#57 | |
![]() ![]() Drives: 2017 ZL1 Convertible A10 Join Date: Aug 2017
1st - I had factory headers with primary and secondary cats, and borla NPP catback Sound was about the same as factory regarding pitch, but louder. Mildly louder on startup, same as OEM setup with valves closed (tour mode) mildly louder at idle with valves open, mildly louder on acceleration and at WOT. but IMO, didn't sound like a 650hp car should sound. I find the OEM sound on the weak side , and it pales in comparison to say the sound coming out of the GT-350R2nd - I added upper pulley, kooks 1 7/8" with high flow cats, mated to previously mentioned borla catback ![]() On startup, it screams like a bat that scared the devil out of hell... sorry neighbors even at idle, with valves closed, it gives a nice muscle car hmm, which isn't much different with valves open. But on acceleration and at WOT, its scary. It has the slight rasp of an exotic, but the loud roar of an American pony car, and the two pitches sort of battle each other a bit when driving. It has ZERO drone under constant load when cruising on the highway and actually sounds close to OEM In short, it is exactly what a now 700+hp car should sound like. I have found that all of the GT's and IS-F's and other cars that love pulling up to us want NO PARTS of this, not knowing what has been done under the hood because of the sound . Hope this helps, if not, sorry, I did my best... you really have to hear every setup, It's amazing how different it can sound with this X pipe, that X pipe, this axle back, these headers, etc. oh yeah, doing 615/620 at the wheels on a conservative 91 tune. you'll be able to add some timing and get more with this setup if you are running 93
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq) '17 Maserati Levante- STOCK ![]() |
#58 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
i have them they are awesome i was the testcar for them
#59 |
![]() Drives: 2018 ZL1 1LE Join Date: Apr 2018
Is no one going to talk about the quality of steel? I’ve seen “cheap” headers literally rust through due to condensation where as better quality headers do not.
Fitment is only half the story... you want them to fit AND last... then there is the weld quality, weld type and this is all on top of the tuning of header length and fitment. I feel many of you commenting on this topic only consider the basic of ideas behind design.
2018 ZL1 1LE - Summit White
529whp Baseline / 760whp 762tq ARH Ceramic Coated LTH 1 7/8" \ ATI 15% Lower \ RotoFab Big Gulp \ Katech 103mm TB \ Ported Blower \ DSX Fuel System \ Flex Fuel E85 \ Custom Cam \ Dual Springs \ Corsa Exhaust \ Prospeed Heat Exchanger \ Cordes Big3\ C&R Racing Radiator \ LS3 Stat housing \ 160* Thermostat \ NX Lid |
#60 | |
ARH: * 304 stainless steel headers * TIG welded * Mandrel Bent * 049 thickness MADE IN USA Next, slightly less popular are Stainless Works: * 304 stainless steel headers * TIG welded with 3/8" thick flanges * 3" diameter slip fit collectors with merge spikes MADE IN USA Below Kooks/ARH/Stainless are TSP , Pacesetters, and OBX OBX specs: Full Length Tube Design Mirror Polished Finish Made of 304-Grade Stainless Steel Inlet Port Design: Square Port (2.0" x 1.8") Primary Tube: 2.0" OD Collector: 3.4" OD Piping: 3.0" OD Flange Thickness: 0.40" Runner Wall Thickness: 16 Gauge (1.5mm) Made in China There are some who have had a lot of success with OBX https://www.camaro6.com/forums/showthread.php?t=532404 other snot so much https://ls1tech.com/forums/cadillac-...st-review.html I think that if you look at quality, you can't beat ARH and Kooks If you want a bargain, and fitment that could be great or could be off, take your chances on the Chinese made stuff. So I disagree, many people have spoken on these specifics in one thread or another... but the general and most popular consensus seems to be, stick with ARH and Kooks, if for no other reason, being MADE in AMERICA!!!!!
#61 |
![]() Drives: 2016 Silver Ice Metallic SS Join Date: May 2017
I do have TSP 1 7/8th headers with their catless connection pipes, fitment was easy according to my shop. The only weird thing about mine was that the connection pipes were about a half inch bigger than any others they have seen. The measured other cars with TSP in the shop and mine was a little bigger but I have had no complaints what so ever. The passenger side connection pipe leaked a very small amount but some exhaust sealer worked and now it is all good!
#62 |
@viurniel
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT Join Date: May 2016
ARH or Kooks and don't look back.
My experience: I have purchased some of the "affordable" versions mentioned in this thread, and on occasion regret the purchase... Every time I purchased the higher end brands, I never thought that I should have saved $400 bucks. Also, the source of steel does make a difference. |
#63 |
![]() Drives: Chevrolet Camaro ZL1 1LE Join Date: Jun 2019
is Texas Speed headers made in USA from local steel or made in/from China?
#64 |
![]() Drives: 2019 ZL1 A10 Black Mosaic Join Date: Nov 2018
I have 1 7/8 ARH with cat less X pipe at coating shop now.
#65 |
https://www.camaro6.com/forums/showthread.php?t=535846
another thread on the same subject. David from vengeance weighed in. OP, I would reach out to him or another respected tuner for advice!
#66 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
I don't need to know your history. There is no significant difference between any headers that will make any long lasting or drastic impact on a vehicle. People made these same comments about cheap vs expensive header years ago. People have been making these same comments for decades. Time and time again it has been proven to be untrue. People come on here talking about PhDs in this and decades working in this lab with metals or whatever the hell they do. And for all the fluff, it still remains that their will not be any significant difference in any of these headers. I had cheapo OBK LTs that I bought off Ebay for less than $600 on my 2010 Camaro SS. After 4 years and about 40K miles I traded the car in, removed the headers, sold them for $300, and installed them on the buyers Camaro in 3 hours and he drove off with them. When I removed them and inspected them, they were sound, solid, intact, and had no signs of damage. They were just worn. I could have paired them up next to Kooks headers with the same miles on them and aside from the emblems you would not be able to tell the difference between the two. There is no major difference with any of these headers I don't care if they're American, Chinese, whatever. They're all pretty much the same.
#67 | |
BUT, you can't ignore people's honest accounts of situations like this: https://ls1tech.com/forums/cadillac-...st-review.html I think we can all agree that the build quality on these is subpar , compared to Kooks and ARH. I think what most are saying is, it is unlikely ARH or Kooks would EVER allow headers that look like these to leave their facility and go to a warehouse. You cant say the same for some of the other companies like OBX.
#68 |
![]() Drives: 2019 Camaro ZL1 Join Date: Apr 2017
Anyone looked at Corsa headers?
#69 |
@viurniel
Many of us that have bought low cost performance parts and have bad experiences with them tend not to post about it because we don't want to be shamed for the decision with "it's your fault for going cheap". IMO it is a roll of the dice with the low cost stuff - sometimes good, sometimes crap.
Also, like I said before the materials are different based on where they are sourced. Nevertheless, we know GM sources a lot of stuff from China and it works well in our cars. I believe that the issue with the knock off headers is mostly due to the R&D and the Q&A that goes into making them, and not the metal itself. |
#70 | |
