Old 01-20-2022, 10:40 AM   #57
Phil zl1
Drives: 2022 zl1
Not at all the point .What people want to know is the actual top speed of the car obviously on a level surface. The rest is all bullshit and has zero value. At the end of the day it s how fast can it go in a straight line . Dont go too deep trying to over analyze it
Phil zl1 is offline   Reply With Quote
Old 01-20-2022, 11:43 AM   #58
Idaho2018GTPremium
Idaho2018GTPremium's Avatar
Drives: 2021 Camaro ZL1 A10
Originally Posted by ohsmily View Post
Knowing the speed at which a particular vehicle will redline is valuable information. You can then apply that knowledge to the real world. What is your "real world" for the purpose of top speed? Two perfectly measured runs with scientific equipment to come up with a two direction average? A freeway? A runway? A slight downgrade? A tail wind? All of these will affect top speed in a given situation. Knowing the A10 won't redline in the top gear (or likely even the 8th or 9th) at any practically attainable speed is relevant to thinking people. You have discarded that information out of hand as irrelevant to the question of top speed.
The theoretical top speed of an A10 ZL1 in 10th gear is irrelevant because it will never be able to get there. When someone asks "what's the top speed of the car", they are asking about what it will actually attain, which is officially 198 mph, a two-way avg (194 mph one way, 202 mph the other) to eliminate the wind factor. They aren't wondering "what is the gear limited theoretical top speed in a vacuum".
Now if you're talking about optimizing the top speed in an M6 ZL1, then we would need to start getting into gear ratios and such.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2018 Mustang GT Premium w/ PP1, MR, and A10
2007 MazdaSpeed3
1995 Pontiac Trans Am
1987 Camaro Z28
Idaho2018GTPremium is offline   Reply With Quote
Old 01-20-2022, 12:48 PM   #59
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Originally Posted by Rams01 View Post
186MPH last month in my A10 2018 ZL1 and that seemed to be where the limiter was at since it didn't move after staying in it another 2-3 seconds.
If you hit a limiter (if one even actually exists in the coupe), you'll know. Been there and done that: The ECM cuts throttle and you get a dashboard message. The throttle cut isn't as harsh as it is if you bounce off the redline in a lower gear, but it will get your attention.
Yes, it's much easier to hit the limiter (155mph) in the vert. But with the top down it's quite the rush!
Old 01-20-2022, 01:20 PM   #60
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
There is no limiter. I can hit 190 in 7th gear.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 01-20-2022, 01:33 PM   #61
Mark R
Drives: 2018 ZL-1
I went 194 indicated, stock car, A-10, race gas booster, slightly uphill, at 5400 ft altitude. I did, however, have about 6 miles of road.
Old 01-20-2022, 05:25 PM   #62
FRANK121
FRANK121's Avatar
Drives: 2022 Camaro ZL1
So how did the ZL1 feel at that speed?
I have gone 197 in my slightly modified Z06 Corvette and it was glued to the road!
2022 Black ZL1
RotoFab CAI, AWE Touring Edition Cat Back Exhaust.
665 Crank hp. est. and 660 Crank ft. lbs. est.
Never been Dynoed
FRANK121 is offline   Reply With Quote
Old 01-21-2022, 10:06 AM   #63
Mark R
Drives: 2018 ZL-1
It felt pretty darn planted. No concerns, other than the obvious ones of driving flat out on a public road, in Mexico, of course.
Old 01-21-2022, 02:21 PM   #64
JSH
JSH's Avatar
Drives: '20 ZLE
I seem to recall Hennessey doing 220 in a CTSV years ago
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 01-22-2022, 04:53 AM   #65
wnta1ss
Drives: 2017 Camaro 1SS
Yes, a stock ZL1 has a limiter, for a coupe it's set at 206. Your car is tuned, so yours might have been changed. Below is a screenshot of maximum allowed vehicle speed from a stock ZL1.
Old 01-22-2022, 07:26 AM   #66
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Attachment 1089876
I’m Talking about below 200 mph. Your never going to Hit 206mph in a stock zl1 unless you have a tailwind and a dozen miles.
It’s a moot point.
