Old 01-31-2020, 06:30 PM   #57
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
I ordered Hotchkis front sway bar and BMR rear sway bar after speaking with Ryephile. I've learned They're both 30% stiffer in the middle hole
I cannot wait to test them after I get a baseline with OEM bars
glamcem is offline   Reply With Quote
Old 02-24-2020, 01:11 AM   #58
GunMetalGrey
GunMetalGrey's Avatar
Drives: 2018 ZL1 (SOLD) 992 GT3 (current)
Wondering if there is a reason to go with stiffer sway bars rather than stiffer springs or vice versa? Or both?
I now have YYZ springs in my ZL1 because I’m going to be using SC3R tires this season (as well as 19” wheels) and aside from giving the car a slightly lower stance I thought these springs would be the best at handling the extra grip of the tires and reducing any increased body roll.
They seem to be the most performance orientated springs, as that is what the makers (Powell Racing) intended them for, with progressive spring rates that start out the same as the stock levels but then progressively get much stiffer.
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 02-24-2020, 12:03 PM   #59
Mountain
Mountain's Avatar
If you increase spring rate there are two things to consider 1. street ride quality (if you care) and 2. how the springs work with the MRC (not an issue with a controller). With sway bars, you can increase rate and not destroy your street ride quality as much and you also mess with the MRC less/less quickly. Personally, when tuning a car's suspension, I want to work with the springs and dampers and then add in sway bars for fine adjustment to needs.
Old 02-24-2020, 12:09 PM   #60
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
yup i have afe power swaybars powergrind endlinks and yyz springs and his prototype shocks my buddy whos a wheel to wheel racer and also has done time attack rode in my car yesterday on track with me and told me the car feels super nice and planted and really wanted to drive it lol but didnt want him to beat my time or crash my car haha
Old 02-24-2020, 01:41 PM   #61
GunMetalGrey
Thanks for the feedback, makes sense, I’ve heard the same thing.
Ride quality is still good (subjective of course) and I guess I figured since they tested the springs with the MRC that they took this into account and hopefully did a good job combining them to work well together.
Either way we will see what I notice on the track the season and go from there before making any more changes.
Old 02-24-2020, 01:43 PM   #62
GunMetalGrey
Haha That’s some good feedback, how is the ride on the street?
Does he have any test data yet?
Old 07-11-2025, 07:29 AM   #63
SpeZ
SpeZ's Avatar
Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30
Revived an old thread, but it might help somebody in the future.
ZL1 sway bar (FE4) combined with the DSSV makes the suspension extremely! stiffer. Literally has only downsides and disrupts weight transfer and results to less grip and more wear on tire inside.
ZL1 1LE sway bar (FEA) is way softer and suits the stiff DSSV.
ZL1 1LE front sway bar has a diameter of 27 mm
ZL1 front sway bar has around 30,3 mm
Shape of both is the same. Chatgpt calculated the stiffness of the ZL1 sway bar is 58% increased.
Callaway SC750 ZL1, DIY 1LE with added OEM 1LE Wheels, DSSV Suspension and 1LE Aero, FEA front control arms, DIY oil cooler, CWA 150 pump, bigger intercooler, Phenolic blower spacer, 82°C thermostat, BMR lockout kit, CTSV Brake Air Deflectors, Smooth idle cam, LS7 lifters, Bronze trunnion bushings. Tuned by JRE
SpeZ is offline   Reply With Quote
