Old 10-22-2018, 03:16 PM   #57
laynlo15
Drives: 2022 Lt1 A10
Dang, I'm 210. I'm going to put me on a diet for next year. Need to loose 25 lbs for sure. I say that every year and it never happens, but it should and the older you get the harder it is to loose fat.
Old 10-22-2018, 03:33 PM   #58
RabbitZL1
Drives: 2018 Camaro ZL1
Lol trust me, I know. But anyway, I’ll be back at the track Friday to dial this thing in more and hopefully get a 10.0
RabbitZL1 is offline   Reply With Quote
Old 10-22-2018, 06:08 PM   #59
Ripper1
Drives: 17 ZL1 convertible
What tire/rim setup are you using and how are you launching?
Ripper1 is offline   Reply With Quote
Old 10-22-2018, 06:31 PM   #60
RabbitZL1
Forgestar f14 17x10 and 18x5 (fronts are pretty heavy). Et street r drag radials. I tried a bunch of different ways to launch. I think flat punching with no preload is best.
Old 10-26-2018, 10:41 PM   #61
RabbitZL1
Went to the track again today. Ran a best of 10.18 @ 138. There were a few oil downs which really killed time. After the boost only passes, I pulled some timing and tested the nitrous from the 1/8th just to make sure everything was in line. Way too rich. Lowered the fuel pressure and went to try again, then another car blew up and ended the day. Might try again Sunday.
Boost Only
Nitrous from the 1/8th
Old 10-27-2018, 06:24 AM   #62
laynlo15
Man you are so close. That last run with the NOS really made the mph killer. Great job.
Old 10-27-2018, 07:28 AM   #63
RabbitZL1
Thanks a lot. Going to get some jets today and probably go back tomorrow. Would love a 10.0 boost only but I don’t know if it will happen.
Old 10-27-2018, 10:42 AM   #64
BMWM.D.
BMWM.D.'s Avatar
Drives: ZL1/335i
Originally Posted by RabbitZL1 View Post
Yes I’m spraying pre tb. But that’s changing soon. The pump is mounted to the tank. That’s a burger tuning tank.
Ahhh...guess you have some N54/N55 experience? Nobody knows about Burger unless they’ve dabbled in the turbo BMW world.
Do the tech inspection guys give you any shit about having the meth tank in the trunk? For some reason I thought you needed a firewall if you did that.
BMWM.D. is offline   Reply With Quote
Old 10-27-2018, 11:20 AM   #65
RabbitZL1
Honestly I was just searching for a meth tank and came across that one. Never owned a BMW. Tech never gave me a problem with it.
Old 10-28-2018, 10:55 AM   #66
BMWM.D.
BMWM.D.'s Avatar
Drives: ZL1/335i
Well, that’s random. I’ve been considering doing a meth system, but wasn’t sure about the trunk mount requirements at the track. I also don’t really want to make any permanent modifications to the car. I’m sure I’ll have to drill a bunch of holes in the trunk to mount that tank and run the line.
Old 10-28-2018, 04:45 PM   #67
RabbitZL1
I used threaded inserts to mount everything. Yea its permanent but it makes mounting easy lol. I plan on keeping this car for a while.....
Old 11-18-2018, 07:06 AM   #68
RabbitZL1
Well the stars are never aligned for me. Tried and tried to go 10.0 on boost only. Stuck at 10.1. So Last pass for the day i decided to spray it with only 700lbs of bottle pressure. That REALLY killed the pass. Definitely didnt hit like 150.....more like 70-90
Old 11-18-2018, 11:59 AM   #69
laynlo15
Man you finally packed the punch with that 9 second pass, mph is awesome. Congrats.
Old 11-18-2018, 06:33 PM   #70
RabbitZL1
Thanks. Hopefully go deeper in the 9s this Friday.
