Christopher
It's a US Lawyer issue. Someone used to offer the feature, some idiot managed to get hurt, they sued, manufacturer lost. Now no manufacturer will add the feature back in.
