Old 09-16-2020, 12:34 PM   #57
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Wish these would fit a C7!
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 09-16-2020, 02:14 PM   #58
Matos1LE
Drives: SS 1LE
They do, you just have to modify the hood lol.
Matos1LE is offline   Reply With Quote
Old 09-16-2020, 02:15 PM   #59
EricFormula350
Drives: 2020 Camaro 2SS
Originally Posted by Fraxum View Post
Super cool!! Me too. I was thinking of trying to fit the stock Lt1 cover. Looks good in there. It won't fool the dealer though.
Edit: Found it:
https://www.shopchevyparts.com/corve...5153_5250.html
Expensive. I got mine for $198 off eBay
2020 Camaro 2SS A10 - Garnet Red/Kalahari, LT2 Intake, RotoFab CAI, Velossa Tech Intake Snorkel, JLT Catch Can, IKON Motorsports Rear Diffuser, MBRP Axle Back Exhaust, Anderson Composites Carbon Fiber Decklid, 1LE Splitter
EricFormula350 is offline   Reply With Quote
Old 09-16-2020, 10:29 PM   #60
QuarterMileSS
Camaro6 newbie
Drives: 2020 Riverside Blue Metallic 2SS
do you guys have long tube header pipes? i have 2" headers, it seems like the injector noise resonates through the primaries.
I have 1 7/8" Speed Engineering long tubes and I don't hear shit from my injectors.
QuarterMileSS is offline   Reply With Quote
Old 09-17-2020, 06:59 AM   #61
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Originally Posted by Mountain View Post
FYI, the areas that were cut/ground on, you can take a tourch, with a very small/lite flame, and go over the area to "seal" or blend the work that has been done. Works pretty good on these PA-GF materials. Just takes a quick back-and-forth over the area with the flame a bit away and off the material.
$390 is not all that unreasonable to the intake+booster fitting+work to add the fitting+work to remove the ribs+MAP extension harness.
A heat gun does the same and IMO better. I use a heat gun on faded Jeep plastic tire guards or any of those parts that fade and works great. Darkens then right up by bringing up the oil used in making the plastic.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 09-17-2020, 07:09 AM   #62
BlackbeastSS2
Originally Posted by EricFormula350 View Post
LT2 Intake Cover installed.
That’s the way to go with the added cover. Just need a custom plate to cover the corvette and add Camaro.
You can put the fuel feed line behind the rear of the manifold. Did it with my E85 on past 2016, you just have to slowly turn and a slight twist on fuel line. They do bend but don’t put a kink in the line.
Old 09-17-2020, 07:55 AM   #63
Fraxum
Fraxum's Avatar
Yeah, I was looking there too. Red would be hard to get that cheap, but I can solve that with a spray can. I see there is one now with an open bid. But I still do not know when my C8 IM will arrive. So happy to buy it as a bolt on kit.
Old 09-17-2020, 06:56 PM   #64
red6.2
Drives: 2010 camaro
This is a great opportunity for someone to sell lt2 manifold covers with Camaro lettering instead of the stock corvette lettering. If someone is willing to to make them and does a oem finish and superb job on the intake manifold cover, I would likely buy one depending on the price of course.
red6.2 is offline   Reply With Quote
Old 09-17-2020, 07:15 PM   #65
Dvs510
Dvs510's Avatar
Drives: 2018 Camaro SS/1LE
Gonna try and hit up emblempros and see if they have any plans on making a direct fit overlay for it
2018 SS/1LE... summit white.. E85 ,Ported LT2 IM, Roto Fab, soler performance ported throttle body, secondary delete, mbrp axle back, tuned by CCNC
Dvs510 is offline   Reply With Quote
Old 09-17-2020, 07:29 PM   #66
BlackbeastSS2
Has anyone heard that the C7 guys are doing the same as we are doing with the LT2 intake manifold? I would think so.
Old 09-17-2020, 07:32 PM   #67
red6.2
Drives: 2010 camaro
what's up Dvs510! how' s the car running man. I think you know who i am lol. shhhhh! lol. whenever your down tho lets go to the track!
Old 09-17-2020, 07:46 PM   #68
BlackbeastSS2
Can anyone measure the length and height of the Corvette lettering?
We might be able to use something already on the market.
This one is
9.8inch x 0.86
Old 09-17-2020, 08:06 PM   #69
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
I believe the LT1 intake was sized specifically to clear the C7 hood, so I doubt they are able to run it without interference issues.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 09-18-2020, 07:34 AM   #70
Fraxum
Fraxum's Avatar
That is a great idea. As for me I am Okay with Corvette on my motor. After all this motor was a Corvette engine as well.
