#57 |
![]() Drives: 18 1SS 1LE SCCA FS, 99 WS-6, E46 M3 Join Date: Dec 2017
10-4. If you don't mind, feel free to report back on the fitment.
Also looking at custom ordering a 10mm spacer w/OEM bore plus a flange with the OEM flange outside diameter. Unless my measurements were not accurate, the hub flange projects 11.5mm from the hub face. Concerned that with the spacer installed, the hub flange would poke out 11.5-10 = 1.5mm potentially interfering with a flange fabricated onto a spacer. A 12mm spacer would be the safe bet, but I am limited to a 7mm net wheel offset delta per SCCA rules (my MRR wheels are +3mm delta).
#58 |
![]() ![]() ![]() ![]() ![]() Drives: 2018 1SS 1LE Join Date: Feb 2017
I'm using custom hub centric 5mm spacers with my Apex wheels and really like them.
One side fits the Camaro hub and the other fits the Apex rim https://www.motorsport-tech.com/4DCGI/wheel_spacers |
#59 | |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
#60 | |
#61 | |
#62 |
Back side fits over the Camaro flange which is 66.9mm and front fits what ever wheel your using which in same cases is not the same as the Camaro oem. Like Apex non-Camaro specific wheels. However you could still use them if your spacer is so thick it cover the stock flange.
Some people just ignore the flange and let the lugs center the wheel. I don't recommend this for street. |
#63 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
Your studs and lug nuts are the only things that ever locate the wheels on a car. You can have all the hub-centric wheels/spacers/rings you want, but they aren't what is positively locating the wheel, ever. They just make it easier to mount a wheel.
Matt Miller
2020 SS 1LE |
#64 | |
I've used both over the past 20yrs and unless you're running a small spacer, hubcentric is the only way to go. Absolutely is a must on adapters.
#65 | |
Matt Miller
2020 SS 1LE |
#66 | |
![]() ![]() Drives: 2020 SS 1LE Join Date: Aug 2020
It makes mounting just a tad bit easier. It makes life a little better on our cars with studs. On other cars like my BMW that uses bolts, it helps even more. My thought is, for what usually is a few dollars more, I'd spring for hubcentric. That said, I do not believe its a safety concern if you don't use them. |
#67 | |
Matt Miller
2020 SS 1LE |
#68 | |
#69 |
If they are easily available and similar in cost, sure. That's not always the case. And when we're talking about thin wheel spacers (say 5-10mm), you really can't make them hub-centric to the wheel because the spacer is thinner than the hub's center is tall. People get anxious about that all the time and try to use that as a reason that spacers should not be used. There are plenty of things to worry about in this world, but hub-centricity isn't one of them. That's all I'm saying.
Matt Miller
2020 SS 1LE |
#70 | |
I believe I read some where the front hub is 6-7mm, but never measured mine. I just ordered some hubcentric 10mm spacers from the places above, I expect a little protrusion to the wheel's hub, but unsure exactly how much.
