Old 03-03-2020, 06:51 PM   #57
Badmojo
aka BeastZL1
Badmojo's Avatar
ARC 8 ET11 Front 19x11
ARC 8 ET43 Rear 19x11
No spacers
-2.0 front camber & -1.7 rear camber
Bridgestone Protenza RE71R's 305-30-19
Factory Springs, Mag Ride, This is a normal ZL1 (not 1LE)
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 03-07-2020, 03:33 PM   #58
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
No spacers
Right. With the correct offset you wouldn't need spacers. Car looks great.
How long do the RE71R's last?
Old 03-07-2020, 03:47 PM   #59
Badmojo
aka BeastZL1
Badmojo's Avatar
Thank you sir! Four track days with a rotation of the tires on the wheels so far. I'm right at 50% worn.
2019 Camaro ZL1 1LE
Old 03-10-2020, 06:40 PM   #60
Blackmonba6Gen
BLUPRINT_1LE
Blackmonba6Gen's Avatar
Drives: 2022 Rapid Blue SS 1LE
Finally have the wheels installed!
Front: 19x10 ET20
Rear: 19x11 ET 43
Tires: 285/35 F , 325/30 R
Stock Suspension & Camber
No Spacers/ Direct Fit
Gorilla Lug Nuts
No Wire Relocation
So far no clearance issues with MRC and the ride quality is day and night compared to stock setup. I can’t wait to get more seat time behind this! The poke wasn’t bad as I thought.
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Blackmonba6Gen is offline   Reply With Quote
Old 03-30-2020, 04:27 PM   #61
Apex Wheels
Apex Wheels's Avatar
Drives: Camaro Z28
Some 5th Gen Racecar action from the boys over at Famous Racing, rocking 18x11" EC-7s wrapped in Pirelli slicks
Apex Wheels is offline   Reply With Quote
Old 04-04-2020, 11:11 PM   #62
davidwarren
Drives: 2019 SS 1LE
Any shots of the 19x11 in et11/43 on a ss1le with stock fenders?what about the huf tpms? Do they show temp and pressure like the OEM? Do they have to be programmed?
davidwarren is offline   Reply With Quote
Old 04-05-2020, 02:07 AM   #63
Scargoes
Scargoes's Avatar
Drives: '18 Hyper Blue 2SS1LE '20 Crush RSR
You will have to program the TPMS when installing any different wheels. The tool is available on Amazon for under $20
The 1st picture is with the alignment at -2.4* F and -1.7* R camber. the second picture is -2.7* F and -1.7* R camber. Tires are 305/30R19 BFG Rival S 1.5
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:28.95 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 04-05-2020, 10:08 AM   #64
davidwarren
Drives: 2019 SS 1LE
Nice. Looks like they fit great. Thanks.
Old 04-06-2020, 02:24 PM   #65
davidwarren
Drives: 2019 SS 1LE
Any downside of the 19x11 front and rear vs the 10/11 setup? Looks like 11/11 would let me run either a stock-like 285/305 but could also run 305 square or 305/325. Whereas the 10 front would max at 295. I just wish all the Camaro spec wheels were included in the spring sale!!!
Old 04-14-2020, 04:16 PM   #66
Blackmonba6Gen
BLUPRINT_1LE
The only downside I can think of is that you will have to grind the steering knuckle down to make it fit and add a spacer. I heard it cause a lot of tramlining with a 305 in the front. I just preferred the 19x10 and 19x11 for direct fit and I’ll be able to test out the setup I went with. Eventually I will see when my skills progress if I really need 305 for the front for track days.
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Old 04-14-2020, 05:21 PM   #67
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Anybody have pics of the FL-5's on their Camaro?
Old 04-14-2020, 09:30 PM   #68
Scargoes
Scargoes's Avatar
With the 19x11 et11, there is only grinding of the strut mounting tabs (which you need to do with 19x10s if you run any camber anyways) but you don't need a spacer of any kind unless you want them. At low camber settings, the 11" wheels stick out pretty far so I don't think anyone would want to run spacers.
Old 04-17-2020, 09:55 PM   #69
Blackmonba6Gen
BLUPRINT_1LE
your right, that makes sense about the spacer. I wasn't aware that I would have to grind down the strut tabs for 19x10 for camber. I will keep that in mind if the current stock camber isn't good enough. thanks!
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Old 05-05-2020, 01:31 PM   #70
Dagstar
Dagstar's Avatar
Drives: 2016 Camaro SS
ARC-8 Satin Black
19x10 ET20 with 285/35/19 Continental ECS
19x11 ET43 with 325/30/19 Continental ECS
AFE springs, drop 7/8" front 1" rear, MRC suspension
no spacers
-1.2* front camber(not pictured), standard -1.0* in rear
Dagstar is offline   Reply With Quote
