Go Back   CAMARO6 > CAMARO6.com General Forums > Z/28 Discussions
Old 07-16-2020, 11:45 PM   #57
ModernCamaroZ28Fan
LT1_Radenso
ModernCamaroZ28Fan's Avatar
Drives: a 2 spd water bottle
Not trying to be that guy, but I doubt that we will have a 6th generation Z28 due to what GM is choosing to do with its budgets.
But, let's get theoretical. If something like that were to happen, it would be as fast as, if not faster than the GT500.
Note, that the car will be most likely slower than 3.1 seconds, as the spoiler will affect drag, and the car will most likely be a bit heavier than 3425 pounds.
ModernCamaroZ28Fan is offline   Reply With Quote
Old 09-09-2020, 11:23 AM   #58
ZRacerLE
ZRacerLE's Avatar
Drives: The DSSV Twins: ZR2 and ZLE A10
Haven't read the whole thread so I apologize if this has already been discussed, but I wonder if the FPC engine that's going in to the C8Z might be going in to the Z28? Especially if they do the NA FPC (I actually believe the C8Z is getting a TT FPC).
ZRacerLE is offline   Reply With Quote
Old 09-09-2020, 03:06 PM   #59
Lafourche1
Drives: 2019 CLA 450 Mercedes
It was reliably reported that the Z/28 had been killed. The fact that Al O is now on to electric vehicles would lead me to believe that GM will not spend the $$$$$$$ to engineer any of these suggested vehicles. Testing, certification and a host of other considerations would indicate that there is not going to be a Z/28 and a 7th Gen may be on life support with a priest being summoned for last rights.
2019 Lunar Blue Metallic Mercedes CLS 450
2021 C43 AMG Mercedes Coupe Metallic Cardinal Red
2014 Lincoln MKT EcoBoost (The Bus)
Lafourche1 is offline   Reply With Quote
Old 09-09-2020, 08:01 PM   #60
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
Originally Posted by GTO_Gregory View Post
Now if a Gen6 Z/28 went outside the box and had carbon fiber body panels with a slimmer, lower front end, and built in aerodynamics in the rear, plus a 600HP Corvette LT2, then it would be unique. If it used the plastic body panel process from the Corvette it's weight might drop two-hundred pounds to say 3425 lbs. With additional aerodynamics and added horsepower it could be a slick piece!
This will make it end up more expensive than the ZL1... Just like the 5th Gen Z/28, and we all know how that worked out for Chevy sales-wise.
And that's the thing, track-oriented models are expensive because all the things exclusive to it, which means less economy of scale and higher cost. There is a reason M4 GTS is horrendously expensive. If GM does something like that, it wouldn't be that different. It's too expensive for your typical track junkies(which will just buy the ZLE that's likely cheaper than a theoretical Z/28), and it's too hardcore to attract people who can usually afford something like this.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 09-18-2020, 10:38 AM   #61
carbon fibr
carbon fibr's Avatar
Drives: 2021 ZL1 1LE
June 2020 GM released a new 427 crate engine. I think they would put this in the new z28
https://media.chevrolet.com/media/us...612-crate.html
2021 ZL1 1LE Satin Steel Grey
carbon fibr is offline   Reply With Quote
Old 09-18-2020, 01:38 PM   #62
ModernCamaroZ28Fan
LT1_Radenso
Why do I smell a dual clutch camaro? I could also see a manual, but I definitely feel like it will have a dual clutch camaro as an option.
We can't go one generation without one Z28.
Old 09-18-2020, 01:45 PM   #63
ModernCamaroZ28Fan
LT1_Radenso
Originally Posted by 2SSRS@Gen5diy View Post
It wont be that much lower on power 50Hp at best, if you remember the last Z/28 was down 80 HP the the ZL1 and still went faster at the ring.
Scary that you'd say that, this new LS7 is only 80 down from our current ZL1.
Old 09-18-2020, 02:20 PM   #64
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
Wondering if crate engines have to meet the same requirements as production engines.
Old 09-18-2020, 04:13 PM   #65
UnknownJinX
That's what I am thinking as well, with the emission standards required on road cars.
Crate engines are technically competive use only.
Current:
Past:
Old 09-21-2020, 08:53 AM   #66
shaffe
Drives: 21 Bronco
This is from the bottom of the press release
"Because of its effect on a vehicle’s emissions performance, this engine is intended exclusively for use in competition vehicles. This engine is designed and intended for use in vehicles operated exclusively for competition:"
Lets keep it simple. ..
Old 10-22-2020, 02:39 PM   #67
whiteboyblues2001
whiteboyblues2001's Avatar
Nope, they don't.
The engine has to meet the requirements of the car, generally.
So, I can't stick one of these LS427/570 crate motors in my '16 SS and call it a day. It would technically no longer be legal to drive on public roads.
But some crate engines DO meet today's standards, like the LS3, LT1, LT4, LT5, etc., are crate engines and can be used in modern vehicles and maintain legal road status.
And boats are a whole different story in terms of legality. Has anyone seen Mike Finnegan's big block twin turbo boat?
As the first comment on the video states: "0 to 113 in 4 seconds ON THE WATER! Finnegan: "Could be faster" Cant wait for more uploads!"
whiteboyblues2001 is offline   Reply With Quote
Old 11-07-2020, 07:19 AM   #68
Number 3
Hail to the King baby!
Number 3's Avatar
Well considering Ford just killed the 350GT with it's wonderful engine it's doubtful GM puts a rumored Corvette engine in the Camaro for a year or two. Big development work.
Also reducing the weight significantly as someone suggested would be HUGELY expensive.
The car OP describes is basically a $100,000 Camaro. So if you are spending $100,000 on a car would you want a Camaro Z/28 or a C8 that will still blow it off the road with the same engine?
There just doesn't seem like a good business case for a Gen6 Z/28.
Biggest hope I think is an (arguably) 7th gen car with GM's first true performance EV propulsion system. Whether you call it a Camaro is another issue, but that's my hope and prediction for 23 or 24.
Old 11-07-2020, 12:49 PM   #69
Bhobbs
Bhobbs's Avatar
GM undercut the Camaro to keep the Corvette on top. The management can’t support two performance Chevys.
Old 11-07-2020, 06:21 PM   #70
396ssrat
Drives: 66 Chevelle SS
Gasoline will be dead soon.
66 Chevelle SS 396
91 octane Driver n/a
6.44@105.78 1/8th mile
