#57 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
#58 |
![]() ![]() Drives: 2023 2SS, 2018 1SS 1LE, 1993 Z/28 Join Date: Jun 2018
LT1 Convertible with Lowering Suspension Upgrade System
We want to add a Camaro Convertible 6.2L A10 as a family cruiser. (I already have an ‘18 1SS 1LE coupe). I’ve located an LT1 vert with the OEM Lowering Suspension Upgrade System installed, but stock wheels and swaybars. Has anyone driven a vert with the factory lowering suspension? I’m a little worried about the lowered suspension kit adversely affecting the ride quality of the more structurally flexible LT1 vert, and I’m sure I’ll want to add a more aggressive wheel-and-tire combination. Any thoughts?
#59 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
As far as wheels go, I would check out APEX wheels at www.apexraceparts.com You cant do any better than Michelin Sport 4S tires so I would stick with those. Check out APEX's fitment guide on their website. I am a firm believer in a rotatable wheel and tire setup better known as a SQUARE set up. The 305 30 19 tires and APEX 19 x 10.5 wheels are the largest ROTATABLE configuration you can have on a SS without having tire poke issues. A more conservative 285 30 19 tires on 19 x 10 inch wheels works great also.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
#60 |
UPDATE
Well the SG3 suspension has been installed and I am waiting on the alignment shop to realign. Also in this process, ZL1 brakes were installed in the REAR and FRONT of the car as well.
GM claims that the SG3 suspension lowers the car about 20MM per corner or roughly 3/4 of an inch from stock height. This appears to be true. The SWAY BAR kit apparently consist of 1LE sway bars which are much beefier than the stock SS units. On the brakes, the REAR ZL1 brake set up appeared be identical to the stock SS set up. The ZL1 front brakes however were a significant upgrade with larger rotors and calibers. Once aligned I will try and get some handling data in terms of lateral G's and such. MY original idea was to also have a LT4 blower set up installed but since I will be primarily road coursing and auto crossing this car when NOT daily driving, AMP has proposed a BIG NA set up using my current LT1. This of course eliminates most issues due to heat soak and they have told me they can get me close to 600 RWHP NA so thats more than a stock LT4 anyway. In a sense, this will be for me what the 6th GEN Z28 should have been, an NA great handling car around 600 RWHP. Will post back in a few days.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 08-06-2020 at 07:52 PM. |
#61 | |
#62 |
OK Well I have taken the car to two different road courses and the suspension mods I have been very happy with it. With the mods and the square tire/wheel setup the car handles fairly neutral. It pushes a little on the front end at the extreme limit but that has more to do with the lack of camber (right now it is set for -2 degrees negative camber and really needs -3.5 or so.
I purchased some VORSHLAG camber plates so I can easily so back and forth between -2 and -3.5 degrees camber for street and track use since I use the car as a daily driver. These are being installed this week. I also am using MS 4S 300 treadware tires so that is a limiting factor as well but they handle VERY WELL for what they are. The car NEVER gets above normal operating temperture and I have ZERO brake fade with those Zl1 brakes. With 100 treadwear tires I have no doubt the car should outhandle a Zl1 1LE expecially since the car is carrying 250 pounds less weight than a ZL1. Once the power upgrades are in place (580-600 rwhp NA) then that in my opinion will make a GREAT road course car.
#63 |
I'm curious if anyone ever figured out the part numbers of the shocks and springs in the event that one needs replaced.
Brandan |
#64 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Someone posted the numbers from one set a while back, but it seems GM changed the part numbers shortly after or made them unavailable through normal means because I wasn't able to pull them up anymore.
#65 | |
![]() ![]() Drives: 2021 LT1 6spd Join Date: Nov 2020
https://www.shopchevyparts.com/perfo...-92294544.html https://www.shopchevyparts.com/perfo...-92292611.html Has anyone driven theirs as a daily with the lowering+suspension kits on? I'm interested but don't want a horrifyingly bad ride in my DD/only car. Interested in results.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
#66 | |
#67 | |
My understanding of suspensions is they settle in after 1000 or so miles, so it isn't overly harsh? How about going up inclines, driveways, etc? I am very interested. Did you do both sway and lowering?
#68 | |
I can tell you for a fact that it lowered the front of the car about 3/4 of an inch and the rear of the car about a half an inch. I DEFINITELY would get the sway bars. I also upgraded the wheels and tires to APEX SM-10 19 x 10.5 ET22 with MICHELIN Sport 4S 305 30 19's on all four corners. The measurement is about 4.5 inches of ground clearance just behind the front tires.
#69 | |
Those are sweet wheels, I like them. I'm sticking with my stock wheels for now, would like to eventually get away from low-profiles, I was never a fan of the massive rim/small tire paradigm. I guess I will have to look into this upgrade for sure, and it is warrantied which makes it doubly tempting.
Previous: 1997 V6 Camaro, 5spd, Black Last edited by Crushin_LT1; 12-03-2020 at 02:23 PM. |
#70 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I'm gonna throw out the same question that I've posed several times in the past in hopes that new eyes will see it any give me some feedback:
Has anyone with a MRC equipped '16 SS installed the handling and lowering kits? I've got the handling kit and am very pleased with it. It's definitely a noticeable improvement on track, and only slightly more harsh on the street. I am hesitant to install the lowering kit as the MRC refresh is not available for 2016 cars. Does anyone have experience with this kit on a MRC '16 model?
Baby Blue
