Old 01-15-2021, 07:54 PM   #57
MR's 2SS
Drives: 2020 2SS Vert/M6/F250 SD
I see some recommendations for the Conti DWS. Before deciding on the snow tire and wheel package I looked at replacing the stock GYs with the Contis and selling the GYs.
I had a quote for them mounted and balanced at $850. They get pretty high marks as an all season.
I didnt look at Firestones. I never thought of them as top tier tires. I also dont look at Generals because back in 1985 I bought a Bronco 2 and it came with General all seasons. I got 2 flats in the first couple of weeks. One from a rock in a gravel driveway. So Ive never once considered them since.
HAHAHA... funny how that works.
Still and all these tires run at or below the cost of truck tires. I rotate my truck tires every 5,000 miles. Thats why I may go to a square set up on the SS after its all said and done.
MR's 2SS is offline   Reply With Quote
Old 01-15-2021, 08:10 PM   #58
It's probably water under the bridge now that you got the extra winter tires, but those A/S Contis or another quality all-season set probably would've worked just fine and lasted you a long time in a square setup. If only GM gave us at least a few tire options to choose from with these cars.
Let's be honest though, we aren't really in the "snow belt", the amount we get typically isn't excessive. The main reason I try not to drive the Camaro in the winter is the freaking salt and not that much the snow.
Old 01-16-2021, 07:15 AM   #59
FarmerFran
FarmerFran's Avatar
I just paid $1K USD for 4 G-force Comp2 AS Plus, installed.
FarmerFran is online now   Reply With Quote
Old 01-16-2021, 10:46 AM   #60
MR's 2SS
Yea. The past few years have been easy. 2010ish though we had snow after snow. I manage a municipal agaency so I am the guy with the salt. My department uses as little as we can get away with. I havnt bought salt in over 2 years and my shed will only hold 50 tons. The damn State puts salt down by the millions of dollars when theres rain that might become salt. I hate it.
My 2007 GMC 2500 had wheel well rust through last year. And from new I rinsed and care for it religiously. Thats how I ended up in an alumaduty.
All things considered Ill probably go square with all seasons when the GYs wear out. But who knows.
Old 01-16-2021, 11:20 AM   #61
True that, I remember my kids digging an entire cave into the snow in 2013
What would happen if townships didn't salt at all and just relied on plowing and people's common sense (tires) and driving ability? Lawsuits or just blowback from media? Also, is there nothing else to be used, sand or something that isn't corrosive when mixed with water?
My wife's SUV is rusting already, which is ridiculous and very frustrating. Washing it is a damned if you do, damned if you don't situation, because unless I'm mistaken, brine is way worse than caked on salt. I wonder if getting it washed weekly or even more frequently in the winter would help.
Old 01-16-2021, 05:32 PM   #62
enjikari
3/10 Vehicle Mechanic
Drives: 17 Camaro SS
We just bought a 2ss vert for my wife to commute in. And for cruzing and all on the weekends.
You cant rotate tires because your fronts and rears are different sizes. But after looking at the cost of the runflats you might find you can buy nice rims and tires... non runflats... in the same size front and rear. So you can rotate.
I just bought winter tires and rims for 1700 deliverd. Not that the car will be driven in heavy snow but it is going to be transportation. If it snows heavy shes working from home or Ill come in and take her in the truck.
The snows should last several years and with the GY runflats running 8 months or so they should last at least 2 years maybe a bit more.
Im getting her a AAA membership and either a slime repair kit or something similar. And the next set of tires will not be runflats.
Even if you get a flat with the runflats you will likely be required to buy a new tire. Which means 2 new tires because your not going to run a brand new tire on one side and a 50% tire on the other.
By the time I wear out the GYs I will decide if Im putting 4 rims and tires of the same size on and rotating.
Your in the sunbelt. Im in the snow belt. What I was not prepared for was needing to buy the winter tires right away. We have 3 months left on a QX50 and I was just going to park the SS unless it was sunny and not salty.
I was surprised to find out you cant even leave the car outside in the sub freezing temps and drive off because the rubber could be damaged. And they are supposedly like driving on steel wheels below 40. Not exactly true as I have been driving them in the 30s and they were fine.
But Im too paranoid to leave it like that so I bought the snows right away.
Im wondering how you made out since this thread is 3 months old.
Well bud, all I can post is what I have so far. These are the 4 tires I bought:
245/40ZR-20 Michelin Pilot Sport A/S 3+ (W- or Y-Speed Rated) 5-Rib Tread Design XL
I've driven in as cold as it's gotten here so far (32deg, no ice), and I've driven in the rain at least twice - no issues. I don't really have any wear reporting to make given the age - will let ya know in another ~9 months? The way we've budgeted for tires is me having to change every 18months (1.5yrs). If I can at least meet that, I'll be fine. If they last longer, then even better.
Again, my baby is primarily for commuting, and some quick math says she'll put on about 20k/year. I'll give what details I can to help other judge the longevity, but I know every person's different.
With these tires: so far, so good.
enjikari is offline   Reply With Quote
Old 08-03-2023, 05:25 PM   #63
enjikari
Reporting back in.
To add a small detail I purchased said tires on 10/26/2020 and they hit the pavement about 2 weeks later. I'm 3mo shy of two years with these tires and they are still running strong. My next check is around that 2yr mark, so I'll try and get actual grade/numbers for a true update. 20+mo out of these tires that ran me, after install, around $1100 is not bad at all, especially given I was dreading having to drop $1500+ every YEAR. I do recommend these tires btw, if anyone's looking to buy. I'll try and report back in around 3mo or so from now.
Old 08-04-2023, 07:28 AM   #64
bootss
Drives: 2021 ZL1 1LE with PDR
I just mounted some PS4S on my ZLE and they are a little mushier than the GY3R but they are what I had.
They are definitely more of a road tire. I picked up the whole set for 1200.
bootss is offline   Reply With Quote
Old 11-16-2024, 09:13 AM   #65
enjikari
New Tires Progress Report
So, today was the day. Bought my second set of new tires and had them put on this morning. Here's the breakdown:
  • First set of new tires put on 20201103 @ 40655mi
  • New set put on. 20241116 @ 68521
  • Same tires - Michelin Pilot Sport A/S 3+
  • Primary driving - commute to work and random outings
  • No track, no burnouts - maybe 30-50 'git-ups' a year
  • Tires lasted 27,866mi, 4 years and 12 days
  • "Think you could have gotten to 30k?" - another 2kmi? Rears, maybe, but I wouldn't have ran the fronts that long
  • Tires purchased from Tire Rack and shipped (free) to installer, price for all 4 total was $1,303.22
  • Install - local Pep Boys $126.25
  • Grand total - $1,429.47
So, after all my worrying 4 years ago, I got a damn good set of tires that lasted me 4 years and almost 28k miles. I heard from countless folks that I'd be R2ing these tires every year. Thankfully for me and my story, that was laughably not the case. This has been great news for me, especially when I had budgetted for 3 years. I hope others have the same story. I recommend these tires, and hope others get the same great life out of them I've had.
Guess I'll update this again in another 3-4 years from now
