#57 | |
#58 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
Thank you sir.
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
#59 | |
![]() ![]() ![]() ![]() Drives: 2018 ZL1 A10 Join Date: May 2012
DAVENPORT STAGE 2 PLUS - 2" ARH ceramic coated headers - 3" ARH catless exhaust - Stock NPP mufflers - Kong ported SC - Katech 103 ported TB - Rotofab 5" Big gulp CAI - 22.5% lower pulley - ATI Harmonic balancer - Cordes SC expansion tank - MSD hi temp ignition wires - Koolsox spark plug insulators - custom tunes - 660hp/725tq pump - 713hp/763tq race
#60 |
Odd. Still works for me. Here's a screenshot of what it is though. Sent from GM Customer Care & Aftersales.
#61 |
![]() Drives: ZL1 1LE SUMMIT WHITE Join Date: Feb 2018
2018 ZLE * StudioRSR Half Cage * SkidmarkGarage Rear Seat Delete * ZL1ADDONS Lift Pads * Roto-Fab CAI * Forgestar CF5-V's * Michelin PS4S * Racequip 6 Pt. Harnesses * Sub-strap Brackets by Carmena Performance * Speedhut Shift Light * Leroy Eng. Hidden Hitch (for the TYR RAT)* Gen5DIY Rapid Flash 3rd Brake Light * KOOKS 2" LT * Green Cats * AWE Cat-back Track Edition *
________________________________________ 2005 NISSAN TITAN 1997 BMW E39 (Thug In A Suit) R.I.P. 10/04/18 2002 MAZDA Protege 5 (Time Attack, Hillclimb) SOLD ![]() |
#62 | |
It says at the bottom “not for 1LE package” Talk about adding to the confusion??
#63 |
The only reason that would be is because the 15w50 is still a more extreme track oil and they're figuring that a 1LE will see the most abuse/more abuse than "regular" cars. And it says "not recommended" so it's just a recommendation. Obviously anybody who can think for themselves will realize if they need the 15w50. Chances are if you're that serious into tracking to justify the better oil, you probably won't run Mobil 1 anyway.
#64 | |
![]() Drives: ZL1 1LE Join Date: Jun 2018
But, that 'not recommended' is going to cause issues at the dealerships for some people. Some will only go with 'recommended' And will not really think about the 'not recommended' and just tell people not to use it, even for the street. Next fill for the street I will definitely look at the 0w-40. |
#65 | |
I was a little confused because I thought I read somewhere that the 0w40 was also good for the track. I can see how these oil discussions can get out of hand. Hahaha
#66 |
This website is not the greatest !!
I’m looking to order the engine and diff oil. After entering the part numbers it doesn’t give you much of a description!!! Does this price look right to you guys? This is for the diff oil. And I’m pretty sure this is the correct oil filter but I just want to make sure.
#67 |
Got the engine and diff oil from my dealership today. So I would think that most of you guys should be able to get it from your local dealers.
I’m Doing the job on Monday. I can’t wait !!!
#68 |
![]() ![]() Drives: ZL1/335i Join Date: Apr 2014
Does anyone know if this is going to be the officially recommended oil for 2017/2018 ZL1? That bulletin only mentions 2019 models. I’m going to assume that no mechanical changes were made to the LT4 for 2019, which would make me think that GM would make the change official across the board.
#69 |
Can anyone confirm that the differential has a drain plug?
#70 |
