Old 07-11-2018, 02:29 PM   #57
Sheriff37
Do it for Dale
Sheriff37's Avatar
Drives: '16 NFGray V6 M6
Originally Posted by john94si View Post
How do you remove the center console? I have my part i am waitnig on some time to figure it all out on how to take it apart.
Remove the two bolts underneath the kneepads, then go to the rear of the console near the cubby and unclip the bolt covers on each side and remove the bolts. The console should feel pretty loose, just grab the point that it is under the back seat and pull up. It'll be kind of tough to pull out but it's a lot easier than removing the seat. It gets a little hairy when you need to push it back under the seat but it shouldn't damage the leather.
Sheriff37 is offline   Reply With Quote
Old 07-11-2018, 02:30 PM   #58
Sheriff37
Do it for Dale
Sheriff37's Avatar
If anyone on this thread is looking for an upgraded module to use with newer phones I'm selling mine: https://www.camaro6.com/forums/showthread.php?t=533601
Old 07-28-2018, 12:52 PM   #59
bond2
bond2's Avatar
Drives: '16 2SS M6,'96 WS6 M6
I put together a how to video while I installed mine. Probably over detailed, but for those that want a step by step this will help...
https://youtu.be/Ktt8jmr0lDo
'16 NFG 2SS M6,SW NPP compatible axel back, black center stripe, black non-split rims
'96 Black WS6 TA - M6, Pro 5.0, Baer Track kit, Corsa Cat-back, Bilstein shocks
'99 30th anniv TA vert #988- M6
bond2 is offline   Reply With Quote
Old 07-30-2018, 10:53 AM   #60
john94si
john94si's Avatar
Drives: 17 2ss vert
Thank you very much.. i will do mine shortly, ive had the part for weeks sitting on my desk.
john94si is offline   Reply With Quote
Old 07-30-2018, 12:24 PM   #61
F1FTY
Drives: 2018 ZL1
Thanks for sharing!
Quick question - rather than prying the rear seat back into place, could you just tilt the seat bottom by loosening its connection to the car to allow you easier access to the console? I haven't looked much in depth, but usually the bottom seat can be removed with a couple of bolts and then tilted up.
F1FTY is offline   Reply With Quote
Old 07-30-2018, 01:04 PM   #62
ecko04
Drives: Too many to list
Originally Posted by F1FTY View Post
Thanks for sharing!
You can pull the bottom seat cushion off altogether which would make access much easier. Just be ready to pull up as if your life depended on it to get those clamps to break free.
ecko04 is offline   Reply With Quote
Old 08-01-2018, 05:09 AM   #63
Eos
Eos's Avatar
Drives: Camaro Coupé 2.0T AT8 (EU version)
Hi Bond2!,
Great video!! Thanks for sharing it with us!!
See you!!,
Eos
Eos is offline   Reply With Quote
Old 08-01-2018, 05:58 PM   #64
ecko04
I got around to putting mine in today. It’s quite a bit thinner than the original.
It’s the easiest install I’ve done in a while.
There’s certainly no need to remove the bottom seat cushion to prop up the center console. It’s more work to remove the seat cushion than it is to use a plastic panel tool and gently push the seat cushion back to lift the console up.
Sent from my iPhone using Tapatalk Pro
Old 08-01-2018, 09:15 PM   #65
WCoolBreeze
2SS
WCoolBreeze's Avatar
Drives: 2016 2SS, Red Garnet Tint
Again my question. Will this work with a Samsung 9 S+. I have a 2016 Camaro 2SS. My prior Cellphone was a Samsung 7 S and I had to play with it (keep moving it around until it linked up) to get it to charge on the charging pad.
Walt B.
2016 Camaro 2SS
2005 Dodge Magnum R/T (Yes it has a Hemi)
1987 Camaro RS (California Special) - For Sale
Gen6, 2016 Camaro 2SS, Red Garnet Tint (with Silver Rally Stripes)
Ordered: 2-12-2016
TPW: 3-7-2016
Built: 3-7-2016
VIN 1G1FH78G0157626
Delivered: 4-26-2016
WCoolBreeze is offline   Reply With Quote
Old 08-01-2018, 10:10 PM   #66
ecko04
Walt B.
Will it charge? Yes
Will you still have to play around with it to get it linked up? Maybe. The 9 S+ is physically larger than the 7S. If you had to play around with your 7S, then imagine trying to place a physically larger device.
FYI: GM Wireless Charging Compatible Device List
By changing the charging pad, we are doing note #7 and therefore making the car 2019+ compatible.
Old 08-02-2018, 06:20 AM   #67
6spdhyperblue
Drives: 2SS 1LE
Walt B.
The new module has a broader charging area so it will definitely be an improvement. For $70 it’s worth it. If you have an iPhone user in the car I’m sure they’d appreciate it too
Old 08-02-2018, 06:54 AM   #68
ecko04
GM wireless charging upgrade for iPhone X & 8?
I don’t know about that. The “charging area” seems to be pretty identical to the older unit. I could take a pic when I make it down to the garage.
GM states that phones longer than 150mm or about 6” may have reduced or no performance. Top to bottom the S9 plus is a little over 6” at 158mm
Some vehicles do have a larger wireless charging area, the Camaro isn’t one of them. The vehicles with larger wireless charging areas are:
Cadillac Escalade / Escalade ESV
Cadillac CT6
Cadillac XT4
Chevrolet Silverado LD
Chevrolet Volt
GMC Sierra LD
The issue he will have is the rubber mat that’s used to attempt try to keep the phone seated. Sure, that mat can be removed but the charging pad itself is slick and on the first moderately paced turn will send the phone to the floor.
It is also not recommended to use anything between the phone and the wireless charger (i.e. remove the case and go commando) due to heat issues.
Old 08-02-2018, 09:12 AM   #69
ecko04
Charging pad area has not changed
Old 08-02-2018, 11:42 AM   #70
6spdhyperblue
Drives: 2SS 1LE
The area that charges(field) most definitely is bigger and distance from the pad is more as well. If you see the inside of both modules you’ll understand why...
There more to it than the physical size of the module case
wireless charging
