Old 07-29-2018, 10:28 PM   #57
steelheadrob
Tactical Garage
steelheadrob's Avatar
Yeah, Whipple described it as a coupler noise. If it was an easy part to replace I would be fine with them shipping me one so I could install it myself.
steelheadrob is offline   Reply With Quote
Old 08-04-2018, 09:11 AM   #58
steelheadrob
Tactical Garage
Phase 2 of my build is officially under way. Will be adding fueling, additional air flow and a custom tune. This should get me over 600 rwhp and well into the 10s for 1/4 mile time.
I will be posting up some videos on the install of the parts as well. Any advice on the installs would be great.
Take a look at the video for more details.
Old 08-04-2018, 11:51 AM   #59
d729596
d729596's Avatar
Drives: 2016 SS Hyper Blue
Good luck. We seem to be mirroring each other, same fuel system upgrades at the same time. When I get home from work, going to start pulling my gas tank.
d729596 is offline   Reply With Quote
Old 08-04-2018, 10:24 PM   #60
steelheadrob
Tactical Garage
Let me know how it goes. I will starting mine next Saturday morning 8/11. My custom tune is scheduled for 8/27. I ordered the Texas speed headers with high flow cats today. Still debating whether to add meth/ water injection now or wait for the spring. What are your mods and which upper pulley are you planning on running.
Old 08-05-2018, 06:32 AM   #61
d729596
d729596's Avatar
Right now I am running the stock upper pulley, 3.625 giving me 9-10 lbs of boost. Mods after this build will be, Whipple, lt4 high side and low side pump, jms booster, lt4 injectors and flex fuel sensor, planning on running E85 . Will be using remote tune by jannety. I am looking at high flow cats to be a part of this build. I am still running stock exhaust and stock air box, with plans to upgrade the air box at a later date. Headers are on the back burner. Trying to upgrade tires on suspension in the spring. I am in the minority of trying to keep the stock sound. I do have my Whipple off, sending it out Monday to see what they can do about the coupler noise. If I run into any issues I will post them here. Not really expecting much, so far everything is going as of planned.
Old 08-06-2018, 09:25 AM   #62
steelheadrob
Tactical Garage
Let me know what Whipple does about the coupler noise. Did you record a sound clip? Curious if it is the same noise I am hearing.
Old 08-06-2018, 10:30 AM   #63
d729596
d729596's Avatar
I do have a sound clip, can try to find it after work I will try to post it . Best way I could describe it is like a marble bouncing around inside front of supercharger. It would go away when you stepped on the has. But I could hear it from 4 ft away with hood closed. I will keep you updated, shipped out this morning.
Old 08-07-2018, 03:59 PM   #64
d729596
d729596's Avatar
Can't get a very good copy to upload, sounds really muffled, not a good example of what I hear
Old 08-15-2018, 11:14 PM   #65
steelheadrob
Tactical Garage
Got a new toy for the shop. Check it out.
Old 08-16-2018, 04:54 AM   #66
d729596
d729596's Avatar
Very nice!!!!
Old 08-16-2018, 06:11 PM   #67
steelheadrob
Tactical Garage
Thanks.
Old 08-25-2018, 10:29 AM   #68
steelheadrob
Tactical Garage
Got the Zl1 in tank fuel pump and bmr drive shaft loop installed.
Old 08-31-2018, 08:30 PM   #69
steelheadrob
Tactical Garage
Update Horse Power numbers with LT4 Fueling, Headers and RotoFab.
657 rwhp.
See video for detials
Old 09-04-2018, 06:37 PM   #70
d729596
d729596's Avatar
Impressive numbers
