Old 01-21-2019, 08:05 AM   #57
JANNETTYRACING
JANNETTYRACING's Avatar
Thanks
I figured you probably ran out of fuel. We found the limits of the LPE DI pump on E80 @ 8psi. Hard to compare power because 5th gear was used. I imagine dropping back to E60 would free up quite a bit of headroom.
With what injectors and low side?
www.jannettyracing.com
email tedj@jannettyracing.com
Old 01-21-2019, 08:18 AM   #58
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
LT4 injectors
LPE DI pump
ZL1 low with JMS booster
Old 01-21-2019, 08:28 AM   #59
JANNETTYRACING
LT4 injectors
LPE DI pump
Seems odd to me must be stock cam also.
My ZL-1 made 668 RWHP on 10 psi boost on stock fuel system parts.
Old 01-21-2019, 08:35 AM   #60
JANNETTYRACING
Thanks
Yes sir, I am just using boost to fuel combinations as reference.
Old 01-21-2019, 08:37 AM   #61
KingLT1
KingLT1's Avatar
So you are saying my stock cam SS A8 with a 3.5 pulley Whipple (8psi), shouldn't be at it's limits on E80 with those fuel system upgrades?
Old 01-21-2019, 08:38 AM   #62
JANNETTYRACING
I would have expected the LPE pump to extend that a bit.
Ted.
Old 01-21-2019, 08:42 AM   #63
KingLT1
KingLT1's Avatar
Ted.
That that is why I asked if you tested any further because you used E60 with the LT4, so I figured E80 must be putting quite bit more strain on the system. or the AFR is too rich. I should know the fueling and afr data here shortly. I too expected the LPE to have more headroom.
Old 01-21-2019, 08:44 AM   #64
JANNETTYRACING
That is why I asked if you tested any further because you used E60 with the LT4, so I figured E80 must be putting quite bit more strain on the system. or the AFR is too rich. I should know the fueling and afr data here shortly. I too expected the LPE to have more headroom.
I recently tested my car with E-70 and I am just starting to see low side fuel pressure drop
Old 01-21-2019, 09:15 AM   #65
KingLT1
KingLT1's Avatar
So with a Whipple on stock pulley, primary cat deletes, Rotofab, LT4 fuel system, Pump booster, and E78, will I have enough fuel supply? If not will the LPE big bore give me enough?
Only Careful logging will tell for sure but I suspect you will be OK at 8-9 PSI boost.
Also the tuning is a Key player in all of this.
Ted.
Just to clarify, I was reporting back that it took the LPE pump to have enough fuel for E80 on a SS with the mods above. That is why I bumped this thread back up asking if you tested any further with different pullies and more E content on the Whipple SS car.
I don't understand how a ZL1 correlates here being it has a different cam driving the HPFP compared to a SS.
My low side is fine and pressure is holding with the JMS and ZL1 in-tank.
Old 05-14-2019, 03:15 PM   #66
JANNETTYRACING
Originally Posted by Hyperlinkblue View Post
So theres a new table in hp tuners?, what exactly can you do with FPCM?
We can adjust the pressure.
Old 05-15-2019, 06:24 PM   #67
F419sr1
F419sr1's Avatar
Drives: 2017 ZL1
I spoke with your shop today about low side fuel. I’m going to bring the car up Monday
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
F419sr1 is offline   Reply With Quote
Old 05-16-2019, 07:46 AM   #68
JANNETTYRACING
Awesome Thank you for your business.
Ted.
Old 05-16-2019, 04:05 PM   #69
Alpha6gen
Drives: 2016 A8 SS
Nice gains
I have a simple question for you, my car has a maggie kit and we only get 91oct pump ! Can I run 90mm or 85mm pulley with LT4 fuel system and E85?
Alpha6gen is offline   Reply With Quote
Old 05-16-2019, 04:11 PM   #70
JANNETTYRACING
Originally Posted by Alpha6gen View Post
Nice gains
With our LT4 fuel system upgrade package which includes a JMS FPVB you can easily run the 90 mm pulley on E-85 and the 85 mm pulley on E50
