Old 05-08-2022, 02:08 PM   #57
JSH
JSH's Avatar
Drives: '20 ZLE
I've just started down a path parallel to this thread with a TVS2650, LPE BB, DSX Aux., and either +30 or +65, with perhaps the biggest difference being using GT100 versus E.
I plan to call these vendors tomorrow and am wondering if anyone else here has been down this road previously.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 05-08-2022, 02:25 PM   #58
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
Same here. I just ordered a LPE HPFP and XDI+30. Plan on working with Ted and seeing how far we can push E85 with a ZL1 in tank with JMS. Decided I’m ok with mixing hope I can do E60 at 8-9 psi. We will see.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 05-08-2022, 03:18 PM   #59
ZL14ever
Drives: 2018 Camaro ZL1 A10
IMO, LT4 HPFP running at 2900 psi will give more fuel than LPE BB running at 2200 psi
ZL14ever is offline   Reply With Quote
Old 05-08-2022, 03:54 PM   #60
Chrome383Z
Chrome383Z's Avatar
Can you run the LPE at 2900 psi?
Old 05-08-2022, 04:18 PM   #61
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
False. The LPE can move significantly more *volume* at those stated pressures…the catch is you need bigger injectors that can supply the engine using lower rail pressures without too long of an IPW.
Old 05-08-2022, 04:20 PM   #62
Joshinator99
Moderator
Yes, but your volume falls off. So it’s just a decision as to whether you need to cover for injectors that are too small or not. With LT4 injectors you’ll need the higher pressure. Once you get bigger injectors you can use lower rail pressure to move more volume through the HPFP.
Old 05-08-2022, 04:34 PM   #63
Chrome383Z
Chrome383Z's Avatar
Thanks Josh.
Old 05-08-2022, 04:57 PM   #64
Joshinator99
Moderator
Thanks Josh.
Anytime.
Old 05-08-2022, 05:07 PM   #65
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Yes..
Lpe big bore
Lpe 38% lobe
Fic 30%
Dsx pump.
887 full E.. edelbrock non ported
If you haven't started the build and you want the most out of the parts you should do it this way.
*LPE fuel lobe 42% or Cunningham 43%
*LPE BB Pump
*Fore pump intank return style or
Holley eliminator 200 gph 18.5v/80 psi setup as return style
*LPE or equivalent hiflow check valve and line(the line will be high flow if you ran a new line for the feed)
*Plus 65%
I think you will bust 930 plus on all e
Old 05-08-2022, 05:27 PM   #66
Joshinator99
Moderator
To back up @EDF’s point, if you’re going to run big power on DI only, you definitely want a +42/+43 fuel lobe on your cam to drive your LPE BB HPFP. I’ve got a shitty +32 cam and it’s definitely a problem as I creep up on 1K WHP.
Old 05-08-2022, 06:00 PM   #67
JSH
JSH's Avatar
Drives: '20 ZLE
I haven't finalized any orders as of today.
So, based on your suggestions, how about starting with:
TVS2650
LPE BB
32% lobe (installed)
+65
DSX lowside (installed)
I could do a 38 or 42% later if I'm so motivated.
Running GT100 or E85?
Yes..
Lpe big bore
Lpe 38% lobe
Fic 30%
Dsx pump.
2020 ZL1LE A10.
Old 05-08-2022, 07:30 PM   #68
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
32% lobe and XDI +65's with a big bore will get you in the 900-1000whp range on E65 but not Full E. The 32% lobe is the limiting factor. On race fuel you will have plenty.
We threw the C7Z on a local Mustang Dyno yesterday but it wouldn't hook up. Tires would break loose around 4800rpm and there was a 22mph difference in MPH between the Dyno readout and the wheel speed sensor.
Old 05-09-2022, 08:19 AM   #69
JSH
JSH's Avatar
Drives: '20 ZLE
What about these? LPE +52 https://www.lingenfelter.com/product...l#.Ynkv-ejMJMs
I ordered LPE BBDI pump.
LPE encouraged me to go to with their 7.85mm fuel lobe cam.
2020 ZL1LE A10.
Old 05-09-2022, 02:20 PM   #70
KingLT1
KingLT1's Avatar
Nothing wrong with those LPE +52's. The XDI +65's are less money.
If you are trying to make as much power as possible and want and want all the fuel this go around then get:
XDI +65's
XDI belt driven HPFP
Triple pump low side
Or if you change the cam then get a 42% lobe, big bore, and +65's.
