Old 06-03-2022, 11:44 AM   #57
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Thanks kwav8r used your pics for a Moroso install, which has the same looking tank and hoses.
Note you need to allow a bit more slack in the top hose to allow it to snake forward some to clear the air tube. Also be conscious of the mounting plastic clips when cutting/judging the outlet hose. You will reuse the radiator shroud plastic clip on the hard inlet line on the driver's side and to the airbox (if stock) for the outlet hose.
I won't be back to COTA until fall to test but last month in the straights it was obvious the car was not making full power. Hoping this helps.
wakespeak is offline   Reply With Quote
