Old 09-12-2020, 11:57 PM   #57
toohighpsi
Drives: 2015 C7 Z06 M7
I actually asked him that via PM yesterday and he said they're also working on a kit for the Maggie 2300, and that kit would likely work with the Whipple. Sounds like the 2650 kit works because the coil packs are relocated with that blower, so he wants to do a slightly different kit for the 2300/Whipple setups.
Correct, it requires a slightly different fuel rail design to avoid having to move the coils. We had to cut some "non automotive" parts last week so we'll be back to rails this week. We haven't been able to test fit the 2300 or Whipple yet so there still are unanswered variables but it's highly likely that it will fit just fine.
The system is a tight squeeze on my Z06 with the Magnuson 2650 but with a couple simple modifications it fits under the stock hood. Hoping to finish the wiring this week and have it running again. Really looking forward to see how much power we will be able to pull out of this otherwise stock LT4 with plenty of E85...
Mike
www.toohighpsi.com
2015 Corvette Z06 M7
2021 Porsche GT4 M6
2023 Corvette Z51
Old 09-13-2020, 12:00 AM   #58
toohighpsi
Guess I'll have to fly out and help him since I don't work anymore. Early retirement.
I'm guessing that anytime in January would probably work good for you
Mike
www.toohighpsi.com
2021 Porsche GT4 M6
2023 Corvette Z51
Old 09-13-2020, 11:21 AM   #59
SienarSystems
SienarSystems's Avatar
Drives: ZL1 1LE
Very interested to see what the Z06 does with your system on E85 and pump.
SienarSystems is offline   Reply With Quote
Old 09-15-2020, 08:08 AM   #60
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
It seems like if it fits under your stock Z06 hood, with simple mods, it might fit under a stock ZL1 hood, too, yes?
'20 ZL1 Black "Fury"
Old 09-25-2020, 11:20 PM   #61
asthmamax11
asthmamax11's Avatar
Sounds like the 2300 might not have close to same results as this due to the IATs/timing
This sounds like such a great way to run E85 on a boosted car
Hope it can work with the 2300
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 09-26-2020, 01:56 AM   #62
toohighpsi
When your able to run a fair amount of E85 the inlet air temps become considerably less important, especially with a PD supercharger.
Lower inlet air temps will reduce the boost pressure from the SC requiring slightly less drive power for the SC, but the bigger factor of the IAT on pump gas is the timing limit to avoid knock. With full E85, knock limits pretty much disappear at boost levels up to about 15psi on an LT1 (much higher on the LT4)
So while the 2300 will likely have higher IATs than the 2650, I'm sure you'll be able to run MBT timing up to about 15psi boost - which will be close to 800 RWHP and beyond the point I'd feel safe with stock LT1 internals.
Mike
www.toohighpsi.com
2021 Porsche GT4 M6
2023 Corvette Z51
Old 09-26-2020, 02:07 AM   #63
toohighpsi
Just a quick shot of the install on my LT4.
Mike
www.toohighpsi.com
2021 Porsche GT4 M6
2023 Corvette Z51
Old 09-26-2020, 07:37 AM   #64
asthmamax11
This is amazing.
I don't have to spend $10k on a cam/pistons/injectors/pumps/etc to run E85 and turn things up
10-11 psi would be good being I'm on stock clutch still
Is your Z06 holding that power on stock LT4 clutch ?
When would you estimate this fuel system be available ?
Props to you and your son for developing these great products
16 1SS M6 White
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 09-26-2020, 08:09 AM   #65
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Attachment 1045473
Old 09-26-2020, 08:30 AM   #66
L78toLT1
L78toLT1's Avatar
I hate to tell you Greg, but retirement at your age, or mine doesn't really qualify as early!
If you start hanging out with Mike, the NA plans for your C7 will be out the window before you know it.
Baby Blue
Old 09-26-2020, 08:32 AM   #67
gtfoxy
Drives: '21 Wild Cherry ZL1
Attachment 1045473
Looks good!
For us LT4 folks how much would you expect it to extend our power capabilities, with various fuel types, of the factory high-side?
Old 09-26-2020, 07:48 PM   #68
SienarSystems
Drives: ZL1 1LE
Those rails would look great here
Old 09-26-2020, 08:37 PM   #69
laynlo15
Drives: 2022 Lt1 A10
I agree that they would look good and you could really bang the gong for sure. Yah Mike's a bad influence on me. I didn't want to put a 2300 on and he said sure you do, then I was trying to refuse a 2650 and he said your gettin one. I accepted so it just went on and on. I just couldn't resist and well you know he's a good talker so here we are again. The C7 is unknown at this point, once I get in the 10s this year NA we'll see what happens over the shitty midwest winter. Might get bored and get another Maggie.
Old 09-27-2020, 05:26 PM   #70
ZO6Ted
Old badass
ZO6Ted's Avatar
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2
You know you need to Greg. We can't leave stuff alone. BTW I may have found a good shop I should know tomorrow.
ZO6Ted is offline   Reply With Quote
