Old 08-11-2017, 01:48 PM   #57
MOSAIC BLACK 1LE
Drives: Mosaic Black ZL1 M6
Springs
Originally Posted by Bakilman View Post
Went in to the dealership to ask about the TSB. They're overnighting the springs and taking care of it on Monday!
Please let me know how my dealership can look this up? I'm in Southern California and they don't know what I'm talking about.
MOSAIC BLACK 1LE is offline   Reply With Quote
Old 08-11-2017, 01:52 PM   #58
Hellobatman
Hellobatman's Avatar
Drives: 2017 Ford F250, 2019 Lincoln Navi
I planned on doing BMR springs eventually, is it TRULY worth letting a tech have his time with your or my vehicle?
Instagram: MattZ_L1 Vengeance Racing Built
Hellobatman is offline   Reply With Quote
Old 08-11-2017, 01:53 PM   #59
TDS
TDS's Avatar
Drives: 2019 Jeep Rubicon Sold:2017 ZL1 A10
I called my dealership, car goes in a week from Monday! I stand corrected that it had to be a safety thing. Wow good on GM making it right for us that ordered a car on faith.
Travis
SOLD ZL1 Summit White, A10, Black Strip, PDR, ZL1 floor mats
Ordered 2/11, 2000 2/14, 3000 2/20, 3100 2/24, 3300 3/7, 3400 3/8, 4300 3/16, 4B00 3/21 Bayed at train yard in Ohio, 4200 3/26 All Abroad for the West Coast, 4800 4/4 Deliverd to portland train yard, 5000 4/7 3:00AM Deliverd to Dealer, 6000 4/7 6:45PM Delivered to Customer
TDS is offline   Reply With Quote
Old 08-11-2017, 01:54 PM   #60
TDS
TDS's Avatar
I gave the service tech the number from post 6. Was not completely right but it put him on the right path
Travis
Old 08-11-2017, 01:54 PM   #61
FringBirdAloha
Drives: Pre-production ZL1 M6
Same here. Mine didn’t know what I was talking about and couldn’t find anything in their database.
FringBirdAloha is offline   Reply With Quote
Old 08-11-2017, 01:55 PM   #62
FringBirdAloha
If we could get the exact TSB number they are using it would be much appreciated.
Old 08-11-2017, 01:55 PM   #63
TDS
TDS's Avatar
Do not know but I will let you know in a week
Travis
Old 08-11-2017, 01:58 PM   #64
Artos
Artos's Avatar
Drives: A10 LT4
Originally Posted by ninetres View Post
The forum rotated the pic for some reason. That's not how it's orientated in my library. And it's hard to hold the tape in the absolute perfect spot, at the perfect angle, and take a pic which is VERY sensitive to exactly where the lens is in relation to the tape for accurate viewing. I tried to have the tape aligned with the center of the hub. Was just offering an additional data point for this discussion. My bad.
And FWIW it's shows ~2 3/8" to the circumference line to the fender. Very unscientific but you should get the point.
It's all good, for what I need that is fine...mine is an early car & is right at 3 1/4" from the fender to the tire line. Coming from 4x4's I'm barely getting used to this lower clearance anyway & OK with the stance.
Maybe wrong thinking on my part, but would worry about the tire rubbing if it was any lower??
Artos is offline   Reply With Quote
Old 08-11-2017, 02:00 PM   #65
TDS
TDS's Avatar
I just called my service guy back, he is at lunch. I will get the info from him and post it
Travis
Old 08-11-2017, 02:04 PM   #66
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Originally Posted by slick3 View Post
In. This would apply to the 1LE im guessing as well.
ZL1 only on earlier builds
RUQWIKR is offline   Reply With Quote
Old 08-11-2017, 02:13 PM   #67
TDS
TDS's Avatar
He said it ended up being 17-NA-208 just like iPODFAN11 posted. It is not a recall but a warranty issue so that might make a difference on where they look
Travis
Old 08-11-2017, 02:14 PM   #68
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
#17-NA-208 - Front Trim Height is too High
Subject:
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Chevrolet
Camaro ZL1
2017
2017
SOP
April 12, 2017
All
All
Involved Region or Country
North America, Middle East
Additional Options
Equipped with ZL1 Package and Special Ride and Handling Suspension (RPO FE4)
Condition
Some customers may comment that the front trim height is too high.
Cause
This may be due to the previous design front springs.
Correction
Replace the front springs to allow the vehicle to be at normal trim height.
Parts Information
Description
Part Number
Qty
SPRING-FRT COIL
84312736
1
SPRING-FRT COIL
84312735
1
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
8033791
Strut, Strut Component, or Spring Replacement - Both Sides
Use Published Labor Operation Time
Service Procedure
Replace both of the front springs. Refer to Strut, Strut Component, or Spring Replacement in SI.
Version
1
Modified
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 08-11-2017, 02:28 PM   #69
MOSAIC BLACK 1LE
Thank your sir!!
Old 08-11-2017, 02:31 PM   #70
FringBirdAloha
Thank you!
