#57 | |||
Drives: 2016 Camaro SS Join Date: Nov 2015
As for the upper stick, it is black anodized aluminum. This sounds like an interesting marriage between the two Hurst products, we're interested to hear/see what you have going, we may have a recommendation to help accomplish the task. If you like to PM me with additional details of what you have and what you're trying to accomplish and I will try my best to help you out with your project. - Jason @ Hurst |
#58 |
![]() ![]() Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
Just received my new stick! Currently gluing the ring back to the shift boot and trying to find the set screw!
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
#59 |
I glued the sides of the shift boot to the top of the black ring and let it sit for about an hour. Then started the ring on to the knob, tucked the rest of the leather in, and applied glue. Then I put something soft under the knob, out the knob down, so it was inside out, and put a 1-3/16 socket on the outer edge of the black ring and clamped in place.
If you lose the set screw from your original shifter like I did, I went to Ace and bought a M5-.80x16 countersunk bolt.
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance Last edited by Dubchitts; 09-18-2018 at 05:30 PM. Reason: Correct set screw size |
#60 |
It's Finally Here! Hurst Upper Stick for Hurst Billet/Plus Shifter - Part# 2385002
You demanded and we listened! For those 6th gen Camaro owners that have the Hurst Billet/Plus Shifter and want to reuse the factory shift knob, we have some great news.
The upper stick portion is now available for purchase. This item can only be purchased by calling us at 707-544-4761; this part is not available on the website. When you call in just let any member of our Support Team know that you'd like to purchase the Hurst Upper Stick, part #2385002. Ladies and Gentleman you have patiently waited and for that I am thankful! If I can be of any assistance please do not hesitate to PM me. - Jason @ Hurst |
#61 | |
- Jason @ Hurst |
#62 |
All done! Thanks Hurst for hearing us and making this product for us!!
It sits a bit higher than i had my cue ball, but the shift action is still very short and precise.
"Spitfire" 427ci
#63 |
#64 | |
![]() Drives: 2018 Camaro 1SS Join Date: Aug 2021
#65 |
![]() Drives: 2023 ZL1 M6, 2010 SS M6 Join Date: Oct 2009
Old thread - I had to get out under some time pressure/didn't get to ask the installer; but I gave him a printout of the edited PDF from this thread.
Here's a bit of a 'before' and 'after' https://www.youtube.com/shorts/IEW7ejwv7Mw |
