#57 |
Flyin NOE
Drives: 2018 ZL1 (A10) Join Date: Apr 2017
You need to 'edit' them by turning then saving. Once you save the image in proper orientation then attach in the 'Go Advanced'
#58 |
![]() Drives: 2019 Chevy Camaro ZL1 A10 Join Date: Sep 2017
Thank you Kwav8r! I will try that.
#59 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
Awesome times for minimal mods. Could you list your updated mod summary? Did you put your car on the scale at the track? I'm interested in the race weight.
#60 |
Flyin NOE
#61 | |
Current Mods: -American Racing 2” headers Ceramic Coated -Borla Atak CB -Katech Ported TB -Weapon X 5” CAI -Chevrolet Performance ZL1 1LE solid bushings for the rear cradle -Weld Racing S71 20x7.5” front Wheels with 245/45R20 Mickey Thompsons -Weld Racing S71 17x10” with beadlocks back wheels with 305/45R17 Mickey Thompson ET Street Rs -Cunningham Motorsports Stage 3 package -Stage 3 cam -10% lower overdrive pulley -Ati performance Dampener -Bigger low side pump(10% more flow i believe) -DSX Flex fuel sensor for E85 -Prospeed heat exchanger -160 Thermostat -Dyno Tuned by Ryne Cunningham including shift points. I thinks thats everything. I know the spark plugs were changed but not sure exactly what they are now. |
#62 |
aka BeastZL1
Were you running E85 or pump gas?
#63 |
Car was on E85 for the most power at the Drag Strip. I launched the car in Touring mode, turned all the nannies off with the 10 second hold down of the traction control button and ran 18psi in my rear tires. Left off a foot brake and 2000 rpm to hit my 9.
#64 |
aka BeastZL1
No launch control?
Sent from my SM-T350 using Tapatalk
#65 |
Yes no launch control. I was told the car pulls timing at the start. I turned off all the nannies and the car went 1.5 60fts and finally hit my 9.
![]() Also ended up in Lethal Camaros YouTube Video https://youtu.be/ZDmFoBexU1c
#66 |
ZL1 Weigh in 3/8 tank of E85
Ok i got my car weighed today! It had 3/8 of a tank of E85 and it weighed in at 3860lbs with no driver. With me inside my car weighs 4040lbs. That’s about the same amount of fuel i had in it when i hit my 9.99 run. Yes i know he spelled Camaro wrong. It was a 4cyl mustang owner.
#67 |
Drives: ZL1 ATS-V CTS-V C7Z Range Sport SC Join Date: Mar 2016
congrats man!
#68 |
#69 |
![]() Drives: 2017 Camaro SS 1LE Join Date: Jul 2017
Nice job!
Congratulations! |
#70 | |
