#57 |
Dyno Show Queen LOL
I did 1 7/8 no issues so far. If I remember the heat shield covers them correct?
#58 |
![]() Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
[QUOTE=EDFHOBBIES;10996272]I did 1 7/8 no issues so far. If I remember the heat shield covers them correct?
The OEM exhaust heat shield did shield the lines from the heat. But now, there is only an approximate 1/4" gap between the header and brake line. I can't see anything mechanical that would fit? |
#59 |
Dyno Show Queen LOL
Maybe header wrap.. and motul or SRF fluid that has a higher boil point
#60 |
Cool. Thanks for the help.
#61 |
![]() Drives: ´18 ZL1 A10 Red Hot 😍 Join Date: Jan 2016
Did you change the thermostat? Thank you.
First ZL1 in Spain (Madrid)! Red Hot, A10, PDR, carbon fiber hood & grounds effects...
#62 |
#63 | |
Thank you.
#64 | |
I listened to Ted Jannetty talk about this subject. I believe he advocates a lower temp thermostat on certain applications. But, I think the number is minimal. Spinning the blower outside it's comfort zone certainly generates more heat. So, in theory, a slightly cooler thermostat might help mitigate that heat by allowing the car to run cooler. But, if I get the proper gist of what Jannetty was saying, running too cool of a thermostat could be detrimental to the motor by not allowing it to reach the proper operating temperature. These cars were designed to run at a particular temperature. How much can one fiddle with that number without consequence? |
#65 |
Dyno Show Queen LOL
Cheap 100 hp!
$395 Speed Engineering's headers $471.99 ATI DAMPER 918856 jegs $115 Blower ring LPE sold by me NIB in member section for sale $35 K080845HD belt Amazon Prime $9.79 ATI crank bolt jegs $55.99 NGK 6510 plugs Amazon.com $350 used normal rotofab or $450 used big Gulp Use the jegs coupon spend 299 get 15 off order the damper and crank bolt $466.78 damper & crank bolt $115 for my NIB 9.17 lower pulley $395 Speed Engineering's headers $35 belt at Amazon.com $55.99 for 8 plugs Amazon.com $1067.00 just add a rotofab or cut the bottom out of your stock box and add a green airfilter.. Man that's cheaper than my build!
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber Last edited by EDFHOBBIES; 11-21-2021 at 12:19 PM. |
#66 |
Petro-sexual
Good finds Jack. Thanks for sharing.
#67 |
Petro-sexual
BTW - How do you like those 6510s? I think I went a little @p3$hit and got a couple sets of 6509s. I haven't swapped them in, yet, but was wondering what kind of life are you seeing out of those? I don't think (I haven't seen you mention too much) I drive my car as much as you do yours, but was wondering what you thought about those?
I went with a heat range cooler than those, because I've only got 91 (and don't want to always run octane booster), so I was trying to see how the car responded to cooler plugs. Even thought Magnuson didn't state to run cooler plugs, I figure I'd try anyways. Thanks for any comments.
#68 |
Dyno Show Queen LOL
About to swap out as preventive maintenance about 12k miles no problems so far.
#69 |
Petro-sexual
But good otherwise since running them? Are you staying with that heat range?
#70 |
Dyno Show Queen LOL
Yes been good no problems w spark blowing out or detonation.
